Great all-purpose lens
Started Dec 3, 2013 | User reviews
ardeswit New Member • Posts: 4
This is truly a great lens. I've been using it for a couple of years with D60 and I am totally happy with it. It is wide, wider than you would expect it to be. It is quick and sharp. If you know what you are shooting the lens will never miss focus. Sometimes it gives you limitation on the long side, but then again, it is not meant to be a tele. The zoom ring is very convenient, the build is very good. Finally, it is big and looks sexy, especially with the native hood. Back when I was buying it, I wished it were less expensive, yes, but since then I've never thought about the price again.
Canon EF-S 15-85mm f/3.5-5.6 IS USM
Zoom lens • Canon EF-S • 3560B002
Announced: Sep 1, 2009
ardeswit's score
5.0
Average community score
4.0
canuck dave
canuck dave Veteran Member • Posts: 3,202
Re: Great all-purpose lens
Yes, I would agree it is an excellent lens. It's great for travel and for all-round use. The 2-3 stops of IS combined with today's cameras with good high(er) ISO performance makes this a good choice.
OP ardeswit New Member • Posts: 4
Absolutely)
happysnapper64 Veteran Member • Posts: 5,421
I have thought about adding one of the f/2.8 variants of this FR from Canon, Sigma Or Tamron etc, even the 18-35/1.8 Sigma, but I do not think it would be a great improvement on the 15-85 for the 90% of shots I do [outdoors] Small amount of lens creep from 35-50 is about the only "fault" I have found. That's being nit-picking though. Great walk around FR & excellent performance all round make this my favourite & most used lens.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
"I'm so fast, when I turn off the light, i'm in bed before the room gets dark" The great Mohamed Ali.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +6 more
NancyP Veteran Member • Posts: 6,608
Yes. That's one disadvantage of going to full frame - there is no 15-85 equivalent, and nothing close preserves the wide end, the FF lenses all start at 24mm. The 15-85 is a great landscape lens and a great all-purpose hiking lens with decent close-up ability.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
technic Veteran Member • Posts: 8,932
This lens it known to have frontfocus on many Rebel bodies in the WA range; quite annoying. And this is not 'operator error' and also occurs with center point focus. If you only do people shots (and not infinity subjects like landscape/architecture) and f/8 or so you probably won't notice, but it is problem to be aware of if you use a Rebel and want sharp images.
I get it, that's what we buy cameras and lenses for; I won't go into details about people who are afraid of using 'inadequate' small and light lenses ...
plantdoc Veteran Member • Posts: 4,339
Experienced the same front issue with t1. T2 and t4 are better but the 40d is best. Also, watch out for wide angle decentering. A good copy is a fine lens but shouldn't all copies be good.
Greg
canuck dave
There may be 'some' issues re focusing on some cameras, but that is not unlike many camera/lens sets. With my T2i and in any shooting situation at any aperture my 15-85mm performs perfectly. I regularly print at 16x20in for exhibitions.
vlab
vlab Senior Member • Posts: 1,568
Have it and love it.
 vlab's gear list:vlab's gear list
Panasonic Lumix DMC-FZ50 Canon PowerShot S95 Canon EOS 60D Canon EOS 70D Canon EF-S 15-85mm f/3.5-5.6 IS USM +4 more
vlab
Correction
EF-S 15-85 - for crop sensor, FF equvalent - 24-105, shorter on long end, but the same 24mm in wide.
Of course I can't judge how your equipment performs, but I know from testing and discussions years ago that the problem is widespread. Many forum contributors simply don't know how to test and will deny any problem with their gear.
The other issue with the 15-85 is copy variation; a majority of them are visibly decentered (worst performance of any Canon lens I know, the cheap 18-55IS is many times better when it comes to copy variation). Even several official reviews have noticed ... But fortunately for Canon, most posters on the DPR forums don't know how to check that either or claim that 'corners don't matter'.
If you have a perfect copy, enjoy
Took me 3 tries to get this lens without decentering on the left at wide angle. Also, had issues with the top of the line, 17-55mm. Frustrated. I test with 3 different camera to eliminate the problem being the camera. I shoot real scenic subjects and not test charts as well. I think QC on decentering seems to be a problem. Just my .02
Greg
Damoo Senior Member • Posts: 1,102
Cannot agree on the 5/5 rating.
Good things -> Good IS. Well built. Sharpness is quite good from 70-85mm range. 15mm is wide. Faster AF.
Bad things -> Too much distortion & CA. Yes can be corrected through post processing. Zoom creep. And lot of copies had decentering. Corners are definitely not as sharp as the 17-55mm f2.8. And SLOW.
Its a 450-500$ lens & really not worth the premium price.
I have taken some excellent shots with this lens but that does not stop me from saying that this lens is over priced.
 Damoo's gear list:Damoo's gear list
Leica M Monochrom (Typ 246) Olympus OM-D E-M5 Canon EOS 6D Sony a7S Canon EOS 5D Mark IV +16 more
leopold Forum Pro • Posts: 14,083
I bought this lens last summer for my vacation and it's been a very good lens, i think i have a very good copy, even at 85mm i took portrait of my girls and a lot of details on my T3i.
Sure there is some distorsion at 15mm but i corrected it in LR. I use it mostly for landscape now and use LV to focus, but the AF was quite good in daylight.
 leopold's gear list:leopold's gear list
Canon EOS 7D Fujifilm X-E1 Canon EF 400mm f/5.6L USM Canon EF 70-200mm F4L USM Fujifilm XF 14mm F2.8 R +3 more
Its a good lens. But not a great lens. Not worth 5/5 stars. Thats a crazy rating. Perhaps the OP doesn't have enough experience with good lenses.
The lens is very sharp from 70-85mm. I also find 15mm to be good enough. However the corners are NOT sharp enough. Distortions, vignetting & CAs are correctible but there is some loss of IQ.
If the lens is priced @500$, I would say its appropriate. Canon somehow got the pricing wrong for this lens.
bronxbombers4 Veteran Member • Posts: 3,387
Re: Correction
Sort of. I don't think it gets as much from the best that a FF sensor can as the 15-85 gets from the best most APS-C sensors can do though.
Limburger
Limburger Veteran Member • Posts: 7,841
Not a perfect lens but hard to beat.
If you can live with the slow aperture it's the walkaround lens for Canon crop.
Downside is distortion wide, not so good for architecture and low light.
On the other side: good MFD, 24-136eq, good IS with tripod detection, FTM and sharp.
In case you want a significant upgrade it will be significantly more expensive as well.
4/5 my vote.
Not perfect but a joy to use.
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100 Canon EOS 7D Sony a7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F4L USM +3 more
Stakeouttoo
Stakeouttoo Senior Member • Posts: 1,298
been using it for almost 2 years as my all-around walk-around lens on my 60d..I just got a 17-55is for a trip to Europe that I just completed mainly for its 2.8 for indoors--cathedrals and museums.. still I go back to my 15-85.. overall I have no complaints about it.. love it.. it's just 'right' for me at least and with the 17-55 I just miss the wider angle of the 15mm.. doesn't look like much of a difference in #'s but it is if you like the wider angle
Ray
my Canon 60d sure beats using that ol' Petri 7s
 Stakeouttoo's gear list:Stakeouttoo's gear list
Canon 6D Mark II Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6L IS USM Canon EF 70-200mm F4L IS USM +13 more
crunch27 Junior Member • Posts: 48
I have had mine for 2 years too and am very happy with it.  It's a great "all-purpose" lens and it probably takes 85% of my shots.  Agreed, nothing is 5/5, but definitely 4/5, maybe 4.3/5.
 crunch27's gear list:crunch27's gear list
Canon PowerShot G15 Canon EOS 60D Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +3 more
