How many shutter actuations is safe for a used D3s or D700?
Started Nov 21, 2013 | Discussions
jfriend00 Forum Pro • Posts: 13,687
I am looking on eBay at both D700 and D3s.  How many shutter actuations should I consider for a camera that I'd like to last at least a couple years?  Under 100,000?  Under 200,000?  Obviously, the lower the better, but some of the deals are not super low counts so I'm trying to figure out what I could/should consider?
FYI, I have 100,000 clicks on my D300 in 6 years so I'll probably add 15,000 or so per year myself.
 jfriend00's gear list:jfriend00's gear list
Nikon Z7 II Nikon Z 24-70mm F4 Nikon Z 14-30mm F4 Nikon Z 100-400mm
Nikon D300 Nikon D3S Nikon D700
sshoihet Senior Member • Posts: 2,633
Re: How many shutter actuations is safe for a used D3s or D700?
Well, it's going to depend a lot on what the price is...if the count is high but the price is very good, then you'd be able to cover a replacement shutter if that were to go.
The D700 is rated at 150,000 cycles and the D3 is 300,000. You can have a look at http://www.olegkikin.com/shutterlife/ to see what people have experienced.
I shoot 60-70K frames a year, I'd probably want to stick to under ~50K on the D700 and ~100K on the D3 but it's really going to depend on the price.
 sshoihet's gear list:sshoihet's gear list
Nikon D7000 Canon EOS M Nikon D600 Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +14 more
MOD Marianne Oelund Veteran Member • Posts: 7,868
D3s durability
8
I will generally have precautionary mechanical rebuilds done on my cameras at about 500,000 shutter actuations.  Prior to that point, I consider mechanical failures to be of little concern.
My #1 D3s has over a million actuations on it, with the help of a rebuild at 500,000 frames.  The #2 D3s is at about 500,000 and just had a rebuild, so is ready to continue for quite a long time.  My #1 D4 is at about 640,000 frames and has had no work done on it yet, other than sensor cleanings.  None of these cameras have experienced shutter failures.
On the D3 (and possibly D700), one of the weak points was the thin material of the mirror assembly arms, where they pivot on small pins.  It appears that the D3s and D4 have bushings added, which seem to be giving this part of the mechanism much better life.
Considering the durability of these cameras, your primary criterion should be overall condition and the level of care given by the owner.  As long as it has been spared abuse, you can expect a very long service life, and the shutter count should be given little weight in your purchase decision.
Qualities possessed by God in infinite proportion: Love, Grace, Power, Righteousness, Wisdom, . . .
Qualities possessed by humans in infinite proportion: Ignorance.
- Marianne
T O Shooter Forum Pro • Posts: 12,066
I would want a D3S under 50,000  It's somewhat rare to find one with lower actuations as most of these are pro owned. Here in Toronto, enthusiasts, who are more likely to have lower actuations than a working pro, tend to put a premium on low shots.
On a D700 there's no reason not to find one under 10k.  A lot more plentiful. There's probably only $200 or $300 separating the price between 10k and 100k, with the difference diminishing the lower the shots.
 T O Shooter's gear list:T O Shooter's gear list
Canon PowerShot G5 Nikon D4S Nikon D500 Nikon D850 +5 more
rubicon Senior Member • Posts: 1,630
I know this out of the area, my D700 bought new has about 30K and I just bought a D2X, and it has 32K and I paid $ 650.00, I too think if needed I'll have them rebuilt these two cameras do all i could ask for I'm very happy with them.
Good luck.  Rubicon:
 rubicon's gear list:rubicon's gear list
Nikon D90 Nikon D2X Nikon D200 Nikon D700 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +6 more
Bender73
Bender73 Regular Member • Posts: 324
Old thread, but I stumbled upon it in a search.
It completely depends on the price.  I just purchased a used D4 with 250,000 clicks, but I paid $1500 less than the average price paid for a used D4 in today's market...paid less than a new D750.  If I factor in the cost of a new shutter and mirror assembly (roughly $300-450 when I contacted Nikon) then I come ahead by ~$1000.  It is pretty blemished and well-used, but works perfectly fine.  I look at these things as tools and I want to find a cheap paint brush to make my art!
Gearsau
Gearsau Senior Member • Posts: 2,034
Just checked my Nikon D3. http://www.shuttercounter.com
Shutter count : 11,122 Just run in.
Must test my D3s next ( and my D2Xs )
Regards Peter
 Gearsau's gear list:Gearsau's gear list
Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF Nikkor 35mm f/2D +21 more
Bender73
Regards Peter
11,000!  She is a baby.  250,000 does not even bother me.  Failures can occur at any time.  Just as many shutters go to 600,000+ as those that fail at 25,000.
calson Forum Pro • Posts: 10,717
It is not difficult to find cameras like this owned by hobbyists that have fewer than 10,000 for the shutter count. The shutters are rated for 150,000 clicks on the D3s but why buy a high mileage camera that is been heavily used when you can buy one that sat in someone's camera bag most of the time?
 calson's gear list:calson's gear list
Nikon D5 Nikon D850
Bender73
The D3s is rated at 300,000
Also, to answer your question...money.  I just paid under $2000 (yes, under $2000) for a D4 with 250,000 clicks.  Add $400 for a new shutter and that is still $1200-1400 less than the current market and with a Nikon shutter warranty from Melville.
Gearsau
I would have taken more, but, after my last overseas trip exactly four (4) years ago, I woke up in hospital one week after the flight home. A stroke caused by Deep Vein Thrombosis has slowed me down a little bit
Taken a long time to even think about to get around to take some photos. I recently purchased a new Nikon 24-70mm f2.8 ( not the latest 2015 model)
Even have the new Lucroit Filter holder for my Nikon 14-24 lens. Its quite impressive, with a 165mm x 200mm graduated filter.
Regards Peter
ImageAmateur Veteran Member • Posts: 5,081
Wow... sweet!
Wishing You Good Light.
 ImageAmateur's gear list:ImageAmateur's gear list
Nikon D4 Nikon AF-S Nikkor 24-70mm f/2.8G ED Phase One Capture One Pro
And got a way better camera (for some), good for you. I think its fabulous that prices have come down so, largely due to competition and resulting Nikon's own D810 and D750.
Will hope to get a used D3s or D4 sometime next year myself, to go with my D610.
Now have a heads up to keep an eye on Fred Miranda sales too.
Enjoy.
Bender73
Don't get me wrong, she aint perfect.  the command dials are a little rough and the rubber is peeling a bit.  But, all of this is ~$600 to bring her back to like new condition and that would be a D4 with new shutter for $2400 investment.  Oh, and a $160 16GB XQD card included.
I have seen these deals out there, you just have to look and buy ASAP.  People always need money fast and have to sell.
NATURALE75 Regular Member • Posts: 319
i got a new one in 2020 with 7500 Clicks
now i have around 8000
You are replying to something I posted 7 years ago.  Usually when this happens (reply to old thread) there's no one here to reply.
I bought a 5k shot D700 in 2018.  Likely it has 20 or 30 more shots on it now.
A Canon G5 and a bit of Nikon gear.
All cameras are so good nowadays, that the good stuff is kinda "given" or "expected". It is the limitations that get to you when you use them in real world situations. Windsurfer LA
