Top 3 Lenses You Will Use With the A7/A7R
Started Nov 27, 2013 | Discussions
KwhyChang Veteran Member • Posts: 5,959
I  use:
Canon 24-105 with Metabones adapter
Voigtlander Nokton 35mm f1.2
Zeiss 50mm f2 Planar T* ZM
Dave
Sony a7
djp58 Regular Member • Posts: 351
Nikon 20mm f4; OM 21mm f3.5 & new Zeiss 35mm f2.8
should be fun on the A7R when it arrives, though looking forward to many others also!
David
 djp58's gear list:djp58's gear list
Sony Alpha NEX-7 Sony a7R Sony E 18-200mm F3.5-6.3 OSS Sony E 50mm F1.8 OSS Sony FE 35mm F2.8 +13 more
ZzzooM3
ZzzooM3 Regular Member • Posts: 276
Re: Top 3 Lenses You Will Use With the A7/A7R
  • Canon EF 24-70mm f/2.8L II USM w/Metabones MB-EF-E-BM3 Adapter
  • Canon EF 17-40mm f/4.0L USM w/Metabones MB-EF-E-BM3 Adapter
  • Sony E 35mm F1.8 OSS
 ZzzooM3's gear list:ZzzooM3's gear list
Sony a7R II Canon EF 70-200mm f/2.8L IS USM Sony FE 55mm F1.8 Canon EOS 6D Sony a7 III +10 more
Arashi1987 New Member • Posts: 15
Re: Nikon 20mm f4; OM 21mm f3.5 & new Zeiss 35mm f2.8
so far
Manual lens - CG45,90
Auto - Sigma 35 1.4
 Arashi1987's gear list:Arashi1987's gear list
Sony Alpha NEX-5N Sony a7R Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* Sony FE 35mm F2.8 +1 more
Carbon111
Carbon111 Contributing Member • Posts: 555
Leica 50mm Summicron-M f/2
Leica 35mm Summilux-M ASPH f/1.4
Minolta MC Rokkor 58mm f/1.2
 Carbon111's gear list:Carbon111's gear list
Leica X (Typ 113) Leica Q Leica S2 Ricoh GXR A16 24-85mm F3.5-5.5 Leica M Typ 240 +9 more
IdealCamera Regular Member • Posts: 146
Zeiss 55/1.8
Nikkor 5cm/1.4 ltm
Super Takumar 85mm/1.9
 IdealCamera's gear list:IdealCamera's gear list
Leica M-E Typ 220 Sony a7 Voigtlander 21mm F4 Color Skopar Pancake II Sony FE 55mm F1.8 +2 more
dazedproductions Forum Member • Posts: 76
Top 3 for me
Zeiss sonnar 50mm f1.5
Leica summicron 90mm(preasph)
Voigtlander 35mm f1.4 sc
 dazedproductions's gear list:dazedproductions's gear list
Nikon D3 Sony a7R Nikon AF Nikkor 20mm f/2.8D Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 85mm f/1.4D +12 more
OP KwhyChang Veteran Member • Posts: 5,959
IdealCamera wrote:
Zeiss 55/1.8
Nikkor 5cm/1.4 ltm
One of the reasons I posted this question was out of a curiosity of other lenses that people might be using. After all, with adapters, you can use most any lens.
Curious about the Nikkor. Have you used it much?
Interesting. So far you're the only one who's planning to use a Sony FE lens. I'm looking forward to reviews.
Dave
Lisa O
Lisa O Senior Member • Posts: 2,505
35 FE
55 FE
24-70 ZFE
but since I only have the 35 right now...
Zeiss 50 2.0 ZM
Contax G 90
Try Contax 21 for B&W
Perhaps a Nikon 105 2.5
see about me in my profile for more info
http://500px.com/LisaOsta
http://www.flickr.com/photos/losta
 Lisa O's gear list:Lisa O's gear list
Sony RX1R II Olympus E-M1 Nikon D810 Olympus E-M5 II Nikon D7200 +27 more
Steverunner Junior Member • Posts: 44
Zeiss 55/1.8
Zeiss 35 2.8
Last one .... Hmmmm not sure perhaps a 70-200 FE would be great..... Waiting for it
brudy Senior Member • Posts: 1,510
KwhyChang wrote:
I use:
We're quite similar.
Zeiss 50/2 planar ZM
CV 35/1.2
Cv 15/4.5 (we'll see how this does, I'm not hopeful)
Canon 24L
Canon 85 1.8
(other assorted Canon lenses)
www.flickr.com/photos/brudy
 brudy's gear list:brudy's gear list
Fujifilm FinePix X100 Canon EOS 7D Sony a7R Fujifilm X-T10
verybiglebowski
verybiglebowski Veteran Member • Posts: 3,986
Canon 5200mm f/14
Zeiss APO Sonnar T* 1700mm f/4
Lensbaby
Don't trust your eyes or mind, they might betray you! Trust only comments posted on the forums, because there is the absolute truth!
http://www.flickr.com/photos/viktor_viktor/
http://verybiglobo.blogspot.com/
 verybiglebowski's gear list:verybiglebowski's gear list
Sony a7R Sony a7R II Sony a7R III Zeiss Otus 1.4/55 Zeiss Otus 85mm F1.4 +2 more
Rob Sims
Rob Sims Contributing Member • Posts: 610
KwhyChang wrote:
Mine A7 just arrived yesterday, and I've only had a couple of hours to play with it in the evening, but from my current kit I can already see myself using the following:
  • Sony 10-18/4
  • Voigtlaender 35/1.2
  • Nikkor 85/1.4 AIS
The one I'm most surprised about is how well the Sony 10-18 works. At 12mm it fills the frame and I think will require minimal cropping (maybe 5-10%) to get sharpness back to the far corners. Vignetting also not as bad as I thought it'd be, even at 4.0 and 5.6. Effectively it becomes an ultralight full frame 14mm.  I will post some samples when I get a chance.
 Rob Sims's gear list:Rob Sims's gear list
Sony RX100 Sony RX1 Sony RX100 IV Sony a7 Sony a6000 +8 more
Lisa O wrote:
35 FE
55 FE
24-70 ZFE
Zeiss 50 2.0 ZM
Contax G 90
So you decided to pick up a Contax G 90 for your long solution?
Be interested how that works out.
Dave
Rob Sims wrote:
  • Sony 10-18/4
  • Nikkor 85/1.4 AIS
Very interesting results with the Sony. Thanks for sharing.
Dave
jkspepper Contributing Member • Posts: 638
Zeiss C-Sonnar T* 1,5/50 ZM (am using)
Zeiss Planar T* 85mm f/1.4 ZF (will be using)
- as yet unknown UWA - (want to use)
SQLGuy Veteran Member • Posts: 6,928
Only 3, huh.. well...
Realistically:
FD 55/1.2 SSC Aspherical
FD 85/1.2L
The kit 28-70 OSS
But I have a bunch of other lenses that will get time on there too.
Nex-7 with kit lenses, Contax G 35, and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 Sony Alpha DSLR-A900 Sony Alpha NEX-7 NEX-5T +15 more
Lisa O
KwhyChang wrote:
Lisa O wrote:
35 FE
55 FE
24-70 ZFE
Zeiss 50 2.0 ZM
Contax G 90
Well I actually had it, but it is not the easiest lens to focus.
seachicken2000
seachicken2000 Veteran Member • Posts: 3,237
Same here. Can't wait to see it in all its glory!
Zeiss Makro Planar T* 100mm f/2 ZF.2 .. kind of similar.
Same again. Maybe the Samyang 14mm, maybe the Zeiss wide angle zoom on the roadmap, or maybe I will just stick with the 10-18mm.
A rose by any other name is still a chicken.
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Fujifilm FinePix S2 Pro Sony Alpha NEX-5 Sony Alpha NEX-7 Sony a7R +21 more
It's much easier to focus with the AF adapter set to MF.  I tried 3 different MF adapters and didn't really like any of them.
David
