If you think you have a use for this lens...
Started Dec 23, 2013 | User reviews
Godfrey Forum Pro • Posts: 29,636
Re: If you think you have a use for this lens...
micksh6 wrote:
Godfrey wrote:
I'm going to have to borrow one of the Oly 45/1.8 lenses and compare it to the Macro-Elmarit 45/2.8 ASPH. that extra 1.2 stops of lens speed doesn't change the DoF (blur) very much,
It's 1.3 stop and I think it makes significant difference. Otherwise people wouldn't pay 3 times more money for only 2/3 stop difference (Nikon 85mm F1.4 vs F1.8 for example).
I don't have Pana 45mm F2.8 but I recently compared bokeh of Olympus 45mm and 75mm with 12-40mm at 40mm and F2.8. To me the difference is clear. Can't say for sure but Pana 45mm F2.8 probably would have similar bokeh as 12-40mm lens since it's also aspherical.
http://www.dpreview.com/forums/post/52669578
I very rarely use 45mm and 75mm lenses with smaller than F2.0 aperture. I think, photos with F2.8 just don't look as good as with F1.8.
As for topic, once I got 75mm F1.8 lens I use 45mm F1.8 only as a backup lens - for cases when 75mm is too long. Such cases don't occur very often to me, and otherwise 75mm is clearly a better lens, well deserved 5 stars. 45mm is just too different FL, and it's also a very good lens..
Thanks, but I'll make my own judgements when I test them.
dougjgreen1 Veteran Member • Posts: 4,068
I agree - but I can always easily decide which lens to take
pinnacle wrote:
dougjgreen1 wrote:
pinnacle wrote:
Just buy it. I can't really add anything that hasn't already been said. The lens excels in everything you would want it to excel in. Razor sharp. very low in optical aberrations, coma, astigmatism, and distortion. Absolutely wonderful bokeh!
If you can justify the cost based on your style of photography, get one.
I went with the Sigma 60mm f2.8, as well as an adapted used Samyang 85mm f1.4, as well as $300 remaining in my pocket awaiting some other expenditure
Each of us makes our own choices and money is often a deciding factor. I just wasn't going to make the compromise you did and give up the opportunity to own what has come to be known as arguably one of the finest camera lenses ever designed. You do have extra cash to use as you wish. You have to decide to either carry two lenses or leave one at home. If you carry just the 60, you have a slower lens with less ability to isolate subject matter if desired and minus the highly regarded bokeh of the 75. If you carry just the 85, you have a bulkier lens with an adapter and no auto aperture and no auto focus.
The 75 isn't for everyone. I am just suggesting that potential buyers think long and hard about just how amazing this lens truly is.
Dan
I have never had a situation come up where I could not determine in advance whether the Sigma 60 or the Samyang 85 was going to be better for my particular purpose. Also, from what I've seen, the Sigma is every bit as great a lens as the Olympus 75mm is. IMHO, I felt that the Olympus 75mm would be the compromise - because it was neither as light and compact as the Sigma, nor quite as good as the Samyang 85mm for isolating subject matter.
The Samyahng 85mm (in Nikon mount) also has the absolute advantage of functioning with all 3 digital systems that I ever own and use:  4/3 DSLRs,  Micro 4/3. and Nikon DSLRs.
 dougjgreen1's gear list:dougjgreen1's gear list
Olympus Stylus XZ-10 Nikon 1 V2 Olympus PEN E-P5 Olympus E-M1 Olympus E-PL7 +17 more
mujana Veteran Member • Posts: 8,420
Agree with the 5 stars.
I adapted my style of shooting, because this lens deserves it!
 mujana's gear list:mujana's gear list
Sigma DP3 Merrill Sony a7R IV Zeiss Batis 85mm F1.8 Sony FE 16-35mm F2.8 +10 more
micksh6
micksh6 Senior Member • Posts: 2,613
Re: My personal choice was different....
But Samyang 85mm F1.4 is too soft on micro 4/3 wide open, isn't it? You would have to stop it down to F2.8 in order to make it "more or less" sharp, no? Please share 1:1 crops if you think I'm wrong. I haven't seen a single sharp photo made with Samyang 85mm wider than F2.8.
As opposed to that I don't hesitate to provide 1:1 crops from 75mm F1.8 lens wide open. 1:1 crops are so sharp that people can confuse them for scaled-down full frame photos. See thread here:
http://www.dpreview.com/forums/post/50015753
http://www.dpreview.com/forums/post/50018973
You can't do that with Samyang, can you?
It always amuses me when in discussion of 75mm F1.8 lens people bring Sigma 60mm F2.8 to compare. These lenses aren't comparable. I can stop down 75mm lens to F2.8 but I won't do that, as it won't do anything good for quality. F1.8-F2.0 apertures simply allow better photos.
And you can't open Sigma wider than F2.8 to see what you actually miss. Why do you have to bring it to discussion?
 micksh6's gear list:micksh6's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +6 more
I choose not to post photos on DPreview.   But that being said, I agree that the Samyang 85mm is a bit soft (not TOO soft, just a bit soft) at f1.4.  And that softness is NOT a lack of resolution, just a lack of contrast - which can be punched up in post processing.
IMHO, it's fine at f2, which allows it to be at least as effective at isolating the subject as the 75mm f1.8.   And just because a lens is slightly soft wide open doesn't mean it can't be highly useful as a photographic tool at that aperture, especially for stuff like portraits.  S
High contrast and high sharpness is not by any means the be-all and end-all of any lens.  And if it were, the Sigma 60mm is just as sharp and contrasty as the Oly 75mm, for less than 1/3 the price.
Making a statement that you WON'T shoot the Olympus at f2.8 because you can't take as good photos with it at those settings might say much more about your limitations as a photographer than about the lenses.   I bring the Sigma lens into the discussion because it (in partnership with the Samyang 85mm) BETTER serve my particular needs than the Olympus 75mm lens would.  When I want it to be (with the Sigma) it's lighter and smaller, and I generally prefer the 60mm focal length perspective to the 75mm perspective for many needs.  My tandem can also be MORE effective at isolating the subject from the background (with the Samyang). The Samyang can also give me more pleasing portraits - the Oly, AND the Sigma, are actually both TOO sharp for optimal portraiture at any aperture, whereas the Samyang wide open is not.
I prefaced this entire discussion with the statement that it was my personal preference.  If you wish to contend that your personal preference is different, I have no issue with that.  If, on the other hand, you are positioning your view as an absolute objective statement on the superiority of YOUR preference, without allowing that yours is an opinion, just as mine is, and neither is ABSOLUTELY correct, well, only a fool would make that assertion.
micksh6
You make valid points, of course. The only thing I disagree with is that a lens can be TOO sharp. You can always make lens softer in post-processing but you can't make soft lens sharp. For portraiture with 75mm lens, if there are too many unpleasant skin details you can use software like Portrait Professional studio, which will keep eyelashes strikingly sharp but will smooth skin.
I actually never wanted to make so serious claims and to declare my opinion as an absolute truth. It's an internet discussion, sometimes it's hard to see what people are up to.
Again, I simply disagree
In this era of pixel peeping, IMHO, people over-obsess about sharpness.  Generally, sharpness is an asset, but not always, and I frankly prefer to be able to control it PRIOR to post-processing during composition.  In any case, the Sigma 60mm lens is just as sharp as the Olympus 75mm.  The Samyang is softer wide-open, but sharpens up noticeably at f2.
Agree.....a lens can never be too sharp. Even with portraits I like sharpness and seeing every skin detail. Except when artifacts or other "nastiness" show up ofcourse (but that's mostly the possible case in extreme PP).
MrScorpio
MrScorpio Senior Member • Posts: 1,440
Hi
It is of course a matter of personal taste, but how can a lens be TOO sharp? Even for portraits?
IMO the eyes should always be tack sharp, and the skin texture handled by adjusting the light source.
thats my opinion since I think the 75/1.8 is truly excellent for portraits.
 MrScorpio's gear list:MrScorpio's gear list
Sony a7R II Sony FE 24-240mm F3.5-6.3 OSS Sony FE 85mm F1.4 GM
