New X-E2 flash mode?
Started Dec 3, 2013 | Discussions
stein1010 Junior Member • Posts: 47
So I just got my X-E2 and was working through figuring out the controls and can't seem to get the flash to fire.  So can anyone who has one help me figure out if I have a defective model, or if I am doing some thing stupid.
I have both shutter and aperture in auto, and I press the flash button, the flash pops up, but in the top left of the screen there is a yellow no flash symbol.
Also If I go to the Q menu, the flash mode is set to auto, but its greyed out and I can't change it.  Is there another setting that I am missing to enable to flash?  Also should to be able to change setting with the flash down.  Or is it the camera I have doesn't recognize the flash has popped up?
Thanks,
Andy
Fujifilm X-E2
Chris Dodkin
Chris Dodkin Forum Pro • Posts: 13,956
Re: New X-E2 flash mode?
You can't use flash in silent mode - are you in silent mode?
http://www.dodkin.com
Chris@1D-Images.com
Mac Pro/MacBook Pro/iPods/iPhones/iPad
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-T2 Fujifilm GFX 50S Fujifilm GFX 50R +50 more
ryan2007 Forum Pro • Posts: 12,001
Thanks,
Andy
Try taking the camera to a darkened area where you know the flash should go off. Take a shot, if the flash does not go off switch to program which means take the shutter or aperture out of "A" so you have to choose one. Set a low ISO to be sure the flash fires.
If it did not fire in auto and auto ISO is being used, which I think it defaults to the camera is doing everything and fires the flash if needed.
If the flash does not fire when you switch to manual override in any combination you most likely can be in silent mode which while turning off the sounds turns the flash off.
You can also check the owners manual for the XE-1 if you do not have the one for the XE-2 for some reason and search for silent mode and flash related topics on the Fuji web site. Just go the the camera and then the Support tab and that is where manuals reside. They all work the same.
oking23 Regular Member • Posts: 285
I agree that you are likely in silent mode. If not and the flash is set to auto, the flash will only fire when it is needed. You would need to change the setting to force flash. Good luck .
 oking23's gear list:oking23's gear list
Fujifilm FinePix S5 Pro Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +25 more
James M Hilliard Regular Member • Posts: 472
The flash will not work in ANY of the bracket modes too.
Mark Hilliard
Color Blog: www.markhilliardatelier.Wordpress.com
IR Blog: www.infraredatelier.Wordpress.com
OP stein1010 Junior Member • Posts: 47
Yep I had it in silent mode.  Thought that just turned off the beeping but I guess it does more then that.  Need to go back to the manual before I change things.
Thanks,
Andy
57LowRider Veteran Member • Posts: 4,240
I've been there with the X-E1, you need to set volume to off to get rid of the P&S sound effects.
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +11 more
Seaflower New Member • Posts: 1
Thank you, Chris for your solution to the problem with the flash not flashing! Very much appreciated!
I did set my X-E2 into silent mode a while ago and that setting was a ”suspect” when I could not activate the onboard flash. After having read your instruction I turned off the silent mode and, voilà, the flash worked as it should. The section in the manual about the flash did not tell about the influence of the silent mode, so your comment was very helpful.
 Seaflower's gear list:Seaflower's gear list
Panasonic LX100 Nikon D40 Fujifilm X-E2 Nikon D5300
