nx30 hype mkii
Started Jan 3, 2014 | Discussions
tjobbe
tjobbe Senior Member • Posts: 1,430
Re: nx30 hype mkii
@Taffy no, I haven't read anything about the NX30 body regards sealing as well  but it leaves room for speculating on the next model. Having said that it means that they will beef up the NX line with upcoming models.
At samsungimaging.com they refer to a new option called i-function+ that should allow to customize the buttons beyond what's currently possible.
 tjobbe's gear list:tjobbe's gear list
Samsung NX300 Samsung NX30 Samyang 35mm F1.4 AS UMC Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +18 more
jennyrae Senior Member • Posts: 2,690
Re: nx30 hype mkii
why is touchscreen negative? but no problem, touchscreen can be turned off.
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Re: nx30 hype mkii
compared to nx20 the nx300 added on sensor phase detection for a bit faster af.
so also nx30 uses it. but I mostly agree on you on the first part.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
Kaziklu Senior Member • Posts: 1,301
Re: nx30 hype mkii
RPywell wrote:
NewForce wrote:
  1. For now it ticked all upgrade boxes fo existing NX20 camera users.
I see no reason to tempt me to replace my NX20, basically the same sensor so no noticeable improvement in image quality. Good news for me as I couldn't afford to change camera this year anyway.
Must add - I see touch screen as a negative, not a positive
Have you suffered a recent blow to the head?
It has the Sensor in the NX300 so the noise is going to be better at higher ISO, and built in Phase Detection. The AF alone makes it a good upgrade.
It's not about sensor it really is about body. Some of the body changes, and the addition of a shooting mode dial is really very nice. The NX30 male organ is a meh feature for me, and the improvements to the OS are good. The big one is the Remote viewfinder.. meaning I'll finally have a wireless trigger.
Those features mean that the camera is more useable in many circumstance.
It apparently has a new Battery that is a little larger too... which is annoying.
My only significant complaint... the SD card slot placement makes it harder to make a battery grip for it.
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
tecnoworld
Re: nx30 hype mkii
Perhaps a "blow to the head" is needed to see things clearly just joking
Of course different persons could have different priorities. Some features that for one can justify a new purchase, for another one simply cannot. For me, priorities over nx300 are IQ (especially dr and high iso), af speed, buffer depth, processing performance and EVF. Till now, the NX30 for sure ticks just the last box. We'll see if it can tick others.
tjobbe
Re: nx30 hype mkii
after trying to control my NX20 by touching on the AMOLD (using the NX300 primarily since its release) I would never say that touchscreens are nonsense
In agree that the NX20 can still compete when it comes down to the IQ but the NX30 ticks all those boxes for me the previous ones left out especially when the new zooms are showing an improved AF performance the only open item would be the buffer handling (which I believe the first reviews will sure mention)
Upgrading my NX20 is more an issue of affordability as I will have to look more carefully at my available budget this year.
Especially the 16-50 pancake is tempting as travel option with the NX300, in case it delivers a reasonable IQ
RPywell Regular Member • Posts: 148
Re: nx30 hype mkii
Of course I should have made clear that for me personally I see no reason to upgrade.
I'm happy with the AF as I don't do action shots. A little improvement to the remote viewfinder would be welcome but that's not worth spending hundreds for the rare occasion I might use it. I think the larger body size is a big negative but may be a smart move on Samsung's part to attract more customers in the USA where mirrorless doesn't do so well.
As for touch screen - well, that's just the thin end of the wedge where eventually they remove as many physical buttons/switches as possible to save money. With any kind of touch screen interface (and the same with those nasty pads on laptops) it's too easy to hit the wrong thing and wonder what happened. Again just a personal thing - I have an Android phone with a physical QWERTY keyboard for the same reasons.
arbuz Senior Member • Posts: 2,247
Re: nx30 hype mkii
1. how this will hurt you? If it's there do you need to use it? Simply don't understand negative impact.
2. Every single person I know (incl. me) that tried once touch functionality to set focus at any poijnt itn the screen was deighted. It make countless pictures possible that I would not take otherwise because either there was not time to recompose after acquiring focus with central point or to move focus point with buttons.
I simply don't see how this can bother someone. It's like with camera being able to make movies - should not bother anyone but some still are. I barely understand how you people make it from file to digital not to mention from DSRL to mirrorless (EVF) But in general I agree that having NX20 I'm not sure myself to make move this year. Maybe some Black Friday deal will convince me.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
Re: nx30 hype mkii
NX30 has more pchysical controls than NX20, not less. I counted 1 useful wheel and one useless button (wifi). They also removed green button that I used rarely.
tjobbe
Re: nx30 hype mkii
arbuz wrote:
.... They also removed green button that I used rarely.
and replaced it with a function "wifi" I hardly ever used
Interesdting to see is if the new i-Function+ settings can overwrite more button function compared to now....
Re: nx30 hype mkii
I'm a grumpy old sod and easily bothered, when you get to my age you begin to realise that so many of the things that promised "progess" were more like "one step forward, two steps back".
Yeah and I've always been bothered that any kind of non professional film or video making apparatus is available to the untrained masses - it's not fair on the rest of humanity that they should waste our time with their trifling little video efforts. A photo takes a fleeting moment to look at but watching a bad video steals an appreciable amount of our valuable time.
tjobbe
Re: nx30 hype mkii
maybe one real good reason to upgrade the NX20 with the NX30 is the placement of the little wheel that changes the diopter setting for the EVF.
In the past both, my NX10/20 as well as my Nikon V1 suffered from changing it when taken out of a tighter messenger bag.
If you carefully look at the NX30 product images you will see where Samsung placed that wheel now... a real smart and welcome improvement
Hint: look at side image with  the tilting EVF
viking79
viking79 Forum Pro • Posts: 14,157
Re: nx30 hype mkii
Dave Gibbs wrote:
just curious if to sell my nx300 and just get a nx30 or wait an just buy the lens
It is targeted to those coming from the NX20, that want the enhancements of the NX300 in the form factor of the NX20.
It also one ups the NX300 in features, with a more powerful processor and tilting EVF.  I am hoping the processor upgrade comes with faster image throughput.
I would spend your money on lenses first, unless the SLR style form factor is important to you (primarily the viewfinder).
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
tecnoworld
Re: nx30 hype mkii
Eric, why do you say that it has more powerful processor? To me, it seems exactly the same drime iv engine of nx300. Where did you find the info?
Re: nx30 hype mkii
Dude again... stop comparing this to the bloody NX300... this isn't the NX300... this is the NX30... the replacement for the NX20.
The Sensor is perfectly good. The low light performance is exactly what it should be. If I can pump up to ISO 4000 shoot RAW with a fast prime (like any of the NX Primes) you should be able to shoot at 1/60 easily and get a good exposure at in the city at night.
You won't get a good exposure in a poorly lit room. You'll have to bump up to 6400 or higher or get a flash. The NX300 currently has low light performance of the original 5D. To get better low light you need to go to the D610 type camera, I held it the other night with the Nikon 85. It is super light and a pleasure to hold.
The NX400 will be the upgrade to the NX300 and it will likely have an upgraded sensor.
the NX 10/11 and 100 had the same sensor. The NX200 introduced a new Sensor, the NX20 later had a tweaked version. The NX300 introduced a new sensor, the NX30 later had a tweaked version. Thus the NX400 will likely have a new Sensor.
viking79
Re: nx30 hype mkii
The DPReview Preview, let me pull it up and look again, maybe they were referring to NX20.
The 'guts' of the camera are considerably different, with Samsung leveraging other divisions of the company. The DRIMeIV processor uses a single-core, 800Mhz Cortex-A9 processor, as well as a SGX540 GPU, which are similar to what you'd find inside a lower-end smartphone these days.
Oh, they were comparing to NX20, not NX300, sorry if I got anyone's hopes up.
If it is the same I imagine the buffer is, edit: but that wouldn't exclude a buffer upgrade either.  Have to wait for user reports
Eric
Re: nx30 hype mkii
Eric
The Galaxy NX uses the 1.6ghz 21 gigaflops version, both are the same 4000 series chip which comes in Single Dual and Quad core.. all labeled as 4 So it is possible that the NX30 or has a slightly or significantly updated chip in it.
The NX30 seems to leverage heavily from the horrid Galaxy NX. I'd be surprised if it didn't have the same basic 1.6ghz Quad core DRIMe IV chipset. I find it odd that is mentions the DRIMeIV as a 800mhz single core processor.
