GX7- What settings are you using for contrast, Sharpness, Saturation etc.
Started Nov 13, 2013 | Discussions
photoshooter1 Regular Member • Posts: 421
Question: What settings are you using for contrast, Sharpness, Saturation etc.
GX7- What settings are you using for Contrast, Sharpness, Saturation, Picture Style etc. or are you using curves?   took my  first pics at high ISO settings but pics look a little soft and not well saturated . Using kit tele lens.
 photoshooter1's gear list:photoshooter1's gear list
Sony RX100
Panasonic Lumix DMC-GX7
greenarcher02 Forum Member • Posts: 70
Re: GX7- What settings are you using for contrast, Sharpness, Saturation etc.
I keep it at default because I always process RAW and I don't think it has any bearing on it.
I could be wrong though. So I hope others reply. I know I tweaked my GX1 so I'm guessing I should do it too on the GX7.
 greenarcher02's gear list:greenarcher02's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Panasonic 20mm F1.7 II +1 more
JosephScha Veteran Member • Posts: 7,249
You beat me to it
I was going to write,,those questions assume we're shooting jpeg.
I'm enough of a control freak that I shoot raw.  I do not believe that the battery powered processor in the camera can, in a fraction of a second, determine optimal white level, black level and white balance so consistently that I can't do better using Adobe Camera Raw.
If you haven't tried it, and if you can develop from raw, I suggest you shoot "raw + jpeg fine" for a while.  Whenever the JPEG isn't everything you hoped for, try converting the RAW image to jpeg. I think you'll be pleased with what you can easily do.  In fact, I think you'll end up shooting RAW (almost) exclusively, like me.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
Re: GX7- What settings are you using for ... Sharpness
Shoot fast enough. Follow the old rule about 1/focal length being slowest shutter speed.  200mm focal length?  use 1/200 second.  It's very conservative, IS can help by a stop or two.  But if you do this your images will be sharper.
For static scenes where that suggestion can't be done, I use a tripod for sharpness.
js
GeorgianBay1939
GeorgianBay1939 Veteran Member • Posts: 4,044
I am also a RAW, ETTR shooter and therefore shoot zero'd / default jpeg parameters.  I don't shoot UniWB as I find AWB with a bit of "english" works just fine.   I also chimp a lot.
If you are contemplating shooting RAW I suggest that you'll save yourself a lot of frustration by reading Gollywop's Exposure Vs Brightening .  It will save you a lot of frustration.
I have been shooting RAW for about a year now and both the quality and my enjoyment of my photography have improved significantly.
Tom
 GeorgianBay1939's gear list:GeorgianBay1939's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Panasonic Lumix G Vario 7-14mm F4 ASPH +9 more
And in case it's out of the question shooting RAW (but it's the general consensus that you do), I use the Natural photo style at default with both i.Dynamic and i.Resolution turned off, and AWB at default [I use this for deliberating bad shots from good shots on a PC since thumbnails for RAW files doesn't show up]. The GX7 does a better job than the GX1 in terms of JPEG's I found no reason *yet* to change the default values.
But for comparison, I used to have NR -1 and Contrast +1 on the GX1 with AWB adjusted to A+2/M+1, or A+1/M+2.
But I decided to shoot RAW since I had some sort of "Olympus envy", and during that time before the E-M5, it was general knowledge that Olympus will always have better JPEG's but Panasonic will always have better RAW. So I thought, why not utilize my camera to the fullest? So yeah, I suggest learning how to edit RAW files, it's worth it.
OP photoshooter1 Regular Member • Posts: 421
Anyone shooting JPEGS? GX7- What settings are you using for contrast, Sharpness, Saturation etc.
No text.
Sony RX100
Jed Perkins Regular Member • Posts: 337
Re: Anyone shooting JPEGS? GX7- What settings are you using for contrast, Sharpness, Saturation etc.
Bumping this back to the top to see if we can get any GX7 JPEG shooters to offer their settings. I have the GM1 and am interested in preferred JPEG user settings for that camera, but their are probably not enough of them out their yet.
PLEASE no more recommendations to just shoot raw. I know how to shoot and proces raw files, I am interested in peoples preferred JPEG settings
I would like to apply a profile for sharpening and NR in LR when I import, and not have to bother with more image processing.  I shoot in a lot of high contrast conditions and would like to take advantage of the GM1 iDynamic or HDR options but would prefer to do the sharpening and NR in LR.  Should I just turn in camera sharpening and NR all the way down to -5.  I would basically like to turn these off in camera while letting the camera do other picture processing (color balance, dynamic range adjustments, etc.)
Any suggestions.
jed
caver3d Contributing Member • Posts: 915
Any suggestions.
I have the GX7.  I'm one of those photogs who happens to like more full color, saturated photos.  I know many of you do not, but that is just my preference.
Settings I use much of the time (not always):  Vivid, Contrast +1, Sharpening 0 (sometimes +1), Saturation +1 (sometimes 0), NR -2.  I want my photos to pop more, so that is why I use these settings.  In good light I also use ISO 200.  As for P, A, S, I will use any of these settings depending on what I am trying to do.  In other words, although I like to shoot in Aperture mode, I do not do that all the time.  Usually iDynamic and iResolution are Standard.
caver3d
 caver3d's gear list:caver3d's gear list
Panasonic Lumix DMC-LC1 Panasonic Lumix DMC-LX3 Fujifilm FinePix X100 Sony RX100 II Panasonic FZ1000 +37 more
Enir4 Senior Member • Posts: 2,468
I shoot raw and convert with ACR. At times JPEG pictures have better colors though. I use everything default, with NR at minimum. Caveat, I only had the GX7 for 36 hours.
Is there a better converter for the GX7 than ACR?
Enrique
 Enir4's gear list:Enir4's gear list
Sony RX100 VI Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +1 more
Joel Stern
Joel Stern Forum Pro • Posts: 10,926
Re: You beat me to it
I use a RAW as well, but shoot jpg fine with it. I boost contrast, sharpness, put NR to -5. I play with other custom settings, all in AP but as yet have only shot in standard with the above. I find RAW better but sometimes jog wins, especially with foliage at this point... Probably my learning curve in both aperture and LR5.
If i am typing on my iPad, please excuse any typos.
smithling Regular Member • Posts: 385
I shoot manual 100% of the time. Point the camera's spot meter at your highlights and bump up the exposure to +1.75 or +2. This will make your highlights just about purely saturated, but not quite.
I usually use "Vivid". The jpeg sliders vary due to the nature of the scene and lighting. Saturation +1 or +2, Contrast -1 or -2 (to offset the saturation boost, or vice versa), NR -5 always, and sharpen varies depending on lens and/or subject.
The best thing to do is test your settings with whatever subjects you usually shoot. See what you like.
edit: oops forgot to say that I use Vivid.
David Kieltyka
David Kieltyka Veteran Member • Posts: 6,450
I shoot RAW + JPEG...the RAWs for printing, the JPEGs for screen display & online. But I always process even the JPEGs so I want a fairly flat file I can tweak a bit. I use the Normal color profile with sharpness & contrast at the lowest setting. Everything else at mid-point. I also dial in a subtle reverse S-curve (+1 low mids, -1 high mids) to preserve more midrange tonal info. For monochrome I use a simulated yellow filter with all other settings the same as above. IMO the GX7 creates very nice b&w files.
-Dave-
 David Kieltyka's gear list:David Kieltyka's gear list
Leica M9-P Leica M8.2 Pentax 645D Pentax 645Z Panasonic Lumix DMC-GX8 +9 more
JimB630
JimB630 Regular Member • Posts: 397
I am  JPG shooter. Because I am colorblind, I do not have a lot of success working with RAW files.
I just did some testing with my 3-week old GX7. My first pics were taken with standard out-of-the-box settings. My initial reaction was not good when comparing ISO 800 pics to my Canon 30D. In low light, hair looked like a watercolor painting.
So, I did a little research and set the camera with Sat +1, Sharp +1, Contrast +1 and NR -3. I took a few more pics at ISO 800. I was still seeing a little too much noise reduction. So, I set NR to -5, and I am much happier. Compared to my 30D, the noise is finer and less blotchy. My wife also says that the colors are much more true on the GX7.
I have not had time to do much more than this, but I initially thought there was no way I could go to anything higher than ISO 800. Now, I look forward to seeing how the higher ISOs are handled.
Jim B in Indiana
 JimB630's gear list:JimB630's gear list
Canon G1 X III Canon EOS 6D
David Kieltyka
Jim, since the post you've replied to I've backed off the saturation to -2. But, as I noted, I do some post-processing work regardless of whether I'm using RAW or JPEG data so I like to start with a flatter-than-normal look.
The GX7 has a surprisingly film-like noise profile in the ISO 400–3200 range. Very little chroma noise, and what there is can be dialed out without causing artifacts. This was a pleasant & welcome surprise since I like a bit of texture in my photos, especially for printing.
Electronic cameras have come a long way in the past decade!
-Dave-
gteague
gteague Veteran Member • Posts: 3,005
i have yet to improve on the defaults, but i haven't shot any raw yet until dxo gets a module ready for this body/lens combination. i do however plan to heavily use the 'dynamic monochrome' setting that panasonic has done so well with many of their models.
/guy
"The world is going to pieces and people like Adams and Weston are photographing rocks!" ~Henri Cartier-Bresson
 gteague's gear list:gteague's gear list
Leica Q2 Leica CL Panasonic S1 Panasonic S Pro 70-200mm F4 OIS Panasonic Lumix S Pro 16-35mm F4
JimB630
I am trying to get my color straight OOC to where my wife says it looks good. I cannot do much with color in post due to the colorblindness. I am good with other post, and I do a lot of B&W processing.
Yes, I am pleased with the noise that is present, especially compared to my 30D. I think when it seems a problem it will be handled much better in post than in-camera.
I almost feel like I am starting over after using my 30D since 2007!
Jim B in Indiana
Terrence5050 Forum Member • Posts: 51
The question was about jpeg settings not raw want to know what jpeg settings to use the raw information was useless to us I don't know why you put it in a thread
Again this is a threat about shooting the best jpeg settings in the gx7 please stop telling people to shoot Raw that's what not what we're interested at this. Thread..
larsbc Forum Pro • Posts: 18,282
(You're necro'ing a 5-yr-old thread.)
