Panasonic 20mm 1.7 ii on epl-5
Started Nov 18, 2013 | Discussions
AngelicBeaver Contributing Member • Posts: 804
The banding is camera dependent.
It has to be camera dependent.  Check out DPreview's review of the EM1.  They test the 20mm on the EM5 and the EM1 at high ISOs.  There is definite banding in the shot by the EM5, but almost no banding in the shot from the EM1.  Same lens, different cameras, different results.  They must have figured out something and made a fix.
My EPL5 also demonstrates banding at higher ISOs.  I'm looking forward to testing it out on the EM1.
I have no signature.
 AngelicBeaver's gear list:AngelicBeaver's gear list
Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Panasonic Leica 100-400mm F4.0-6.3 ASPH
Ulric Veteran Member • Posts: 4,559
Re: Panasonic 20mm 1.7 ii on epl-5
Verbatimium wrote:
Just watch out at higher ISOs...
I had the 20mm (older version) on my PL5 and I had the notorious horrible banding issue with it at higher ISOs of 1000+. Ruined too many pictures for me so I got rid of it for the Oly 17mm and never looked back. The problem was never fixed with the newer version of the lens.
If you use this combo in decent light environments and do not shoot above 1000 ISO, it is a great set. If you like low light photography, then forget it.
My experience is that the banding can happen at any ISO setting. The net result is a huge reduction in useable dynamic range, because the way to avoid the banding is to drown it. I.e, where you would otherwise get noise in the shadows, you get banding long before the noise becomes an issue.
The banding can occur on any body using a particular, otherwise excellent, Sony sensor: Olympus E-M5, E-PL5, E-PM2, E-P5 and Panasonic GH3.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
OP agc73 Regular Member • Posts: 167
Just to back up the debate about banding: the shots below are taken with the epl5 and new 20mm 1.7 and show banding at ISO 1600 & 3200.
Iso1600 banding top right quarter of PIC.
ISO3200 banding example.
 agc73's gear list:agc73's gear list
Fujifilm FinePix X100 Canon PowerShot S110 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85
Anders W
Anders W Forum Pro • Posts: 22,144
Re: The banding is camera dependent.
It's a known issue with the E-M5, E-PL5, E-PM2, E-P5, and GH3. However, the very latest top-level cameras, the E-M1 and GX7, are both unaffected according to DPR testing:
http://www.dpreview.com/forums/post/52184609
http://www.dpreview.com/forums/post/52355175
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
Anders W
Yes, the banding is latent even at lower ISOs but you'd be hard pressed to see it at those ISOs unless you start pushing the shadows.
Some ideas about how to reduce if not completely eliminate the banding at the stage of shooting here
http://www.dpreview.com/forums/post/50092818
and some ideas about how to reduce its visibility in PP in this thread
http://www.dpreview.com/forums/thread/3532757#forum-post-52061838
Note, with regard to the first link, that it appears to be the lens rather than the camera that benefits from being "warmed up" before shooting and that you don't actually need to shoot images to do so. Exercising the AF mechanism a bit (some 5 to 10 AF cycles) appears to do the trick. I should also mention that I am still uncertain about how well this method generalizes to other copies of the lens and body than my own. So YMMV. Furthermore, it is clear to me by now that it doesn't remove the banding completely. However, it tends to reduce its visibility by reducing the likelihood that you get broad, low-frequency banding of the kind illustrated in the post I link to.
Henry Richardson Forum Pro • Posts: 21,959
Yes, you have banding too
Yes, you have the banding problem too.  The 20mm is such a nice lens, but it is extremely disappointing and annoying that it has this banding fault with many of the m4/3 bodies.
http://www.dpreview.com/forums/post/51029028
The only reason I bought the 20mm was for low light shots street photography when I travel and because of its small size.  That is precisely where it fails.  There was a lot of hope that Panasonic would fix the version II when it came out, but they didn't.  They have known about this problem for a long time.
Henry Richardson
http://www.bakubo.com
Asanee Junior Member • Posts: 39
I also bought E-PL5 and 20mm f1.7 II. Both are silver.
I love pictures taken with this camera and lens.
Here is my E-PL5 with 20mm f1.7 II.
I added a custom leatherette kit, Olympus large grip for E-P3, and Olympus leather hand strap.
Mais78 Senior Member • Posts: 1,231
This pictures are bad first and foremost because the ISO is too high, the banding is secondary, without the banding they would still be bad. In low light with M43 you can shoot decent picture until ISO1600 max, anything above that is bad. At ISO 1600 there is no banding unless you spend 5 mins in LR to artificially show it, so no issue. In good light you can shoot up to ISO3200 or 6400. In good light there is no banding, so no issue in this case as well.
There are very rare occasions where banding ruins a good picture. Nothing that should prevent people from buying and using this lens. furthermore the newest sensors (EM1 and GX7) don't show any banding. Bodies come and go, a lens is for the long term
 Mais78's gear list:Mais78's gear list
Olympus OM-D E-M5 Sony a7R III Olympus M.Zuiko Digital 45mm F1.8 Panasonic 20mm F1.7 II Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +2 more
