Panasonic 20mm 1.7 ii on epl-5
Started Nov 18, 2013 | Discussions
agc73 Regular Member • Posts: 167
After a bit of online research I ended up recently purchasing the new Panasonic 20mm 1.7 ii lens for my epl-5.
Like a lot of others on these forums I was tossing up between the Olympus 17mm, Panasonic 20mm, 25mm and 14mm lenses. I ended up going for the 20mm due to the constant postings of how the 20mm "has stayed on my camera since I got it...". I also thought the focal length of the 20mm, which is close to a Sony 35mm 1.8 I used to have on my Sony a57 that I always liked but also felt like having another few mm width would be nice.
When doing my web research I read a couple of good reviews (SteveHuff particularly) that covered all the image quality, slow focusing etc but not so much on what the lens looks and feels like on a silver epl-5 so I've taken a few pics to help others going down the same track as I did. As well as pics of the camera and lens I've also added one of a filthy mirror that also shows what the camera looks like when the 20mm is mounted to the epl-5 while in my front shorts pocket as an example of size.
One thing I noticed compared to a 20mm 1.7 ii I tried out in a shop (it was part of a GX7 kit) was that the lens cap is thinner on the one I purchased. My lens cap is unleashed from the 20mm by two tabs on its side whereas the 20mm off the GX7 had a lens cap that had a central pinch mechanism. I'd say my version is half the width when on the camera (keep in mind its been roughly two weeks between lens caps so I may be slightly off).
Epl-5 with 20mm 1.7 ii Silver front view.
Epl-5 with 20mm 1.7 ii side view.
Epl-5 with 20mm 1.7 top view.
Epl-5 20mm 1.7 ii in hand.
Epl5 with 20mm 1.7 in front shorts pocket.
All pictures taken with a Canon S110 (a great truly pocketable camera).
 agc73's gear list:agc73's gear list
Fujifilm FinePix X100 Canon PowerShot S110 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85
Olympus PEN E-PL5 Panasonic 20mm F1.7 II
Ulric Veteran Member • Posts: 4,559
Re: Panasonic 20mm 1.7 ii on epl-5
I see that you hurt your knee carrying the camera in your pocket.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
eastvillager Senior Member • Posts: 1,338
Great photos. Thanks for posting.
 eastvillager's gear list:eastvillager's gear list
Sony a9 Sony a7R III Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 +3 more
Verbatimium Forum Member • Posts: 60
Just watch out at higher ISOs...
I had the 20mm (older version) on my PL5 and I had the notorious horrible banding issue with it at higher ISOs of 1000+. Ruined too many pictures for me so I got rid of it for the Oly 17mm and never looked back. The problem was never fixed with the newer version of the lens.
If you use this combo in decent light environments and do not shoot above 1000 ISO, it is a great set. If you like low light photography, then forget it.
I didn't know anything about this? Is this just with this camera or other cameras as well. I was thinking of getting one of these for my GX7. I shoot a lot of higher ISO pics. How weird. Is this a well documented issue?
baxters Veteran Member • Posts: 5,319
Banding? It's there, maybe. Maybe not.
I have the first version of the lens, where users first noticed banding on the EM5. It must be highly variable between samples, as it's never been a problem for me on EM5 or EPL5.
If I take the EPL5/20mm to the back of my basement, where the exposure at ISO6400/F1.7 is 1/30 second. I get this awful picture, but I don't notice banding.
Here's a better room (wish it were my house) at ISO 3200 with natural room light with the EM5. If I play a bit with Lightroom and I can see some banding to the left of the chair.
Too good of a lens to tarnish with the banding label. Banding exists. It may not be bad on a given sample.
Last picture and there's plenty of banding in the black areas. Can be seen if I lighten them. Why would I do that. It was dark.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
Barry Stewart
Barry Stewart Veteran Member • Posts: 9,147
I see a band in the last shot
Barry
 Barry Stewart's gear list:Barry Stewart's gear list
Olympus E-1 Olympus E-M1 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +6 more
It is an odd issue that arises when using the 20mm lens with the newer Sony 16mpx Sensors. It is a well known issue, and even Olympus has commented on it that they will investigate the problem. Panasonic has also indirectly admitted it as in the GH3 (which uses the Sony sensor) manual, they state that there may be banding at higher ISOs with the Panasonic 20mm lens, and their solution is to use lower ISOs.
It didn't happen all the time with my PL5. I had some nice shots at + 1600 ISO with no banding at all. But other times, it ruined a whole set of pictures for me. I just got fed up with it and sold it.
Jorginho Forum Pro • Posts: 15,370
On my EPl only 3200+.
No text.
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
47872Mike Regular Member • Posts: 222
Yes, the banding with this lens on the OM-D, E-PL5 and E-PM2 is well-documented, although some users seem to find little problem with it. From reading everything I can about it recently, I think there are clearly all sorts of variables at play...quite apart from the photo composition, the temperature seems to be a factor and there may well be differences between different examples of lens and camera. Some users report differences according to camera firmware version. Lots of people don't shoot much in low light and may have low expectations when they do.
For me, I find that obvious and intrusive banding is an ever-present danger when shooting outside at night as low as ISO 1250, but it isn't always present and varies from shot to shot. In dull daylight or indoor lighting, I find that band-free ISO 2500 seems almost a given, even if, for now, I still have a tiny bit of doubt about the outcome when I go above ISO 1000. When I've shot this lens at very high ISO, the banding becomes even more obtrusively obvious...I no longer do this, which is a great shame.
I have an E-PM2 and find this a definite limitation, since I enjoy shooting outdoors in low light. Updating the camera firmware didn't affect the issue at all, although some users have suggested that they now consider it "cured" after previous problems.
Feel free to report how yours is in this regard.
 47872Mike's gear list:47872Mike's gear list
Canon EOS 20D Canon EOS 50D Konica Minolta Maxxum 7D Sony SLT-A37 Canon EOS 6D +12 more
This is a post of someone testing the new version of the 20mm right after it came out. Problem is NOT resolved. I had 20mm version 2 on preorder hoping the issue was fixed, until I saw this post....
http://www.dpreview.com/forums/thread/3528108
Mais78 Senior Member • Posts: 1,231
I have the 20mm f1.7 II on EM-5
And banding only shows above ISO 3200 when you open the shadows a lot. In practical terms it is not an issue. It is just an issue when you are trying to fix a picture that should be already in the garbage.
 Mais78's gear list:Mais78's gear list
Olympus OM-D E-M5 Sony a7R III Olympus M.Zuiko Digital 45mm F1.8 Panasonic 20mm F1.7 II Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +2 more
Re: I have the 20mm f1.7 II on EM-5
Not in my experience with the lens. Showed up strongly for me in ISO 1000 shots of properly exposed images. However it was only seen in the shadows.
that's a pity, maybe the E-M5 handles the banding better, absolutely no issue at ISO 1000
This is absolutely not my experience at all, but it depends what and how one is shooting.
For me it is a surprisingly large issue and actually worse than I expected, but everyone should make their own tests on their own equipment, with their own shooting style etc.
Henry Richardson Forum Pro • Posts: 21,959
Yes, 20mm on E-M5 banding is real
See this post:
http://www.dpreview.com/forums/post/52357014
The Panasonic 20mm lenses can cause banding when used with several bodies.  I think the E-PL5 is one of them.  If you don't shoot at higher ISO then you are unlikely to have any problems though.
Henry Richardson
http://www.bakubo.com
with the EM-5? Maybe it is camera dependent
LMNCT Veteran Member • Posts: 4,908
It seems that the banding issue is tied to specific camera bodies, not necessarily the lens.  I use two 20 1.7 lenses on a GF1, GX1, GH2, GX7, EM5 and EPL5 and have had no problems at all.  Could it have something to do with the issue date of the bodies, or the lenses?
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
ulfie Veteran Member • Posts: 3,299
Is that a ...
Is that a PEN in your pocket or are you just glad ...
markintosh13
markintosh13 Veteran Member • Posts: 4,951
Nope. At least not with the PL5.
ISO 2500 - SOOC jpeg - banding.
And on a camera where ISO 3200 is otherwise useable.... banding. It's less obvious on these downscaled samples, but in the originals it's really bad.
This "don't use high ISOs and you'll be fine" advice isn't super helpful when the camera is otherwise capable of a very decent ISO 3200 - 6400 with every other lens.
