Sigma DP1M vs. Ricoh GR
Started Nov 10, 2013 | Discussions
carlos roncatti
carlos roncatti Senior Member • Posts: 2,668
Re: Sigma DP1M vs. Ricoh GR
PrebenR wrote:
carlos roncatti wrote:
If i understand correctly..they are all jpegs...and the only raw file from the GR is an in-cam conversion...
do you want same everything...i think this may help...
http://www.dpreview.com/reviews/ricoh-gr/16
Problem is that the DP1M files are not processed correctly.
If there is one thing i learned, specially from this forum, is: do you your own experiments, do not trust other peoples experience regarding cameras. As for dpreview, i trust them and IR, a website that shoots under the same condition, the same scene for years now. And you can download their files and process them to taste
Here we have jpegs from two cameras and the GR has a wide converter!!! its pretty clear this is not a proper comparison.
BTW, what settings dpreview did wrong? thanks.
To understand photography, you must understand that the experience must be much more important than the result ....
Carlos Roncatti Bomfim
http://www.youtube.com/watch?v=wwTyj2W9NwI
http://www.crbimage.com
PrebenR Veteran Member • Posts: 3,529
Thanks for the comparison.
The DP1M files are underexposed compared to the GR. Was that by choice?
Would you be willing to make some ISO 800-3200 B&W comparison samples? Would need RAW development though.
Lightwriting with Sigma
OP Membership Expired - Please Renew Forum Member • Posts: 61
I have not learned how to use SPP properly, I need to sit down and really go through the different settings and options in SPP(and how the files behave when I edit them). When I used my SD-14 I only used SPP on good images(so that means rarely).
The pic of the boat is normal/non edited.
@Carlos, both cameras have the wide angle converter on.
Sigma DP1M With a 14,25mm (21mm FF equ.)
Here's a Norwegian DP3M test:
http://translate.google.no/translate?sl=no&tl=en&prev=_t&hl=no&ie=UTF-8&u=http://www.akam.no/artikler/sigma-dp3-merrill/136115&act=url
It's almost funny to read, Google translation
It is not worth reading though. Well, perhaps it is funny to read in English , but reading the original only confirms that the site is not about photography only specs.
carlos roncatti
Thanks for telling me, my bad ...somehow you moved, didnt you?
it seems that with the sigma you managed to have focus on infinity (even with the focus point where you said) but not with the GR...i wonder why...
anyway, thanks for your samples and i hope you didnt mind me for saying you dont need a GR for your style of shooting...  maybe its because i wish i had these both cameras too...
