Olympus 75mm lens and close-up filter for macros?
Started Dec 3, 2013 | Questions
Lab D Veteran Member • Posts: 6,938
Has anyone tried the Olympus 75mm F/1.8 lens with a close-up filter for macro pictures?  I am considering getting the 75mm lens and want to use it for multiple situations.  With it being so sharp and with a very good macro filter, will it be useful for pictures of small flowers and such?
 Lab D's gear list:Lab D's gear list
Panasonic FZ1000 Nikon D600 Panasonic Lumix DMC-GH4
CrisPhoto
CrisPhoto Senior Member • Posts: 1,749
Re: Olympus 75mm lens and close-up filter for macros?
Yes, here my report:
http://www.dpreview.com/forums/thread/3522091
In short: The 75mm is a very good lens,
but not a very good macro lens
OM-D + Sam7.5, PL25, O60, O75
P12-35, O75-300
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
MAubrey
MAubrey Senior Member • Posts: 1,600
I've used it with a Marumi 330 Achromat. It only bring the magnification up to about x.4, but its absolutely brilliant.
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony a7 Voigtlander 35mm F1.2 Nokton Olympus M.Zuiko Digital ED 75mm F1.8 +2 more
Jim Salvas
Jim Salvas Veteran Member • Posts: 5,671
I don't have the answer to your question, but you've got me thinking about adding a quality closeup filter to the 20-40, which already starts with a .3x magnification.
Closeup filters, being of simple construction, lose little on a quality lens. Where they fall down is on flatness of field, which isn't much of a problem in most cases.
Jim Salvas
 Jim Salvas's gear list:Jim Salvas's gear list
Olympus PEN E-PM2 Olympus E-M1 Olympus PEN-F Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +11 more
Zensu11
Zensu11 Senior Member • Posts: 1,542
I've thought of the same but I wonder because the close focusing on the 12-40 zoom is outstanding at all focal lengths but you are also just inches away from the front element of your lens and I wonder how well this would work. Please keep us updated if you try this out.
LincolnB Veteran Member • Posts: 4,390
Consider an extender instead
You can get an active extender for not much money. Guaranteed no added optical distortion, all it will do is alter the min/max focus distances. Something like this:
http://www.amazon.com/FOTGA-automatic-extension-Olympus-panasonic/dp/B00CANGBIK/ref=sr_1_3?s=photo&ie=UTF8&qid=1386093928&sr=1-3&keywords=micro+four+thirds+extension
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Sony a7 II Sony a7 III +8 more
Punda
Punda Regular Member • Posts: 224
I have a 75-300 with raynox 250 lens, good quality!
http://www.flickr.com/photos/51197209@N03/11139147664/
Greetings,
Iroon
Gear: E-pl5, 14-42, 45, 75-300
 Punda's gear list:Punda's gear list
Sony a7 III Canon EF 300mm f/4.0L IS USM Canon EF 17-40mm f/4.0L USM Sony FE 85mm F1.8
DaveEM1 Junior Member • Posts: 40
Re: Consider an extender instead
I have a 60mm macro lens and want even higher magnification. How much magnification would it add? It depends on the focal length of the attached lens and i see this is 26mm total extension.
thanks
fluberman Regular Member • Posts: 115
I did, but I prefer using a dedicated macro lens...
Here you can see a water droplet, taken with the 75mm and Raynox 250
http://www.flickr.com/photos/flubie/8529100682/
 fluberman's gear list:fluberman's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-GM1 Olympus OM-D E-M10 Olympus E-1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +12 more
thanks
No idea. Somebody somewhere probably has a calculator for that sort of thing.
thanks
I found an on-line calculator that suggests a 26mm tube extender will increase the max magnification of the Olympus 60mm from 1:1 to 1:1.27
http://www.flybacon.com/Cameras/Macro.aspx
LincolnB wrote:
thanks
... although I found another formula that suggests it would be 1.43
"Magnification gained = # of mm of tubes used / focal length"
UnderDriven
UnderDriven Senior Member • Posts: 1,089
I'm surprised at the contrast issue with extension rings. I don't think that is normal...
Close-up lenses are problematic, unless they are designed for the lens. The results might be fine, or not so good. My Sony R1 has a dedicated close-up lens which works very well, but putting it on another lens may not work well at all...
Have you tried reverse-mounting another lens on the 75mm?
“The world is going to pieces and people like Adams and Weston are photographing rocks!” --Henri Cartier-Bresson
 UnderDriven's gear list:UnderDriven's gear list
Sony Cyber-shot DSC-R1 Panasonic Lumix DMC-G1 Sigma SD14 Sony SLT-A55 Sony SLT-A57 +9 more
Jim Salvas
I love the fact that there are so many ways to go macro. A true macro lens. Closeup filters on a standard lens. Extension tubes. Bellows with a standard lens. Bellows with an enlarging lens (really high quality and magnifications). Reverse ring with a single lens. Reversing one lens on the front of another. Telextender (which will double the image size at the same close focus point).
That's 8 options. Can anyone add to the list?
Jim Salvas
Smithy 51 New Member • Posts: 23
Can you get close enough to take frame filling shots of average size flowers with this combination or is the magnification achieved only suitable for large flowers? If you can post any samples that would be really helpful.
Thanks.
SterlingBjorndahl Senior Member • Posts: 2,642
Thanks.
Smithy, this is a very old thread, from 2013. It's probably better to create a new thread than dig up an old one - who knows how many of the folks in this thread are still around or whether the person you're asking still even uses M43.
Sterling
Lens Grit
 SterlingBjorndahl's gear list:SterlingBjorndahl's gear list
Olympus Air Panasonic Lumix DMC-GX85 Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix DMC-FZ50 +18 more
