Finding the 70-200mm a bit cramped after moving to full frame
Started Dec 6, 2013 | Discussions
1trev27 New Member • Posts: 20
I'm finding my 70-200mm F4 L IS a bit cramped on the 5D MkIII. It's a significantly different beast on full frame than on crop. Just wondering what people thought of the 70-300L on full frame? I've gone through so many threads that my head is spinning  Worthy upgrade or would one be better of saving for a 2.8 with a TC?
I could do that but just worried about the added bulk of that beastie - not to mention that I don't like the idea of pointing a large lens like that around. Primarily shooting landscapes, nightscapes (on tripod), street photography, and some portraits. Probably 40% of my shots have been with the 70-200mm but I have quite often missed that extra reach the crop gave. Have not been able to check the big lens out as none of the dealers on this side of the country stock anything above the F4 variants but I will be in NYC this Christmas and may upgrade then. Would love to hear your thoughts. Does it really seem that much bigger and heavier when kept in a sling most of the time?
Will be a shame to let it go though. Turned out to be a nice combo for some deep sky stuff on my 7D. But then again the low light performance of the MkIII could me the 70-300 perform just as well or better. Here's a couple from the older non-is F4.
T
M31 - Andromeda
M45 - The Pleiades
 1trev27's gear list:1trev27's gear list
Canon EOS 5D Mark III Canon EOS M5 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM +7 more
Canon EF 70-200mm F4L IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon EOS 5D Canon EOS 7D
CameraCarl Veteran Member • Posts: 9,204
Re: Finding the 70-200mm a bit cramped after moving to full frame
I liked my 70-300 IS L lens on my full frame and 1.3x 1D Mark III/IV so much that I sold my 70-200 f2.8 IS. But I don't do much portrait photography and my days of shooting indoor sports are over, so I never used the f2.8 any more.  The optics and improved IS of the 70-300 sold me on the change.
OP 1trev27 New Member • Posts: 20
Many thanks for the reply Carl. Just the input I was looking for.
I've been leaning more in that direction than the 2.8 after reading up some. Plus if I need a wee bit more reach I could always have the 7d along with me as well. Will probably just hang on to the 85mm for the occasional portrait.
Always good to be able to lighten the camera bag a bit.
Thanks again
Trev
Lee Jay Forum Pro • Posts: 56,673
Get a 1.4x TC III.  Problem solved.
Lee Jay
 Lee Jay's gear list:Lee Jay's gear list
Canon PowerShot SX50 HS Canon EOS 7D Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM Canon Extender EF 2x III +10 more
wazu
wazu Senior Member • Posts: 1,408
The better solution is to upgrade to the 70-200/2.8 and then add the 1.4x TC III. Way better than 70-300L. IMO.
There is a crack in everything That's how the light gets in. - Leonard Cohen
stratobill Senior Member • Posts: 2,081
That's the first time I've heard that. It may be better, but way better? I doubt it.
The 70-300L works great for me, the added reach over my previous 70-200F4IS is welcome, and it has very similar IQ. Just a bit slower is all.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
ed rader Veteran Member • Posts: 9,068
also sold my f4 IS for the 70-300L IS.  perfect for close in wildlife and longer landscapes.
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
Many thanks for all the input guys. I think I'm leaning towards the 70-300 L . If I need speed in a telephoto I can always grab a 135 F2 in the future and a 1.4x TC - an option I hadn't thought of before.
Going to try both lenses (70-300 & 70-200 2.8 II) in B&H when I'm there in a couple of weeks.
T
Rock and Rollei Senior Member • Posts: 2,916
+1. Great lens thought the f4 IS is, I find the 70-300 L just so much more useful.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
wazu
speed and versatility, the only advantsge to the 70-300L is size/weight and an extra 20mm at the long end.
with the 70-200/2.8 + 1.4 you get a 70-200/2,8 a 100-280/4 or add a 2xTC and get 140-400/5.6 (same speed as the 70-300 but with 100mm more reach) what's not way better?
tonyjr
tonyjr Veteran Member • Posts: 5,295
Yes , FF is not long enough , but is wide enough . It just costs a lot more to go wide or long on FF .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
I have not tried that combination, but the usual questions about a TC combo would be: slower focusing, reduced IQ, more unwieldy operation, and heavier weight.
You may say that none of those are a problem, and you might be right. As I say, I have not tried that combo. And you are right, there is a lot to like about it.
But I will stick to my original statement that "way better" than an integrated lens is a bit suspect, that's all. Many would prefer the single lens for a lot of reasons.
I use that system, after using the non-L 70-300, and "way better" is an understatement.  Just the ability to go to f/2.8 is really great, not to mention the longer focal length of 400mm.
Lee Jay
Pultzar Senior Member • Posts: 1,529
Have you compared cropping your 70-200 FF images to the same as your are on a crop?  You may lose some detail but the noise level should be similar since you are capturing the same amount of light in both cases.
MirekE
MirekE Contributing Member • Posts: 925
I would suggest that you give it some time and see if you can readjust your thinking to the new FOV. It worked for me.
(unknown member) Senior Member • Posts: 1,144
This is really intriguing.  Has anyone actually conducted tests?  I have the 70-300L and 70-200 L II with a 2x TC ( the III version). I love my 70-300L, I love my 70-200L II w/out TC, but I have not been impressed with the 70-200 + TC. However I haven't conducted tests that directly compare them.
Perhaps, that's something I can do this weekend if the weather holds up.
