What options with remote viewfinder?
Started Dec 26, 2013 | Questions
shutterbobby
shutterbobby Contributing Member • Posts: 758
Hi about to get a NX210 soon & want to use the remote viewfinder for putting the camera in a tree to get bird shots.Can i adjust the shutter speed/aperture?? very critical for what I want to do..the camera will be about 40cm from the birds.
if not are there any hacks that anyone knows of
Thanks alot
LOVE LIFE & LAUGHTER
 shutterbobby's gear list:shutterbobby's gear list
Sigma DP3 Merrill Olympus E-1 Pentax K-5 II Nikon 1 V2 Pentax K-1 +8 more
Samsung NX210
Kaziklu Senior Member • Posts: 1,301
Re: What options with remote viewfinder?
Samsungs remote viewfinder is the same Remote for all of it's Smart Camera's including the Point and Shoots. It seems because of that the WiFi mode is Smart Auto only. You have no control over anything except forcing the flash to stay off.
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
KelvinHammond Regular Member • Posts: 353
That said, Smart Mode is pretty smart most of the time. It will get your subject correct, but it may blow out the highlights to do it.  So, the bird will be right, but the clouds in the sky behind it might get blown out (depending on the scene).
I believe the newest firmware allows you to set the focus point.
 KelvinHammond's gear list:KelvinHammond's gear list
Canon EOS 6D Nikon D610 Samsung NX30 Sony a7 II Sony a7R II +17 more
shutterbobby
OP shutterbobby Contributing Member • Posts: 758
what does smart auto do? will it set a fast shutter speed,plan to use 30mm prime on it
(unknown member) Contributing Member • Posts: 947
Hi
The only control you have is flash on / off and image size in Mps. You can also download a very low res image to your tablet / phone.
I use it a lot with the NX20 on the top of a 50 ft pole and it is just satisfactory:
The image is landscape only and won't scale to the screen size, so is tiny phone sized if viewed on a 10" tablet.
The image is very laggy, up to 1 second behind time and very slow to focus / take the image, I doubt it would be suitable for any moving subject.
The app has reasonable range but much improved with a wifi booster in the circuit. I've used mine up to 300ft up in the sky with a helium balloon. Sometimes the app crashes and will require a full restart of the camera / tablet.
In summary it's poor to acceptable. My system doesn't use it any more..I mount a GoPro3 on the hotshoe and use the GoPro app which is far better and much more stable as the viewfinder. The NX20 is triggered by a wireless remote.
I'd suggest using a camera like the GoPro which has a proper app and comes with a waterproof case!
shutterbobby
Jaberwok wrote:
Hi
Hi so I wouldn't be able to see well enough when to shoot on my Ipad? I'm going after behaviour of small birds at feeders,and want to capture wing movements with more detail than my K5IiÍ & 300mm can from a distance.The go pro has only 2mp stills from what I know,which is not enough,prefer a small apsc camera if possible.
Does the triggertrap dongle/app give any more possibilities?
I have no idea if that will work. Smart Auto is okish. But doesn't always get shutter great. I almost never use it for more then group shots I'm in.
GoPro3 / 3+ is 12Mps. You really need a custom rig with no delay. I made up a rig taking the GoPro AV out to a model helicopter transmitter / receiver kit and monitoras a viewfinder and using the GoPro remote to trigger the shutter. It works well. if you want more details in how to do it then PM me.
It's not cheap to do. The whole thing cost around $800.
I find the smart auto always chooses a small aperture and slow shutter, guaranteed to blur the pics. Not much good for critical fine detail work but ok if the subject isn't moving.
