Top 3 Lenses You Will Use With the A7/A7R
Started Nov 27, 2013 | Discussions
Jefenator
Jefenator Senior Member • Posts: 2,862
Re: Top 3 Lenses You Will Use With the A7/A7R
Leitz Summicron-R 1:2/35mm
Leitz Summicron-R 1:2/50mm
Leitz Macro-Elmar 1:4/100mm
That would be the top 3.
The first runner-up would be my Nikkor 24/2.8 AI, the Tokina RMC 17/3.5 and I might have to rotate nifty fifty duty with the Minolta MC-Rokkor 50/1.4 and Canon FL 55/1.2.
 Jefenator's gear list:Jefenator's gear list
Sony a7 Canon EF-M 11-22mm f/4-5.6 IS STM Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro Sony Alpha NEX-7 +8 more
NEXFULLFRAME Regular Member • Posts: 283
ST205 wrote:
Voigtlander 35/1.2
Zeiss ZM 50/2 Planar
Zeiss ZM 85/2 Sonnar
The 2.8 is common but the 85/2 Sonnar is a rare beast...
nzmacro
nzmacro Forum Pro • Posts: 15,724
Just the one
On FF I would only consider the one lens, Canon FD 800 F/5.6L. The rest of the lenses would still be mounted on the NEX-7. I know exactly what I can get away with on the FF cameras vs the crop. 800mm makes so much sense while the 300mm and 500mm makes more sense on the NEX.
All the best.
Danny.
http://www.birdsinaction.com
The image couldn't care less what took it, it just exists.
 nzmacro's gear list:nzmacro's gear list
Sony Alpha NEX-7 Olympus E-M1 Sony a7 +6 more
Lightshow
Lightshow Veteran Member • Posts: 6,787
Tough to answer, so many to choose from....
FD SSC 24/1.4 Aspherical.
My Contax G 45/2 Frankenstein, it's optics transplanted into a Rokkor MC 55/1.7 body with an M-mount. (Work in progress)
M 90 Cron APO Asph.
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Leica Elmarit-M 24mm f/2.8 ASPH Leica APO-Summicron-M 90mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar +20 more
ST205 Regular Member • Posts: 137
NEXFULLFRAME wrote:
ST205 wrote:
Voigtlander 35/1.2
It's also pretty large and heavy for a rangefinder lens. At odds with the philosophy of Sony's new system as well, but I can't bring myself to sell it. I've taken some of my favourite photos with it.
Cheers
Ben
 ST205's gear list:ST205's gear list
Carl Zeiss Biogon T* 2,8/25 ZM Carl Zeiss Planar T* 2/50 ZM Carl Zeiss Sonnar T* 2/85 ZM Voigtlander 35mm F1.2 Nokton
Carl Schofield Senior Member • Posts: 2,631
1. CV 21mm f/1.8 Ultron
2. Contax G 45mm f/2 Planar
3. Contax G 90mm f/2.8 Sonnar
 Carl Schofield's gear list:Carl Schofield's gear list
Sigma DP2 Merrill Fujifilm X100F Sony a7R Pentax 645Z Sony a7 II +2 more
igorphoto New Member • Posts: 20
1. Zeiss FE 35mm f2,8 ZA
2. Leica M 90mm f2,0 Apo
3. Voight 50mm f 1,1
Igor
LimitedAmatuer New Member • Posts: 11
Only what I've already got, these will be my top three as they are on my K-5 IIs . . .
1. Pentax-FA 31mm f/1.8 Limited
2. Pentax-FA 77mm f/1.8 Limited
3. Pentax-K 50mm f1/.2
The thing is with the A7 it seems you can stick almost any lens on it and this is a very hazardous circumstance for anyone who likes to click on 'Buy It Now' or 'Add To Basket' or 'Checkout'.
So, for now, once I can find an A7r and Novoflex adapter, I'll only be using the Pentax-K and M42 lenses I already have, such as the ones mentioned above CZJ DDR Electric 50/1.8 and others.
Lot of people could cause themselves serious financial problems over this camera and I like this thread because it makes folks think about their best three lenses for this Sony.
 LimitedAmatuer's gear list:LimitedAmatuer's gear list
Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 77mm 1.8 Limited +14 more
ZzzooM3
ZzzooM3 Regular Member • Posts: 276
Martin Muehlemann wrote:
ZzzooM3 wrote:
Canon EF 17-40mm f/4.0L USM w/Metabones MB-EF-E-BM3 Adapter
You cannot be serious, right. This one is probably the worst UWA lens in the Canon L park.
Cheers
Martin
By what standard? By worst, if you mean not fast, okay. You will need good lighting with it. There's no problem with IQ.
It's weather-sealed, extremely tough and compact lens that maintains a fixed size when zooming or focusing, and silent with full-time manual focusing. It produces very good image quality across its focal range from three aspherical and 1 Ultra-low Dispersion elements.
I am thinking about picking up the EF 24mm f/1.4L or EF 35mm f/2.0 IS for fast FF lens, however.
 ZzzooM3's gear list:ZzzooM3's gear list
Sony a7R II Canon EF 70-200mm f/2.8L IS USM Sony FE 55mm F1.8 Canon EOS 6D Sony a7 III +10 more
contax4ever Contributing Member • Posts: 613
C/Y Zeiss 28/2.8
ZA 50/1.4 with la-ea4
C/Y Zeiss 85/1.4
darrellc Regular Member • Posts: 415
Cron R 50/2
OM 21/3.5
Zeiss 50/1.5 Sonnar C
Will add a 35 (not sure if I'll get the FE 35//2.8 or one of the RF 35's that work without issues) and short tele, which might displace one of the 50's for #3 spot.
OP KwhyChang Veteran Member • Posts: 5,958
Can I change my mind? Played with it last night and decided the Nikkor 85/1.4 AIS is quite unbalanced (very front heavy with all that glass). So decided I will probably just use these two for now:
I'm changing my mind too. The Canon 24-105 felt unbalanced and heavy on the A7 and the overall usage and response of the Metabones III was such that I preferred manual focus. So I found a used Zeiss ZF 85mm 1.4 to go along with my CV 35mm f1.2 and Zeiss ZM 50mm f2.
I would still like to find a very wide lens, (wider than the upcoming 24-70) and am looking at the Voigtlander 21mm f4.
Dave
radissimo
radissimo Regular Member • Posts: 148
Depends on the day:
Leica R mood/ C/Y (e.g can pack heavy)
1) cron-R 35   /  Distagon 35 1.5
2) lux-R 50   /  Planar 50 1.4
3) Cron-R 90   /Distagon 85 1.4
+Ricoh GR w/ wideangle adapter
City mood/ night:
1) CV 35 1.2 II  (or CV 40 1.4)
2) Nokton 50 1.5 asph  (or ZM planar f2)
3) Apo Lanthar 85 3.5
Rado
 radissimo's gear list:radissimo's gear list
Sigma DP2 Merrill Ricoh GR Panasonic LX100 Canon PowerShot G7 X Canon G7 X II +7 more
