Does the E-M1 have Low light issues ?
Started Dec 3, 2013 | Discussions
lightandday
lightandday Regular Member • Posts: 230
I've just purchased a E-M1 ( not able to use as I'm awaiting delivery of a 17mm lens ) and having experienced the FUJIFILM X10 " ORBS "debarcle, have a done it again or is there NO PROBLEM ? I do hope so as I love this camera !
 lightandday's gear list:lightandday's gear list
Fujifilm X10 Olympus E-M1 Olympus Air Olympus M.Zuiko Digital 17mm 1:1.8 Olympus 40-150mm F2.8 Pro +2 more
CrisPhoto
CrisPhoto Senior Member • Posts: 1,669
Re: Does the E-M1 have Low light issues ?
In short: E-M1 is a very good camera.
To clarify the low-light thing for me, I compared my E-M1 and my E-M5.
I made dark exposures in RAW and extracted the noise statistic value (standard deviation sigma) from RawDigger. (ISO200, ShadowComp=OFF, WB=auto, NoiseFilter=off, temperature 22°C, sensor temp=29°C).
  • With shutter speeds faster than 15 seconds, EM1 is very similar.
  • Without noise reduction (=darkframe), at 15 seconds and above the new camera has significantly more dark noise than the "old" EM5.
  • With "noise reduction" enabled, E-M1 and E-M5 or on par again.
So, under certain circumstances E-M1 is "less good" than E-M5, but even then, the E-M1 is as good or better than most other cameras. The EM5 is outstanding in this regard but we did not notice yet ...
Christof
OM-D + Sam7.5, PL25, O60, O75
P12-35, O75-300
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M5 II Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Rokinon 7.5mm F3.5 UMC Fisheye CS +9 more
alolywu Regular Member • Posts: 387
Very nice summary, thank you!  Don't forget however that noise reduction (dark frame) doubles the exposure time and for some people that may be an issue.
P12-35, O75-300
vinster Forum Member • Posts: 53
Im using the 17mm as its the only lens I have and low light shots are great, no problems.
 vinster's gear list:vinster's gear list
Leica D-LUX 2 Leica D-LUX 5 Leica M9 Olympus E-M1 Sony Alpha a7 III +4 more
Steve_
Steve_ Senior Member • Posts: 2,869
Yes
It's darned near impossible to find in the dark.
 Steve_'s gear list:Steve_'s gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic Lumix G 14mm F2.5 ASPH +13 more
lightandday
OP lightandday Regular Member • Posts: 230
Re: Yes
Hi Steve,
What were you looking for ?
lightandday
Hi Cris,
Thank you for you explanation - thankfully it's not another " FUJIFILM. ORB " problem just a limitation in the camera that needs to be and can be managed ! MANY THANKS !!
Regards
CrisPhoto
Thanks for thanking!
And I see you also have the 50-200mm lens. I wish yo many outstanding photos with this combo!!
Christof
P12-35, O75-300
UnderDriven
UnderDriven Senior Member • Posts: 1,089
Does anyone know what changed to cause this? It seems strange, since they are both 16MP sensors. I can't imagine Olympus using an inferior sensor in their flagship model, and newer sensors are usually better. Did Olympus tweak the M1 to improve low ISO performance at the expense of high ISO performance? I see that the M5 has a min ISO of 200, and the M1 has a min ISO of 100...
“The world is going to pieces and people like Adams and Weston are photographing rocks!” --Henri Cartier-Bresson
 UnderDriven's gear list:UnderDriven's gear list
Sony Cyber-shot DSC-R1 Panasonic Lumix DMC-G1 Sigma SD14 Sony SLT-A55 Sony SLT-A57 +9 more
SaltLakeGuy
SaltLakeGuy Forum Pro • Posts: 13,815
Not in the least
I've seen all kinds of disparaging reports regarding low light focus issues and performance overall. I've had too many pro DSLR bodies to count since 1997 and frankly NONE have been better at focusing in the dark than the EM1 has been in my experience so far. Even the D700 and D7000 I had before didn't focus on a familiar railing post in my dim living room, and the EM1 nails it without even hunting, and best of all it renders an IN focus shot everytime. As long as you're eye can see it and there is "some" light on it the EM1 will have no issues nailing it.
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony RX10 IV +8 more
mgnff Junior Member • Posts: 47
I shoot up to ISO 3200 with my EM1, images are quite decent after appropriate NR in Lightroom. It is definitely good enough and focusing is quick in low light when paired with the right lens.
My Nikon Df is a low light monster, although I would say the EM1 is more fun to use due to several advanced techs that make life easier (live histogram, real-time color shift, focus peaking, etc.).
 mgnff's gear list:mgnff's gear list
Olympus E-M1 Nikon Df Canon EOS D30 Nikon D70 Olympus PEN E-P1
rrr_hhh Veteran Member • Posts: 6,022
It could be the price to pay for the pixels sacrificed to the on sensor PDAF. The E-M1/E-M5 sensors aren't equal due to this specific feature Of the E-M1.
rrr_hhh
 rrr_hhh's gear list:rrr_hhh's gear list
Olympus OM-D E-M5 Canon EOS 6D Sony Alpha a7R Olympus E-M5 II Sony Alpha a7R II +5 more
Olymore
Olymore Senior Member • Posts: 1,728
There is no obvious pattern to the noise suggesting it relates to the PDAF pixels/locations.
The most likely explanation I've seen is something to do with the circuitry and heat generation.
Unless you do long exposures with noise reduction turned off it doesn't appear to be an issue so most people will be unaffected.
There are 10 types of people.
Those that understand binary and those that don't.
 Olymore's gear list:Olymore's gear list
Olympus E-M1
Olymore
Re: Yes
They should have added illuminated buttons like the E620
Olympus E-M1
VinceC Senior Member • Posts: 1,035
Low light shots
Check these out - taken at my local folk music club, which is not blessed with a lot of light!
Best regards
Vince C
 VinceC's gear list:VinceC's gear list
Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0
UnderDriven
On-sensor PDAF is another difference between the M1 and the M5. Do sensors with PDAF (1) replace specific image pixels with the PDAF sensors, or (2) do they reduce the size of the all the image pixels (slightly) to make space for the PDAF sensors? If it's #1, how do they recover the image information where the missing pixels are?
Another possibility is that the sensor manufacturing process had to be modified to allow for the PDAF sensors--if they cannot be fabricated using the same process used to fabricate the M5 sensor...
Perhaps the PDAF sensors require a significant amount of circuitry on the chip, which--in addition to the optical real estate needed by the PDAF sensors--may have required a slight reduction in the size of the imaging pixels...
The other difference is the elimination of the AA filter, but I don't see how that could have any bearing on long-exposure noise...
I realize it isn't a big issue for most users, but I'm still curious as to why the M1 is worse in this one area...
I find that curious. It could be sample variation, but on the other hand, it is very consistent : a similar pattern appears for all lenses.
Look here for the links to the DXO TEST results :
http://www.dxomark.com/Reviews/Best-lenses-for-the-Olympus-OM-D-E-M1-Short-telephoto-and-standard-focal-lengths (E-M1)
http://www.dxomark.com/Reviews/Best-lenses-for-your-Olympus-OMD-E-M5-Panasonic-Lumix-DMC-GH3 (E-M5)
rrr_hhh
