Advice needed for next purchase
Started Nov 17, 2013 | Questions
Torogoz
Torogoz Regular Member • Posts: 114
I am about to come into some money that I want to invest in improving the quality of my images. My budget will be about $1000, and maybe $1200 maximum.  I'm not a pro, just an enthusiast that likes to take pictures.
I currently have the following equipment:
Panasonic G5 camera
14-45mm f/3.5-5.6 standard zoom
45-175mm f/4-5.6 power zoom
100-300mm f/4-5.6 long tele zoom
25mm f/1.4 PanaLeica fast prime
45mm f/2.8 PanaLeica macro (which I also use for some portraits and as a short tele).
I shoot sometimes in jpeg, sometimes in RAW, depending on how much time I want to dedicate to post-processing with Silkypix (I've never tried Lightroom).  Shooting in jpeg does require more time in preparation/camera settings/pre-processing, but less time in post.  The G5 allows me to preset 4 custom modes to save time, and I'm not above using some of the "scene modes" or "creative modes" that come with the camera.  You can look at my gallery to see the kinds of things I shoot, but it's a bit of everything.  I do about 40% of my shooting with the standard zoom, 25% with the 25mm, and about even with the rest of the lenses.  I don't have another camera body.
My choices to improve my equipment would be:
1) get the Panasonic 12-35mm f/2.8 and replace my 14-45mm (get 2/3 of a stop better on the wide end, better OIS);
2) get the Panasonic 35-100mm f/2.8 and replace my 45-175mm (get 2 stops better at 100mm);
3) get the GX7 to obtain IBIS for the 25mm prime, plus a better sensor (1 stop better, maybe?) better viewfinder, better processing engine, and wi-fi (don't know how much I'd use the wi-fi, honestly, and I may miss the grip and ergonomics on the G5);
4) save my money, and then get the LUMIX G7 (or whatever) when it comes out.
I will appreciate your advice and comments.  Remember I'm a hobbyist, not a pro, so the only person I have to please is myself.
Torogoz
 Torogoz's gear list:Torogoz's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Panasonic 12-35mm F2.8 II Panasonic 100-300mm F4-5.6 II +2 more
Michael J Davis
Michael J Davis Veteran Member • Posts: 3,755
Re: Advice needed for next purchase
[snip equipment]
What do you mean "improve the quality of my images"?
What size prints do you require?  Because with that range of equipment, I would suspect that there is something wrong with your technique rather than the equipment.
I have used (and still use) a Panasonic G1 and recently a OMD E-M5, and I have had no difficulty getting prints up to 24" x 20" - from a good image - and good means noc camera shake and proper exposure. I got the OMD for low light stuff where the noise on the G1 obtruded.
So please explain your technique and types of images rather than going on about how much to spend!!
Mike
Mike Davis
Photographing the public for over 50 years
www.flickr.com/photos/watchman
 Michael J Davis's gear list:Michael J Davis's gear list
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +6 more
jalywol
jalywol Forum Pro • Posts: 12,301
You have a nice kit of gear there. Before you spend more money on MORE gear, you may want to do an assessment of what you are looking for that your current gear does not give you? Unless you know what you are looking for, and why, then you are just going to be spending money without necessarily optimizing your returns....
Given that, I would ask yourself:
  1. What are my most frequent shooting situations (low light, night, portrait, wide angle, scenery...)?
  2. With the gear I have now, what do I find I can't do that I want to?
  3. Do I find I am always looking for a particular lens, or focal length that I don't have now?
  4. What are the most consistent problems I am having (blur, focus, noise)
If you can narrow down what you DON'T like with your current kit, and what you most want to improve, then you will be able to figure out what equipment will be most likely to fill the gaps you have now in your system. If you just go and buy more stuff because it is supposed to be "better", then you are not necessarily making the wisest use of your money....it would have to be better enough in an area that is important to you for it to make sense to buy.
Since you like the ergonomics of the G5, then my suggestion would be to look into the GH3, if you wanted a better performing sensor, or to wait for the G7 to come out. I am assuming that Panasonic will put their newest sensor (the one in the GX7) into the G7, and if so, you will have a real update of your G5 while keeping the form factor that is most comfortable for you.
In terms of lenses... the 14-45mm is a very good zoom, but is not fast. If you find you want to use your zoom in lower light situations, the 12-35mm might well make the most sense as an upgrade. Again, this depends on your useage....
Don't get caught up in a good case of G.A.S.....evaluate your needs and purchase your next gear based on what you actually will get the most use out of, rather than just to find a way to spend the extra $ that you have at the moment.
-J
ryan2007 Forum Pro • Posts: 12,001
First and foremost what I have to say will not be music to your ears. Remember you said you have to please your self.
With respect.
If you are not able to get quality images with what you have spending more money will not make you a better photographer.
None of this has to do with the camera or lens. You can take killer images with a Canon G 16 p&s, it is knowing how to use what you have to your advantage. It is also knowing that your 100 yards from the subject and not even the 100-300 at the long end is going to completely fill the frame especially at a slow f 5.6.
So I would say keep shooting you have lots of gear and their is no reason for you to do anything.
OK
With That here is what I would do IF I truly wanted to make some upgrades
First, no one shoots every single focal length all the time I know you have a certain subject matter you shoot 80% of the time and the rest you can take it or leave it. Sell those lenses to fund the upgrade, it is not like you can never buy that lens again.
Keeping with the Panasonic Theme:
My kit would look like this:
GH-3 will balance the 35-100 better than the rangefinder style body of the GX-7
So..
7-14 if you do wide
12-35 is a great main lens
35-100 if you need telephoto and portraits
45 2.8 for macro, or product photography. If you have the 35-100 2.8 You Do not need this lens as a general purpose, that 35-100 does the same job
You only need that 25 1.4 for low light stuff, the 12-35 covers this range.
In short,
Sell everything and start over to consolidate.
Panasonic G5 camera
Torogoz
Torogoz
OP Torogoz Regular Member • Posts: 114
Thank you, jalywol.  Much appreciated.
beomagi Senior Member • Posts: 1,372
Whatever you do go with, keep in mind that you're not on just the Panasonic system, but the Micro four thirds system. You don't have to restrict yourself to one brand of gear. Olympus lenses work well on Panasonic cameras and vice versa.
You have decent lenses and a good camera, so why not consider a flash? going manual flash is cheap.
Idea is somewhat based off pictures in your profile.
http://www.amazon.com/Yongnuo-YN-560-Speedlight-Flash-Nikon/dp/B0079M711S/ref=sr_1_1?ie=UTF8&qid=1384724748&sr=8-1&keywords=yn-560+ii
You can use some cheap wireless triggers like these
http://www.amazon.com/CowboyStudio-NPT-04-Speelights-extra-receiver/dp/B005IQRMN4/ref=sr_1_1?ie=UTF8&qid=1384724784&sr=8-1&keywords=flash+trigger
Bounce the flash off the ceiling for nice indoor lighting, or use a diffuser and add some light to macros when on the move outside.
Another possibility is a close up lens which can let you get up closer for macro shots. Not all of them are poor quality. A raynox DCR-250 is excellent.
http://www.amazon.com/Raynox-DCR-250-Super-Macro-Snap-On/dp/B000A1SZ2Y/ref=sr_1_1?ie=UTF8&qid=1384725696&sr=8-1&keywords=raynox+dcr-250
Canon's close up lens also works well.
http://www.amazon.com/Canon-250D-Close-up-A710IS-Cameras/dp/B000050M6M/ref=sr_1_4?ie=UTF8&qid=1384725741&sr=8-4&keywords=canon+close+up+lens
One more thing you can try for a pittance is a manual 50mm. Manual isn't for everyone, but I've grown fond of it.
e.g.
a canon FD 50mm F1.8 is <$20
http://www.keh.com/camera/Canon-Manual-Focus-Fixed-Focal-Length-Lenses/1/sku-CA060104001970?r=FE
An adapter is also fairly cheap
http://www.amazon.com/RainbowImaging-Adapter-Olympus-Panasonic-DMC-GF1/dp/B003MDWG68/ref=sr_1_2?ie=UTF8&qid=1384727147&sr=8-2&keywords=fd+to+micro+adapter
Together you can spend under $30 for a good cheap manual bright short tele.
 beomagi's gear list:beomagi's gear list
Canon EOS 5D Olympus PEN E-P3 Olympus OM-D E-M10 Canon EF 50mm F1.8 II Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +5 more
Steve_
Steve_ Senior Member • Posts: 2,876
1, then 2, then 3
You've numbered them correctly. Your G5 is servicable enough that I'd get the 12-35 as it covers more shots than not. After that, the 35-100 to maintain that IQ into the telephoto range. And finally, a new body. If it's still the GX7 to wish for by then, or whatever.
 Steve_'s gear list:Steve_'s gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic Lumix G 14mm F2.5 ASPH +13 more
Corkcampbell
Corkcampbell Forum Pro • Posts: 18,895
Just to add to the comment about Oly lenses - Sigmas also work well.
I have all three, and consider the 60mm to be the best deal available in this format. I use them, and my Pany and Oly lenses on cameras from both makers.
As for the OP, the advice given by a couple about focusing on photography before the hardware is good; if the OP really wants to spend money, a GH3 or EM-5 would be good choices for sensor upgrade, with the GH3 allowing for enhanced video capabilities in case that need should appear. The prices on both have been coming down recently. I have both and, considering what the OP said about ergonomics, the GH3 would be the choice here. Both are weathersealed, robust, with the GH3 having incredible battery life and an available grip.
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony RX100 III Sony RX10 III Leica C-Lux +8 more
Torogoz
e.g.
Thank you very much for your suggestions!
I already have a TTL flash, and I am considering a wireless trigger.  Maybe, as you suggest, I should just get a wireless trigger, and wait for the next generation body to come out.  The gear I do already have is pretty good, just a little limited in low-light capability, so I could just save the money for now...
Eyvind Regular Member • Posts: 227
I leave it to better qualified m43 specialists to comment on equipment, GAS and lens lust, but I would strongly recommend you to buy Lightroom 5 and Scott Kelby's book on it and spend some time with it.
You'll get organised, and most importantly, get improved post processing skills. I know I most likely will get some 'a polished turd is still a turd' comments, but I think this would provide you with the best return on investment in terms of IQ in your final results - and you will have money left for some new equipment as well...
Eyvind
jeffharris
jeffharris Forum Pro • Posts: 11,409
Your kit looks good. Buying more gear won't improve your images.
What do you feel needs improvement in your pictures? Work on that.
I second the recommendation for getting Lightroom and the Kelby book and learning to use it.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
JBurnett Contributing Member • Posts: 835
Your hardware is fine, how 'bout a little software & training?
Best bang for your buck...
I suggest Lightroom (and shooting in RAW), and really spend some time to learn it. Learning how to post-process well can take your pictures from out-of-camera snapshots, to images that truly show what you saw, or what you want to convey to the viewer.
In addition to Lightroom, I use Photoshop Elements, primarily for its layers capabilities. There are certain things for which I find layers to be better or more efficient than LR4. You could also consider OnOne's software suite, which has layers capabilities, a number of other post-processing aids, and lots of helpful "pre-sets". Many photographers rely on the NIK software suite, as an alternative.
In terms of hard dollars, the cost will be less than a new lens. And the software (and the effort you put into learning it) will benefit ALL of your images -- not only in improving them post-shot, but, long-term, in helping you to "visualize" images before you make them.
 JBurnett's gear list:JBurnett's gear list
Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +4 more
Ulric Veteran Member • Posts: 4,559
You have a nice kit. If you can't decide what you want, perhaps the best suggestion is to sit on the money until you can.
Or don't buy any new gear? Buy a ticket somewhere, $1000 will get you pretty far.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
e.g.
Just keep in mind most cheap wireless triggers will not support TTL. I'm still on my EP3 which is pretty much the same capability as your sensor. Fast lenses and flash are keeping me going till the year after next, when I plan to upgrade to a used em5 or the new OMD that's rumored to be "lower cost".
LincolnB Veteran Member • Posts: 4,390
Accessories????
When you list your equipment, you don't mention Photoshop, a tripod, monopod, speedlights, strobes, wireless triggers, light modifiers, reflectors, light stands, light meter, color calibration tools, etc. You don't have Lightroom. You don't seem to have any of a number of accessories that could trigger a quantum increase in the quality of your photos. You don't mention books, seminars, videos, workshops, etc.
I suggest spending the majority of the money on something other than glass or a new body.
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Sony a7 II Sony a7 III +8 more
