Great all around
Started Dec 5, 2013 | User reviews
Bobsweet50 New Member • Posts: 15
Great all around
I have owned the 18-135mm STM lens for about 6 months now.  Having said that, I feel it is one of the best Canon non "L" lenses on the market.  It is quiet, fast, sharp as a tack and one I leave on my 7-D all the time.  It is excellent for younger children's athletic events - have a comfortable equivalent range of 29-200mm.
The only downside which I have realized is that when you attempt to manually focus, the lens does not do so, it's almost like a dummy switch when I try to use it.  The other minor inconvenience is that when the lens "sleeps", it takes a second or so to wake up and focus accurately again.
Overall - I would recommend this lens without reservation for any crop sensor Canon.
Canon EF-S 18-135mm F3.5-5.6 IS STM
Telephoto zoom lens • Canon EF-S • 6097B002
Announced: Jun 8, 2012
Bobsweet50's score
5.0
Average community score
4.8
Akilia50 New Member • Posts: 16
Re: Great all around
Lens switched to AF overrides MF.
There isn't MF adjustment in AF mode.
To manually focus using the MF ring:
a) have the lens switch set to MF mode
b) have the camera switched on
There is no resistance felt when focussing, nor infinity stop.
The mind's eye has an aperture range spanning orders of magnitude, and a focal length strongly influenced by preconception, combined with vast though apparently volatile memory storage media prone to fallacious error-correction routines.
 Akilia50's gear list:Akilia50's gear list
Canon EOS 70D Canon EF-S 10-22mm F3.5-4.5 USM Canon MP-E 65mm f/2.5 1-5x Macro Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF 100-400mm F4.5-5.6L IS II
quiquae Senior Member • Posts: 2,265
Sure there is. The AF has to be active, though. Half-press the shutter button (or press the rear AF-ON button) and then turn the focus ring.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
msowsun
msowsun Contributing Member • Posts: 740
If the camera is set to AI Servo AF then it will be impossible to do manual focus over ride.
Switch to One Shot AF and then you will be able to manually focus.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
