Autumn colors in the Smokies...
Started Dec 5, 2013 | Photos
Lucy Forum Pro • Posts: 31,166
Visited the Smokies in Tennessee a couple of weeks ago and the colors were spectacular. Here are a few samplings from my gallery:
The colors:
http://www.pbase.com/image/153642104/original.jpg
Saw Bears in Cades Cove:
http://www.pbase.com/image/1536421008/original.jpg
And some deer (or are they elk)?
http://www.pbase.com/image/153642118/original.jpg
Waterfall:
http://www.pbase.com/image/153642130/original.jpg
More colors:
http://www.pbase.com/image/153642143/original.jpg
For my gallery, see: http://www.pbase.com/lucy/townsend_tn_2013
Thanks for looking....all were taken with the SX40 HS.
Lucy
Oly cams and a Canon, too.
FCAS Member #98, Oly Division
'Photography is the art of seeing what others do not.'
http://www.pbase.com/image/56509403/small.jpg
 Lucy's gear list:Lucy's gear list
Olympus XZ-1
Comment & critique:
Canon PowerShot SX40 HS
OP Lucy Forum Pro • Posts: 31,166
Sorry, I seem to have forgotten how to enter the photos....
That's what I get for being inactive too long.
Lucy
Olympus XZ-1
Re: Autumn colors in the Smokies...the photos!
The colors:
http://www.pbase.com/lucy/image/153642104/original.jpg
http://www.pbase.com/lucy/image/1536421008/original.jpg
http://www.pbase.com/lucy/image/153642118/original.jpg
Waterfall:
http://www.pbase.com/lucy/image/153642130/original.jpg
More colors:
http://www.pbase.com/lucy/image/153642143/original.jpg
I think this should work....I wish they still had a 'preview' button...if this doesn't work, I'll give up for now....thanks!
Lucy
Lucy
Olympus XZ-1
Re: one more try
http://www.pbase.com/lucy/image/153642151.jpg
Lucy
Olympus XZ-1
VisionLight
VisionLight Veteran Member • Posts: 6,227
Lucy, here's some temporary help
The colors:
Waterfall:
More colors:
The colors
Saw Bears in Cades Cove. Note, Lucy, that your link to this picture above does not work. It has an extra "0" before the 8.
And some Deer (or are they Elk?)
Waterfall
More Colors
 VisionLight's gear list:VisionLight's gear list
Samsung NX1 Canon EOS M5 Sony a7R IV Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 100mm f/2.8 Macro USM +15 more
(unknown member) Veteran Member • Posts: 3,073
Lucy,
I just used the link to your gallery   Thanks for sharing your trip--nice autumn shots.
Murry
HOw did you do that, visionlight?
I posted like I used to some time ago by entering the url myself but I forgot to enter "/lucy" so I tried adding that but it still did not work.  Then I tried to copy and paste the url from my pbase site....but this didn't work either.  I tried searching the site for info about posting images and couldn't find anything.  Dpreview used to have an 'edit' option and also a 'preview' option beneath the message, now neither of these are available.
Sorry to be such a dummy, but things have apparently changed a lot since I was here last.  Can you tell me where to look for this info?    Thanks so very much.
Lucy
Olympus XZ-1
VisionLight
Re: HOw did you do that, visionlight?
Here is your original link to the first image:
When copying it to the reply edit field, an icon popped up that gives you the choice to imbed the image in the post. I clicked on that icon, chose to imbed, and the image showed up as seen above. This was fairly easy since you had already provided the links.
The normal way to do it would be to use the "insert image" icon above the edit field on the Icon Bar. It's the last one. From the drop down options, choose "insert image from web" and enter the link. Hit Enter and the image downloads as seen below:
Hope this helps.
Ed
Lucy,
When you create or reply to a thread there is a task bar at the top (right below the subject line) that has a small picture frame.  If you click on that it will give you three options for posting your photos--form your computer, from your web site or from your DPReviw gallery.  They have made it pretty simple now.
Murry
Thanks Visionlight....and all...
I will try again...
Scene at the Townsend Visitor Center.
Now I see where you imbed the image.  I hadn't noticed that ribbon at the top.
That's what happens when you stay away for a while....everything changes!  lol   To me it was simple the old way....but that's just me.  Thanks again.   (I still wish they had a preview pane) lol
Lucy
Olympus XZ-1
omerko Junior Member • Posts: 45
Hi Lucy
I like the waterfall pic the most, very nice frame and angle.
Though I would try to get a bit more of the top, maybe by using a wider lens or by trying to get a lower angle (not sure that's possible here).
I would try a longer exposure as well, this is a perfect frame for that!
bluewater1
bluewater1 Regular Member • Posts: 270
Nice shots.
