do some lenses require more AF microadjustment than others: 85/1.2
Started Nov 25, 2013 | Discussions
ajy Regular Member • Posts: 251
I already posted this thread in this forum: http://www.dpreview.com/forums/post/52579940, but thought maybe I'd get more responses here:
I've been trying out an 85/1.2 this past weekend with the 1DX. I started to adjust the AF microadjustment settings and noticed that it seems to require a fair amount, around +15 maybe +20. (Admittedly, I haven't had to do any microadjustment with e.g. 24-70/2.8; it seemed to work fine without any).
Have people noticed that some lenses require more microadjustment than others? Is this something that I should expect to do with the 85/1.2 (whereas not so much with the 24-70/2.8)?
Thanks.
 ajy's gear list:ajy's gear list
Leica Q2 Canon EOS-1D X Mark II
Canon EF 85mm F1.2L II USM Canon EOS-1D X
(unknown member) Veteran Member • Posts: 5,590
Re: do some lenses require more AF microadjustment than others: 85/1.2
Thanks.
Well the extremely narrow depth of field at f/1.2 is going to emphasise any errors that may not be evident at f2.8 (and you are not quite comparing apples with apples either with regards to focal length).
If you haven't already read it have a look at this article:
http://www.lensrentals.com/blog/2008/12/this-lens-is-soft-and-other-myths
and the follow up:
http://www.lensrentals.com/blog/2010/03/this-lens-is-soft-and-other-facts
OP ajy Regular Member • Posts: 251
Thanks.
and the follow up:
That's a good article.
Also saw some comments from 2010 about the 85/1.2 here: http://www.dpreview.com/forums/thread/2767345
tonyjr
tonyjr Veteran Member • Posts: 5,295
Yes , my 35-350 is all over - depends on distance , F stop .
My 70-200 mk II is fine til I add the 2 X III .
The 10-22 seems OK also . The sigma 180 macro is + 9 up to 5/6 feet .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
