Extension tubes
Started Dec 22, 2013 | Questions
frangulis Forum Member • Posts: 72
Extension tubes
Hello everybody,
I want to experiment with extenion tubes to shoot macro with my 17 mm 1.8 , 45mm 1.8 , 40-150 mm and other lenses. Searching the options I found:
Kenko    2 ring set    10 + 16 mm    190,-
kooka     3 ring set   10 + 16 + 21 mm    aluminum or chrome    110,- /130,-
Caruba   3 ring set   10 + 16 + 21 mm     aluminum or chrome      90,- /110,-
Does anyone have experience with any of these brands c.q. which would be the best buy?
advice appreciated,
Steven
 frangulis's gear list:frangulis's gear list
Olympus PEN E-PL6 Olympus PEN E-P5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 17mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 +6 more
John Carb Forum Member • Posts: 51
Re: Extension tubes
I have not used any of those. I've heard the Kenko ones are great but they are very pricey. I assume you want tubes that have electrical contacts so the lens can still communicate with the camera and you can use auto focus? I do know many people on here are using very cheap non-electronic tubes and manual focus to get amazing shots. Many will argue manual focus is the way to go for macro anyway. That being said, I bought Meike tubes off of amazon a while ago and they have electronic contacts and auto focus, etc. and they are cheaper than your options listed. I would ceck them out as well as the Foga ones. The plastic construction doesn bother me, I still think they are decent quality and worth the price.
Check out this thread:
http://www.dpreview.com/forums/thread/3475095
Fredrik Glckner Veteran Member • Posts: 3,750
Re: Extension tubes
I have used the ones from Meike/Neewer/Skyblue:
http://m43photo.blogspot.com/2013/07/meike-macro-rings-highly-recommended.html
They are 10+16mm, and cost around US$40.
They work fine, and are easy to use. Some complain that the inside of the rings is too glossy, and can cause lack of contrast. I think that is a highly exaggerated issue. If you are worried about it, I guess one could matte the surface down with sanding paper, not while mounted to the camera, of course.
(unknown member) Senior Member • Posts: 1,001
Re: Extension tubes
I'm using the ones from Fotga, about 40 euros on ebay from a seller called estores. Partly plastic so probably not as sturdy as the Kenko's, but they work well.
Robiro Veteran Member • Posts: 6,808
Practical examples
frangulis wrote:
Hello everybody,
advice appreciated,
Have a look:
http://www.dpreview.com/forums/post/52702182
http://www.dpreview.com/forums/post/52733923
http://www.dpreview.com/forums/post/52172204
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Olympus 40-150mm F2.8 Pro Olympus 100-400mm F5.0-6.3 IS Panasonic 12-35mm F2.8 Sigma 30mm F1.4 for Micro Four Thirds
dw113 Junior Member • Posts: 38
Re: Extension tubes
Just received a 16mm + 10mm set of Vello extension tubes.  $49.99!!!  Not a steep investment to explore the world of macro photography.
dw
 dw113's gear list:dw113's gear list
Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G 20mm F1.7 ASPH Sigma 19mm F2.8 EX DN Sigma 30mm F2.8 EX DN Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +5 more
CrisPhoto
CrisPhoto Senior Member • Posts: 1,749
Re: Extension tubes
I bought the very cheap Meike rings and would not buy them again.
Why?
They have horrible inner reflections because the surface is not anti-reflective at all. Very bad design.
Here is the thread with some example pictures:
http://www.dpreview.com/forums/post/51893286
I would strongly suggest buying rings with anti-reflective structured inner surface.
OM-D + Sam7.5, PL25, O60, O75
P12-35, O75-300
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 40-150mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 100-400mm F4.0-6.3 ASPH +9 more
jalywol
jalywol Forum Pro • Posts: 11,069
Re: Extension tubes
I got the Fotga ones (about $55 USD).  I have been having a huge amount of fun with them.  They do have ribbing on the interior walls of the tubes, so I think they reflect less (I have not had any problems with image degradation due to reflected light with them).  They are plastic with metal mounts, so I don't think they will stand up to heavy use, but they work fine for everything I have thrown at them so far (including using them with the 100-300mm lens).
-J
Some shots with them:
Tony Rogers Senior Member • Posts: 2,024
Re: Extension tubes
I have a set of the Kenko rings and they work very well, The mounts are good and everything still works when you use them. I use them with my 100-300 (10mm + 16mm gives about 25% increase in magnification at 300mm) and 45-175. Both are fine.
I have no idea why they cost so much money though...
 Tony Rogers's gear list:Tony Rogers's gear list
Olympus E-M1 II Sony FE 200-600 F5.6-6.3 Sony FE 85mm F1.8 Olympus 12-40mm F2.8 Pro Sony FE 50mm F1.8
lester11
lester11 Contributing Member • Posts: 577
Re: Extension tubes
Some comments on Fotga (and similar aluminium material rings)
http://www.dpreview.com/forums/post/52517733
Lester
 lester11's gear list:lester11's gear list
Olympus E-M5 II Olympus OM-D E-M1X Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 7-14mm F2.8 Pro Panasonic Leica 100-400mm F4.0-6.3 ASPH +10 more
OP frangulis Forum Member • Posts: 72
Re: Extension tubes
Thank you all for your helpfull feed back.
I cannot find any of the real cheepos here, but I think I will gor fo this set
http://www.cameranu.nl/nl/objectieven/tussenringen/kooka/kooka-extension-tube-set-olympus-micro-4-3-serie-chroom/h138_36324_368274
from kooka optics
http://www.kooka-optics.com/products/list-136.html
a three ring set with chrome setting for 130 Euro's.
Happy Christmas
Steven
