Panasonic GM1 compared to NEX-5R. Should I consider switch?
Started Jan 5, 2014 | Questions
oorraine New Member • Posts: 23
New Panasonic Lumix GM1 seems very interesting. I am thinking if I should switch from NEX to GM1...
I have Sony NEX-5R with SEL 35mm f1.8 and SEL 18-200LE. 35mm is what I normally use. However, I would like something more wide and better for close-ups. Zeiss 24 mm would be ideal, except the price and size. Small size is important to me: I want to take camera with me for my business trips here in Europe. These are usually short trips, 1-2 days. I need to travel light with hand baggage only. During business trips I am able to take photos only in evenings. So good low light performance is a must.
Because Zeiss 24mm is so expensive, I was thinking other options. Then I noticed GM1. I am most interested in GM1 kit having both 12-32 and 20mm + handgrip. How would the image quality be compared to my NEX, I suppose no big difference? Is GM1 with 20mm on par with NEX-5R+SEL35F18 in low light?
Size. I haven't been able to see GM1 live yet. But based on what I have read and seen on web, camera bodies don't have huge difference in size. But GM1 will be a lot smaller lens attached. Is this correct?
Battery. I really like the usb-charging with my NEX. I can charge the camera with my mobile phone charger. But if I have understood, this isn't possible with GM1. I would need to carry external charger. And if I use GM1's extra handgrip, I need to remove that always to be able to access battery. This sounds complicated. I hope I misunderstood something here...
Wifi. Both NEX-5R and GM1 have wifi, so I can transfer photos to iPad while travelling. I suppose this works same way for both cameras?
Would it make sense to switch from NEX to GM1? Or would I be better just buying Zeiss 24mm (and selling my 35mm). I think also Sony RX-100 mk2 would be an option for me (but I suppose my NEX provides much better image quality).
I would like to hear if someone has used both NEX-5R and GM1 and list important differencies between those. Thanks
 oorraine's gear list:oorraine's gear list
Canon G9 X NEX5R Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Sony E 18-200mm F3.5-6.3 OSS LE +2 more
berni29 Veteran Member • Posts: 3,119
Re: Panasonic GM1 compared to NEX-5R. Should I consider switch?
Hi
I so not have the NEX, but I have the GM1 and EM-5 so can make some observations.
Honestly, I think sticking with what you have and getting the lens you want and need is the better option for you. The GM1 with the kit lens and the 20mm and 45mm for low light is great, but it is a 2nd body for me and I can step up to the EM5 when I need to.
If you were using something a lot bigger and wanted something a lot smaller for travel then yes, but that is not the case for you.
I also think it would be nice if the GM1 could use usb to charge.
Berni29
EM-5, GM1 + Pana 12-32mm, 20mm, 14-45mm Oly 45mm, 50mm F2, (prev GH1, E30, E510, E1, E300)
 berni29's gear list:berni29's gear list
Ricoh GR II Olympus E-M1 Sony a7R II Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +13 more
OP oorraine New Member • Posts: 23
Thank you, it is good to hear this from owner of GM1. I start to hunt second hand Zeiss 24mm. And maybe I still find a store having GM1 available, just to check its size myself.
Of course more opinions are still welcome.
Joseph T Lewis III Veteran Member • Posts: 3,594
Well, here's how the camera bodies compare:
NEX-5R Compared to Panasonic GM1
You can obtain the dimensions of the lenses on the DPReview Compare Lenses Side by Side menu.
If you are otherwise satisfied with your NEX, buying the GM1 might not be a good solution. The GM1 with 12-32 kit lens is $750; if you get the Panasonic 20mm that would add another $400 or so. Even a used 20mm would be $300-ish. With that money you could buy the Zeiss, or even a couple of cheaper E-mount lenses you don't currently have.
Have you considered the Sony E-mount 16mm f/2.8 lens? I know it isn't as fast as you would like, but perhaps with a combination of higher ISO and raising the exposure in post processing it might be adequate. It is dirt cheap and very small, and is generally regarded as an acceptable little lens.
To find out if the f/2.8 would work for you, take your current 35mm lens, set it at f/2.8 and ISO 800 (or even 1600), and shoot several pics in the environments you are considering the GM1 for. Try post processing the photos, and see if the images are acceptable to you or not. Won't cost anything other than a few minutes of your time, and might save you a few hundred bucks.
Just a thought...
Tom
 Joseph T Lewis III's gear list:Joseph T Lewis III's gear list
Canon PowerShot G7 X Olympus E-M1 Olympus PEN-F Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +6 more
Camera comparison tool is handy, thanks for the link.
Price level here in Finland is 700€ for GM1 kit. Double kit with both 12-32 and 20mm and handgrip is 999€. Zeiss I can get for 650€. If I get Zeiss, then I will sell my 35mm. I should get ~300€ of that.
In principle I am happy with my NEX. It has tilting screen and usb charging which are missing from GM1. I am just thinking if m4/3 would be a better choice in long run... Before investing to Zeiss I need to consider that.
MrTaikitso
MrTaikitso Contributing Member • Posts: 901
I don't own a GM1, but have owned a 5R, and in good light, it offers superb IQ thanks to Sony's APS-C sensor (I only used the kit 16-50mm PZ lens), however, the handling is as bad as the GM1, which I have not enjoyed whilst trying it in shops. The benefit of the 5R is really the flip display that I always found invaluable. (I sold the 5R because I missed a built in flash, I like using fill flash outside a lot.)
I once owned a GH2 that had superb handling thanks to the control dials and chunky grip. The little wheel at the back of the GM1 is way too small and you risk activating a different feature. The 5R has a universal dial on the top.
All said, I dislike the handling on both cameras and think the larger G5/G6 or NEX 6 if going that route, are far superior.
From the rave reviews of the GM1, it is purely size and IQ that are winning people over. Not enough for me, but maybe for you? --
http://www.flickr.com/photos/taikitso/
 MrTaikitso's gear list:MrTaikitso's gear list
Sony a7S III Sony FE 24-105mm F4
duartix Veteran Member • Posts: 3,613
For 1-2 days trips this seems like the wrong approach. I would take an extra fully charged battery instead.
Duarte Bruno
 duartix's gear list:duartix's gear list
Fujifilm FinePix F40fd Olympus PEN E-P1 Panasonic Lumix DMC-GH2 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +4 more
No. I have anyway usb power bank with me, as a back up power. I can charge my phone, iPad and camera with that if needed. No extra camera battery needed. Usb charging is really good.
This is just my opinion. I know some prefer external chargers or dedicated extra batteries. I don't want to argue about this topic, because it is a matter of personal preference.
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
If it were my money, no way.
Please take no offense, but appears to me, you're all over the map with your decision making process and justification for acquiring another camera to replace your NEX-5R.
Is it just a case of chronic G.A.S.?   Is it change for no good reason, except to try a newer camera?
Are you willing to downgrade IQ to MFT /RX100 from APS-C?     Ok with losing money in trade or selling your NEX gear?
Better to go out and take more pictures with what you already own.
Good luck whatever you decide.
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
I admit, it is a bit of trying a new camera. And if I would go to GM1, I would sell all my NEX gear.
You indirectly answered one of my main question: is GM1 with 20mm on par with NEX-5R+SEL35F18 in low light? What I read above, answer is no.
Actually nobody here suggests a switch from NEX to GM1. And this is a Micro Four Thirds forum... so decision is clear for me now
lapdog99
lapdog99 Contributing Member • Posts: 814
Stick with the Sony and get the 10-18 f4.  To get as wide on a GM1 takes a 7.5.
 lapdog99's gear list:lapdog99's gear list
Fujifilm GFX 100S Fujifilm X-H2
Lab D Veteran Member • Posts: 6,938
Becareful, you may fall in love with the Panasonic GM1
A lot of people (including myself) absolutely fall in love with the GM1 when they see it and first use it.  It is not a stripped down camera and does so many amazing things...and can fit in many people's pockets.
The silent shutter is what really got me.   In perfectly quiet setting no one knows you are taking a picture and no one is distracted.
Either way, enjoy your choice!
 Lab D's gear list:Lab D's gear list
Panasonic FZ1000 Nikon D600 Panasonic Lumix DMC-GH4
Ignore Lee's comments
As soon as I saw where he said "downgrade IQ to MFT /RX100 from APS-C" I had to laugh.   I owned an RX100 for a year and there is no comparison to the GM1.  I also started with the NEX 6 and found there is no noticeable "downgrade" in IQ as I switched to an Olympus (I wanted the IBIS and smaller lenses).   If you read what DP Review says in their reviews, they agree with me.
Oh, and the GM1 with the slightly wider aperture lens is every bit as good as the 5R with the 35mm F/1.8 lens from my experience.  The only difference is one is about twice the size of the other.
I'll add the GM1 has a built-in flash but there will be no option for a VF.   You will have the choice of more lenses and if you were looking at the NEX 24mm lens you will find you can get the 25mm F/1.4 lens which is actually sharper wide open for 1/2 the price.
Severe vignetting.
And yes there are lenses that go to 7mm so that is not an issue.  That Sony lens has severe vignetting.  It is often more than 2 1/2 stops.  There were some long discussions and many examples here about it.
Here's how the sensors of the GM1, Olympus E-M1, and Sony NEX-5R compare:
DxOMark Comparisons
As you can see, your Sony's sensor is better at low light than that of the GM1.
Tom
Hi
Just on the GM1 lacking the swivel/tilt screen, you can operate the camera from a smartphone, so in SOME circumstances you can overcome that limitation.
I actually find that the GM1 handles very well. Much better than you would think. It is not so obvious on first using it, but once you get familiar with the way things work it is in fact really quite intuitive and nice to use.
I am still not suggesting you get one given your circumstances, although I think the m43 offering serves the majority of needs very well.
Berni29
tt321
tt321 Forum Pro • Posts: 13,854
Normally I advocate keeping one's existing system and not switching. However, in this case there is enough motivation if closer focusing with a wider than normal lens plus compact size are important.
The 20/1.7 is sharper than the 24/1.8 across shared equivalent apertures at least in the MTF-50 sense, and does that with considerably smaller weight and size. Depending on which market you live in, the cost of GM1+20 could be similar to the 24 lens alone or even lower. If you keep the NEX as your main system and have budgeted the 24, then spending that budget on a GM1 and 20 will give you a second body for emergency cover w/out much weight/size penalty.
Look again - almost identical
DxOMark Comparisons
Please don't rely on the overall score which is not accurate in most situations. Instead look at the graphs/actual measurements. You will quickly see that all are very close and almost over lapping, so in real life there will be no noticeable difference.  Since the question was comparing an M43 lens with a slightly larger aperture to an APS lens, any difference should be erased.
What is amazing is how much better then E-M1 DR is than the 5R proving sensor size does not dictate which is best.
Re: Look again - almost identical
DxOMark Comparisons
The OP was concerned about low light performance; that is the particular measurement I referenced and NOT the total overall score. The low light rating for the GM1 is 660, whereas the NEX-5R is rated at 910. Are you saying that this difference is inconsequential, and that the NEX is no better at low light shooting than the GM1? (I ask this sincerely, not being an expert at interpreting DxOMark reviews.)
The point I was trying to make to the OP is that instead of spending almost $1000 (US) on a fast wide Zeiss lens, he might "be able to get by" with the much, much cheaper Sony E-Mount 16mm f/2.8 lens for his travels, given the NEX's apparent better low light performance. That combo could tide him over until he figured out if he really wanted to jump ship from NEX to m4/3. And, the 16mm pancake would also meet another of his criteria (that of being small and light).
PS.  I wasn't suggesting he get an E-M1; I had included the E-M1 in the comparison simply because I was curious as to how it stacked up against the 5R, and was too lazy to redo the comparison for the OP with the E-M1 removed.
Tom
kazkioken Contributing Member • Posts: 551
I have a GM1 and a 5N (not a 5R but for all intents and purposes the same camera).  They both have merits, though these days I grab my GM1 with the Lumix 20 f1.7 ii as it has autofocus and is tack sharp wide open.  The only autofocus lens I have for my Nex is the SEL 10-18, otherwise I am usually using manual focus lenses on all my bodies.
Handling: The Nex has the viewfinder which you can tilt all the way up as well as the swivel LCD screen -these are invaluable to me when shooting since it's much easier to be stealth when you aren't looking at the subject.  The GM1 is tiny, smaller than it looks like in these pictures and I find I need the attached handle to get a solid grip on it.  Having said that, it's very easy to hold in one hand since it's so light and it's very easy to shoot with.
Focus assist: On the GM1 it is very VERY easy to zoom in for focus assist when using manual glass.  You just double tap to zoom into whatever area you want to check, it's very intuitive.  I don't have a 5R so I don't know the touchscreen functionality for focus assist.
Size and lenses: If you are looking for autofocus and small size, I don't know what beats the GM1 with the 20mm f1.7.  As you can see in the picture it's very small and compact, and I much prefer the images that come out of this than the RX100.  There are simply more lenses for M43 that are compact and autofocus than available on the Nex.  The GM1 is tiny, that's why you get it.  The Nex is also a system camera but the lenses are rather large comparatively.
Crop and image quality: Sure you get a 2x rather than a 1.5x.  I never had a problem with either you just walk back and forth a little bit.  But what was surprising to me was that looking at full sized images zoomed in there is little difference between the two bodies.  Of course the large sensor gets slightly lower noise but...in all honesty it's not like the jump from aps-c to full frame, I really don't see a difference between m43 and aps-c.
I think if it's your only camera the Nex is the better system camera since it has the viewfinder and is a bit larger of a camera.  These days though the Nex bodies are backups and I either pickup the GM1 if I am headed out and need a small camera, or the A7 if I need full frame noise quality.  I sold my RX100 once I opened up the files on my GM1, it's very good.  The GM1 with the 20mm is pretty amazing, I would very happy with it as my only camera and it's very compact.
