The Lens You Wish Nikon Made
Started Dec 2, 2013 | Discussions
Ali-C Forum Member • Posts: 70
Re: The Lens You Wish Nikon Made
rcower wrote:
Canon mp-e 65
you do realize the only thing "special" about that lens is the collapsible extension tube, right?
It doesn't have a collapsible extension tube, it's a dedicated macro lens designed for reproduction ratios of between 1:1 and 5:1. Here the canon page with associated info:
http://www.canon.co.uk/For_Home/Product_Finder/Cameras/EF_Lenses/Macro/MP-E_65mm_f2.8_1-5x_Macro_Photo/
 Ali-C's gear list:Ali-C's gear list
Canon EOS-1D Canon EOS-1Ds Canon EOS-1Ds Mark II Carl Zeiss Planar T* 1,4/50 Voigtlander 90mm F3.5 APO-Lanthar SL II +10 more
Roy Kikuta Senior Member • Posts: 1,705
10.5mm f/2.8 for FX (rectilinear, small, and light like the DX 10.5mm)
larrywilson
larrywilson Veteran Member • Posts: 6,568
6
Update of the Nikon 20mm f2.8 lens to a better lens for digital images.  This is way past due.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D500 Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 500mm F4E FL ED VR +7 more
Brian in Montana
Brian in Montana Regular Member • Posts: 442
Any lens that is at or goes to 500mm for under $2,000.
The 300mm F4 VR (soon?) at less than $1,800.
And then I woke up....
ceaiu Regular Member • Posts: 118
Realistic for Sigma because they already released 3 lenses for APS-C since reorganizing (1 year). I'm sure other (eg 8-16mm) will be re-released shortly.
Not realistic for Nikon because all they release lately, for crop, are superzooms. Sure those primes can be done, only Nikon doesn't want to.
So in 2014 its more likely that Sigma will make another f1.8 zoom, than Nikon to make another DX prime.
joejack951 Senior Member • Posts: 2,682
JamesErik1971 wrote:
24-85mm f/2 VR
$2999
Increased range, faster by a full stop, and adding VR all for $1100 more? You don't even get a full stop for a prime for that money (reference 35/1.4 vs. 35/2, and 85/1.4 vs. 85/1.8), let alone the other wishes. For zooms, the closest comparable lenses would be the 70-200/2.8 VRII and the 70-200/4 VR. The loss of a stop in that case took $1000 off the price alone. So a 24-70/2 could theoretically cost $2900 but I'm thinking closer to $4000 for the extra 15mm and VR.
The size might be a bit annoying but it's a lens I'd love to have too (but not in the market for at realistic prices)!
 joejack951's gear list:joejack951's gear list
Nikon Coolpix AW100 Nikon Coolpix P7700 Nikon D300S Nikon D3S Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
ebsilon Contributing Member • Posts: 628
ForeignerOnEarth wrote:
Nikkor AF-S DX 24mm f/1.6G (much cheaper than FX 24/1.4)
Nikkor AF-S DX 24mm f/2G (cheap, small)
Nikkor AF-S DX 16mm f/2G
Nikkor AF-S DX 70mm f/1.6G
Nikkor AF-S DX 60-240mm f/2.5-4G VR
Nikkor AF-S DX 16-55mm f/2.8G VR
Nikkor AF-S DX 16-85mm f/4G VR
+7
and add to this list
Nikkor AF-S DX 50-135mm f/2.8 VR
Sad thing is the only of the above that seems a close to likely is an update to the 16-85mm. Nikon otherwise seems to have made up their mind to leave us DX users to languish with yearly updates of 18-xxx mm f/3.5-5.6 (ok admittedly the new 18-140mm seems to be well received in terms of optical qualities).
------- Eirik ----------
Visit my gallery at http://eirikbs.smugmug.com/
happypoppeye
happypoppeye Veteran Member • Posts: 3,894
A wide semi fast prime for APS-C
EKB wrote:
It's the wish-list time of year again, and rather than resurect an old thread I'll start a new one.
What's the one lens you most wish Nikon would introduce? Realistically. Or not realistically, if you prefer.
For me, it would be a 70mm f/1.8 prime (or possibly an f/2 macro). I shoot DX, so it would be a "105mm FX equivalent," and I wouldn't be bothered if Nikon made it as a DX lens, rather than FX.
I already have a 50mm f/1.8D, and I could get an 85mm f/1.8 if I wanted - but I'd like something in-between those two focal lengths.
thats semi small ...I don't think thats really asking too much.
...maybe something similar too the 14 2.5 for m43 ...or the 12 2.0 or something like that. Really the reason I left Nikon.
 happypoppeye's gear list:happypoppeye's gear list
Panasonic Lumix DMC-TS30 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS
calson Veteran Member • Posts: 9,609
I was waiting for two lenses, a DX 60mm and a new version of the 80-400mm zoom. With DX cameras there was no equivalent in a prime to the 85mm f1.4 lens on a film or FX camera. Now there is the 58mm DX lens which is close enough only 10 years too late. It should have been released soon after the D1 cameras.
Nikon after more than 10 years finally updated the 80-400mm VR I lens which was a mediocre lens in every respect. Nikon replaced the 80-200mm f2.8 with the 70-200mm f2.8 VR I and then the 70-200mm f2.8 VR II as well as the 200-400mm VR I and the 200-400mm VR II lenses while completely ignoring the 80-400mm lens. I was sorely tempted to get a Canon camera so I could use the excellent Canon 100-400mm IS zoom lens.
At this time I would like to have a FX travel lens with a zoom range of 50mm to 150mm that was half the size and weight of the 70-200mm and had f2.8 speed and VR. Even a 50-135mm f2.8 VR would be OK. All the Nikon "travel" zooms are f5.6 lenses and VR does not compensate for the lack of f2.8 in terms of autofocus speed or the ability to photograph any subjects in motion, including landscapes with a breeze moving plants or people walking down the street.
My DX travel kit weighed 4 lbs. less than my equivalent FX kit and the differnce was with the weight of the lenses.
Melvinphoto Regular Member • Posts: 413
For FF: set of highest Quality 2.8 primes. Keep them relatively small and light.
18/2.8 g AFS or 18/3.5 g AFS
20 or 21/2.8 g AFS
24/2.8 g AFS
All: weather proof construction and well corrected high Quality optics
turbsy
turbsy Contributing Member • Posts: 909
The Andy G wrote:
A new 20mm.
+1
Could you all move half an inch to the left? Okay, pretend you like each other and smile.
 turbsy's gear list:turbsy's gear list
Olympus XZ-1 Nikon D50 Nikon D300 Nikon D800 Nikon AF-S Nikkor 300mm f/4D ED-IF +11 more
turbsy
None, the Nikon Lenses are to Expensive and/or have not good IQ like Bokeh and more...
What a great contribution thanks for posting your thoughts.
chromophore
chromophore Regular Member • Posts: 141
... Noct-Nikkor 58mm f/1.2 AF-S
www.flickr.com/lhotelin
 chromophore's gear list:chromophore's gear list
Nikon D3S Nikon D750 Nikon PC-E Nikkor 24mm f/3.5D ED Sigma 50mm F1.4 EX DG HSM Sigma 85mm F1.4 EX DG HSM +9 more
Holmes375
Holmes375 Veteran Member • Posts: 3,798
A 100-300mm f4 VR with a well designed tripod collar... and hold the breathing, please
 Holmes375's gear list:Holmes375's gear list
Panasonic FZ1000
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 16,866
The DX 10.5mm is a fisheye. It's anything but rectilinear. And an FX 10.5mm fisheye is going to put a circular image on a 24mm X 36mm frame.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony RX100 III Nikon D300 Nikon D750 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +12 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 15,201
24 F1.8
Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +37 more
Pontoneer Senior Member • Posts: 2,990
Something like this ?
http://www.dpreview.com/products/pentax/lenses/pentax_smc_fa_77_1p8_ltd
or maybe this ?
http://www.dpreview.com/products/pentax/lenses/pentax_hd_da_70_2p4_ltd
With kind regards
Derek.
 Pontoneer's gear list:Pontoneer's gear list
Pentax *ist D Pentax K-01 Pentax K-3 Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited +38 more
windsprite
windsprite Senior Member • Posts: 2,621
I'm mostly happy with what's available, but I'd like a new 35/2 or even 35/1.8 for FF. I'd also love to see the 28-200G updated with better optics and VR (fully aware that it will be heavier and more expensive).
Julie
 windsprite's gear list:windsprite's gear list
Fujifilm FinePix F100fd Fujifilm FinePix F550 EXR Panasonic Lumix DMC-FZ200 Nikon D2H Nikon D300 +42 more
Nick Jones 08 Junior Member • Posts: 43
I would be very glad if Nikon still offered their official F-to-AI conversion service.
 Nick Jones 08's gear list:Nick Jones 08's gear list
Nikon AF-S Nikkor 50mm f/1.8G +5 more
Karl Summers
Karl Summers Regular Member • Posts: 234
clarnibass wrote:
AFS 135mm f/2 (for a price that is worth it to me).
If you're talking G lens, then yes, definitely.
 Karl Summers's gear list:Karl Summers's gear list
Sony a7R II Sony FE 85mm F1.4 GM
