Pentax smc DA* 50-135mm SDM Issue
Started Dec 21, 2013 | Discussions
awaldram
awaldram Forum Pro • Posts: 13,271
Re: Pentax smc DA* 50-135mm SDM Issue
I'm of similar opinion to you, I don't take as read that a lens is superior because it has an OEM brand name on.
Many Sigma lens a clearly superior to their OEM brethren especially when they (Sigma) are attacking a market segment, HSM is an example of this where the technology is every bit as functional as Canons USM implementations.
Whereas SDM is IMO not technically very clever if the objective is fast silent focusing but I suspect those were not the design constraints rather suspect they wanted three way focus at all costs.
Those blinkered to OEM only are missing some of the best lens in production.
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Olympus PEN E-PM2 Pentax Q7 Pentax K-3 +17 more
DAVID MANZE Veteran Member • Posts: 6,390
Re: Same old explanations
awaldram wrote:
As you asked where I got ny evidence that failure rates had normalized for SDM inc the 16-50 and 50-135.
Here are the stats form PF for 2011 (the only year with enough numbers)
percentage chance of failure worst to best
17-70 26%
16-50 23%
55 8%
300 8%
50-135 8 %
60-250 2%
200 0%
18-135 0%
I see no evidence to back up your claim on the frailties of the 16-50 and 50-135 as compared to the rest.
Could you post your evidence ?
You complain same old explanations but unless the facts change how can the conclusion?
I'm not a bif fan of Pentax's ultrasonic implementation and believe there was a lot cleaner ways to do it if you dropped backward compatibility, yet the accusations ledged against it I find unfounded and always without evidence.
For every member screaming from the rafters about their failed SDM there are 10 users quietly taking pictures with theirs.!
-- I see nothing from these statistics which underline the reliability of Pentax's SDM, a good figure from a manufacturer should be around 1-5%, 8% shows a problem, above 20% is "inexcusable". Are you seriously putting these figures forward as proof of reliability? You cite 1 in ten as a good figure?
Anyway,the problem has been fixed now, but unfortunately Pentax refuses to give any serial numbers to differentiate between the change in SDM motors and as old stocks remain, there's no way of knowing whether you've bought an early or recent motor.
PS. Statistics showing zero% just show insufficient statistics.
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Nikon D750 Nikon D500 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 28mm f/2.8D +17 more
jamesm007 Veteran Member • Posts: 5,820
Demoguy wrote:
On Tuesday I went to Everett Wa. to look at a possible project. The Nimitz, CVA 68 is back from a long deployment so I thought I would stop along the waterfront and take some photos. I pulled out my camera (k-3) with the DA* 50-135 on it and lo and behold, no auto focus. I bought this lens last year on black Friday, so its three weeks out of warranty. Anyway it was @ 29 deg F so I ended up using manual focus and with my bad eyes the result was not so good. Today I mounted the lens on my K-5 and nothing happened, then on the K-01 and it woke up. Tried it on all the other cameras and it worked fine. I wonder if it was just cold or if this is a sign of SDM failure.
Has anyone had this lens fixed at CRIS recently and would you have a cost?
Thanks,
Joe
Because its a known issue of some sort I would call and ask for some good will from Pentax. In any case I believe the cost I have seen to repair, although not cheap would be made back if you ever sold it. Also considering it is a great lens you will still be ahead if you pay the repair cost (should be under $270?). You also have other no cost ways of restoring AF written above.
You may want to just send it in for a cost and state on the letter how close out of warranty it is. When you call and speak to someone they don't have the power to say, "no charge". They are office phone... When being repaired they can make it a no charge more easily. But there would be a small fee for shipping back to you if not repaired.
But again as I have written over and over. Pentax needs to get rid of this issue. It has to keep some would be Pentax buyers away from Pentax you would think. Pentax only needs to change a few lens. Why not coat the DA* lens with the HD coating, give it a bit faster motor (just a bit) and call it DA*II series of lens. Buyers would know the SDM issue is gone on those models.
Just the very fact we are even writing about it shows a demon real or not called SDM AF failure is still with Pentax.
But! I do want to make sure all know every manufacture of photo gear has at least one demon, most more. I am only trying to help Pentax and the OP.
 jamesm007's gear list:jamesm007's gear list
Pentax K20D Pentax K-5 Pentax K-3 Sigma 10-20mm F4-5.6 EX DC HSM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +12 more
KentG Veteran Member • Posts: 4,825
I agree. One of the lenses in my Canon system is a Tokina AT-X 300/2.8 SD AF. A very well regarded lens by Photodo. Yes it doesn't have IS and it doesn't have USM or HSM. On the other hand it only cost me $700. Where else can you buy a sharp 300/2.8 AF lens for that price? Even the pre-IS Canon 300/2.8 lenses cost twice as much used. Heck I could have paid that much for a Tamron AD-2 300/2.8 manual lens.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-3 II Pentax K-1 Canon EOS 80D Pentax smc DA 16-45mm F4 ED AL Sigma 120-300mm F2.8 EX DG HSM +7 more
emem
emem Veteran Member • Posts: 4,430
Thanks,
Joe
Very astute observation James. My 50-135 failed some months back (AF as dead as the extinct Dodo) and I have just dropped it off at the hospital over the holidays. That lens would barely have been on my cameras for more than 100 shots. To all intents and purposes brand new. I've also heard the cost to repair this SDM failure can be as much as $300 or more, yes? It makes it a very expensive lens instead of just an expensive lens - around $1200 new plus $300 for repairs? A hidden cost is also that because of the reluctance of people to buy used SDM lenses, their resale value is less than it should be.
On a related topic, I know there is a method linked to on other forums to convert a lens from SDM to screw drive. I have read and reread these instructions but find some of the steps difficult to follow and understand. Has anyone who has successfully interpreted the instructions re-written them in a clearer way?
Mike McEnaney. (emem)
www.veritasmea.com
 emem's gear list:emem's gear list
Pentax *ist DS Pentax K10D Pentax K20D Nikon D300S Pentax K-5 IIs +12 more
solarider
solarider Veteran Member • Posts: 4,930
I would suggest a direct paper certified mail letter to the new(ish) head guy of Pentax in Denver, Colorado, anyone remember his name? He may be more likely to extend your repair period than someone at pentax repair in the event pentax repair says no.
Thanks,
Joe
The intuitive mind is a sacred gift, the rational mind is a faithful servant.
We have created a society that honors the servant and has forgotten the gift. - Albert Einstein
________________
Science... became Scientism, which means it didn't just pursue its own truths, it aggressively denied that there were any other truths at all... Ken Wilbur
__________
Coincidence is God's way of remaining anonymous - Albert Einstein
_______________
My work consists of two parts: the one presented here plus all that I have not written. And it is precisely this second part that is the important one - Ludwig Wittgenstein
"On a related topic, I know there is a method linked to on other forums to convert a lens from SDM to screw drive. I have read and reread these instructions but find some of the steps difficult to follow and understand. Has anyone who has successfully interpreted the instructions re-written them in a clearer way?"
I would strongly advice all non hard core computer programmers or engineers to not(!) try the method at Pentax Foru... its wiping out parts of your cameras firmware and re-writing it with other values. Even backing it up is a dangerous procedure.
The number one rule is to follow directions to the letter. But if your not 100% sure, positive, just don't do it.
I just read the way its done. I thought the method was to cover lens contact pins. That's one thing. To reprogram your firmware in a fashion as this is dangerous. Do you know why the directions say use notepad and not Microsoft word? If not just don't do it. You can use other text editors. But only certain ones, why? If you don't know why don't do it.
I feel for those with SDM that don't work. Go back and read my posts when I went to the store before SDM was an issue and the DA*50-135mm auto-focus would not work at the camera shop! The lens had been sitting on the shelf for a long time. I tried it, was going to get it and then everyone's DA*50-135mm lens (a lot) started to act up all around the same period of time. Its all written down.
Cane Veteran Member • Posts: 6,900
c57d wrote:
Do a Google search on: "How to deactivate SDM and allow for screw drive autofocus"
The first hit should be on the Pentax Forums page.
It tells how to use an older camera to read the lens firmware, make a change and write it back to the lens so that it always uses screw drive. I did it to my 50-135 and now I have a working lens again without having to send it in for a repair that may fail again down the road.
Have to strongly agree with Chris on this one. I deactivated 2 of my SDM lenses (DA* 16-50 and DA* 50-135). Pair it with K-3 and I never looked back on SDM anymore. I think screw drive focusing is faster with K-3 now compare to my old K-7 and K10D.
Cheers
Suwandi Chandra Photography
It is pretty sad that you have to spend that much on a lens, then have to hack up the lens yourself to end up with a loud screw drive at the end of the day. Can you imagine Canikon owners needing to do this?
-Hi,
The whole SDM story is a veiled and disappointing one, firstly, OK, any manufacturer can design a system which turns out over a period of time to be "unreliable" , normally the follow on is a redesign which cures the problem and this is what happened eventually, only many years went by before they addressed themselves to the problem. These lenses are batch produced and many thousands were manufactured and stocked for sale appropriately.
What to do with these lenses after it became apparent that in fact there was a problem with the SDM system? Take them out of the warehouse and rebuild them with the new replacement motor? No, that would have cost a fortune and would have resulted in a tremendous financial loss, what to do then? Answer nothing at all, admit to a problem? well not out loud.
So they decided to say "nothing" (excepting an unofficial mutter at I think, Photokina ) knowing that the majority of the lenses would likely at least last out the one years guarantee (although many didn't) and thereafter have the customer pay for the repair. So from having a potential situation of facing a complete motor change of all their SDM lens stock and all the losses that would entail they stood back and let the customer pay.
What is the situation now?  Well the new motors are there, but there's still plenty of the old motor stock about for sale and Pentax hasn't released any serial numbers to indicate the changes, so you buy in the dark.
Dave's clichés
awaldram
I thin your seeing 2+2 and making 5
your theorem is based on SDM lasting the 12 months warranty period .!
Yet in 90% of the world Pentax lens come with 2 years warranty and on top of that through most of Europe will have a consumer protection for design failure in the 6 year region.
So why would Pentax keep quite on a ticking bomb when in most of the world it is themselves who will foot the bill and get hit with bad publicity to boot.?
On your 'new motors' again I see no evidence accept from the same discredited third party source in Germany.
I would consider it a lot more likely that failures are not that great and though earlier ones are more likely to fail (probably due to manufacturing tolerances) Pentax decided that FoF (Fix on Fail) was cost effective for all units sold.
My 50-135 was replaced by Pentax UK after 4 year free of charge and the motor is identical to the original, the revision status of  the Motherboard was newer but I can't remember now what its markings were.
So we have
2008 purchased 50-135
2010 first reports about new motors
2012 2nd rumour about new motors reported
late 2012 50-135 replaced directly by Pentax UK (not repairers) motor is identical unit as 2008 original.
The 50-135 I received was not a new unit but a factory refurb being the unit all UK reviews are based on (i.e demo stock) so would have all mec releases fitted.
Rolo King Regular Member • Posts: 121
You Could Most Probably Rule Out Cold
I have a 50-135 that will be 3 years old. It's been used in snow blizzards and temperatures down to -20 (if not less). It's still working although focusing is as slow as it ever was.
 Rolo King's gear list:Rolo King's gear list
Panasonic Lumix DMC-ZS7 Nikon D90 Pentax K10D Pentax K20D Pentax K-5
Bonn Regular Member • Posts: 119
Its time Ricoh consider putting the option in the camera firmware for activating the screw drive if the SDM fails. Its so weird that they install the screw drive together with the SDM for the DA* lenses but do not allow it to be used. Its like paying for something but can't use it. Simply does not make any sense.
---- What can't me measured cannot be managed ---
 Bonn's gear list:Bonn's gear list
Panasonic FZ1000 Pentax K-3 Sony a7 III Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +8 more
soheil Veteran Member • Posts: 3,025
Agreed
It would be a very useful option.
Soheil
It's the singer not the song.
 soheil's gear list:soheil's gear list
Pentax Optio 330GS Pentax MX-1 Pentax K-7 Pentax K-5 Pentax K-5 IIs +19 more
awaldram
From a Japanese viewpoint it makes perfect sense.
Whereas you or I may see addition of a screw option a choice and hence a good thing, I think Pentax see it as an admition of failure and given Japanese culture will never happen.
I would have released it as a cost option and use PR to dress it up 'We don't want our users reverting to screw but understand there is a wish amongst some of our customers we therefore release a custom firmware at £xx to cater to their wishes. (Whilst 3 way lens are in production)"
