Fix for Panasonic 20mm Banding in Post
Started Dec 5, 2013 | Discussions
uberjer
uberjer Junior Member • Posts: 37
Hi all,
I've scoured the net looking for ways to fix the banding issue when using a Panasonic 20mm f/1.7 lens on an Olympus body.
I tried Topaz Labs' DeNoise and Nik Software's Dfine 2.0.
DeNoise: It's easy to find the banding settings in DeNoise, but no matter what I set them to, I couldn't remove the banding completely.  Furthermore, I didn't want to do noise reduction.  I just wanted to eliminate the banding.  DeNoise does not provide the necessary flexibility to solely address the banding problem.
Dfine 2.0: You can target the adjustment to just the banding issue, but the option is buried.  When in Dfine, select the "Reduce" tab, then expand the somewhat hidden area by clicking the "More" link. From within the Reduce->More area, you can turn on the option for Debanding.  You can also fine tune just how much the debanding is applied.
Summary: Use Dfine 2.0 and find the Debanding feature.  You can strictly target banding without denoising the image.
If anyone has any better methods to just perform debanding, please let me/us know!
Jeremy
 uberjer's gear list:uberjer's gear list
Nikon D800 Olympus PEN E-PL5 Olympus PEN E-PM2 Nikon AF-S Nikkor 14-24mm f/2.8G ED Panasonic Lumix G Fisheye 8mm F3.5 +11 more
Nik Dfine Panasonic 20mm F1.7 II Panasonic Lumix G 20mm F1.7 ASPH Topaz DeNoise
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,433
Re: Fix for Panasonic 20mm Banding in Post
Yes, Dfine is surprisingly good with banding.  It hasn't been updated in ages, it seems like anyway, but it's still what I use for problem noise.  Though, the debanding can easily be overdone with adverse effects, but one just has to be on the lookout for that potential.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
