I think the notion of FF = heavier lens may not be true
Started Nov 8, 2013 | Discussions
EinsteinsGhost
Re: Not exactly.
EinsteinsGhost wrote:
I know I might get some flak for this, but I was just curious about this debate so decided to check out the olympus site.
I know it's not FF, but if the logic is that bigger sensors mean bigger lenses, then it should also be concluded that aps-c lenses will be bigger/heavier than m43.
But after checking the olympus site, their equivalent lenses are heavier. They don't have exact same focal lengths but relatively close.
zuiko 14-54 2.8-3.5 = 440g
fuji 18-55 2.8-4 = 310
zuiko 50-200 2.8-3.5 = 995g
fuji 55-200 2.8-4 = 580g
for comparison, panasonic's closest was the 45-150, but with a slow aperture of 4-5.6 weight = 200g. It's much lighter than both the zuiko and fuji, but has a slower max aperture.
zuiko 35 f3.5 = 165g
fuji 35 1.4 = 187g
panasonic 45 2.8 = 225g
panasonic 25 1.4 = 200g
I know some may not be a direct comparison, but some of them just don't make the same focal length and aperture. What I find interesting is that Fuji is actually the lightest of the bunch, but has a bigger sensor.
It seems to really all boil down to lens design and materials. I think the assumption is also that all else being equal, yes, it glass elements will be bigger to accommodate a larger sensor, but the lens as a whole can still be light by using lighter metals like aluminum and perhaps less glass elements.
Lenses can also get heavier depending in build quality. Use more plastic, and weight with same optics can go down. Lens for smaller format can take advantage of smaller parts, however.
Then there is the reach aspect. I use 200mm/2.8 on APS-c whereas the same reach on FF would require 300/2.8.
The same "reach" (diagonal angle of view) would require 320mm.  But the same DOF and same light projected on the sensor for a given shutter speed would require f/4.5.  So, the better comparison to a 200 / 2.8 on APS-C is a 300 / 4 on FF.  APS-C still comes out ahead in terms of size and weight, however.
Whole both are FF lens, the 200/2.8 is considerably smaller with same metal build and weighs only a third (about 750g).
Again, compare to a 300 / 4, and that advantage narrows considerably, although the advantage still lies with APS-C.
You dont need same total light to be projected on a smaller sensor. Exposure is independent of sensor size. Put 200/2.8 on a FF camera, take note of your exposure variables. Turn crop mode on (I understand Canon can't do it, but Sony and Nikon allow it). Do you expect exposure values to be off by a stop?
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sony 135mm F2.8 (T4.5) STF Sigma 70mm F2.8 EX DG Macro +12 more
CharlesB58 Veteran Member • Posts: 8,766
Re: I think the notion of FF = heavier lens may not be true
This puts it in perspective:
http://camerasize.com/compact/#482.366,487.392,ha,t
While the Sony FE 70-200 f4 is smaller than a comparable DSLR 70-200f4 lens, it's still much bigger than the 35-100 Panasonic for m4/3. The size difference decreases as the focal length changes. There is not that much of a difference between the Panny 12-35 and the Ziess FE 24-70, though the Zeiss is much heavier, which is the case with nearly all Zeiss lenses.
If, in my lifetime, I will have produced just one image that makes a real difference in the life of another, I will have achieved my highest goal as a photographer.
http://ikkens.zenfolio.com/
http://sarob-w.deviantart.com/
Jack Hogan Veteran Member • Posts: 6,507
Promit wrote:
The older 4/3 lenses you picked were widely panned for their size, and rightfully so. Olympus picked a smaller format and reaped little or no benefit from it.
The current m4/3 lenses are very small though, and it's a combination of three things:
  1. Smaller format
  2. Small flange distance
  3. Software correction
It's all of those, together, plus a bit of modern design technique, that gives m4/3 lenses their size and weight advantage. Leaving distortion and CA in the capture and fixing them in software means less glass elements and lighter glass elements. The small flange distance reduces the need for retrofocal designs.
This is a good point, and every format can do that.  Things are in flux, but the mFT guys are pushing the envelope of progress faster than APS-C and FF apparently because they have to in order to be competitive in the market they play in.
Things will tilt back to the mean (where the notion that equivalent FF lenses are heavier may be less true)  once we start seeing simpler/lighter/smaller/cheaper FF and APS-C lens designs that also offload some of the optics onto the camera's DSP.
We live in interesting times.
RedFox88 Forum Pro • Posts: 28,201
Then there is the reach aspect. I use 200mm/2.8 on APS-c whereas the same reach on FF would require 300/2.8. Whole both are FF lens, the 200/2.8 is considerably smaller with same metal build and weighs only a third (about 750g).
No, you would need 300mm f/1.8 on 35mm to compare to 200 f/2.8 on aps-c.  That 300mm lens doesn't exist and would be very big, very heavy, and very, very expensive!
Great Bustard Forum Pro • Posts: 40,847
Re: Not exactly.
fuji 35 1.4 = 187g
You do if you want the same noise performance (for equally efficient sensors) and/or DOF.  And if you don't care about that, then you can compare 200mm on APS-C to 300mm on FF, and leave out the f-ratio all together.
It is. So is the total amount of light projected on the sensor (depends on the aperture diameter, as opposed to the f-ratio).
Here we are:
http://www.josephjamesphotography.com/equivalence/index.htm#exposure
This section will answer the following four questions:
  • For a given scene, what is the difference in exposure, if any, between f/2.8 1/200 ISO 400 and f/5.6 1/200 ISO 1600?
  • What role does the ISO setting play?
  • What role does the sensor size play?
  • What does any of this have to do with the visual properties of the photo?
As mentioned in the introduction of this essay, the concept of Equivalence is controversial because it replaces the paradigm of exposure, and its agent, f-ratio, with a new paradigm of total light, and its agent, aperture. The first step in explaining this paradigm shift is to define exposure, brightness, and total light.
NexOffender Regular Member • Posts: 328
Different formats have size advantages at different focal lengths. An APS-C 24mm lens is usually bigger than the equivalent 35mm lens for FF, but an APS-C 35mm lens is usually smaller than the equivalent 50mm FF lens. With longer focal lengths the smaller formats usually have smaller equivalent lenses.
 NexOffender's gear list:NexOffender's gear list
Pentax Efina
EinsteinsGhost
Re: Not exactly.
fuji 35 1.4 = 187g
Perhaps that realization is leading you to your usual run about.  This was the question you didn't answer:
EinsteinsGhost
Nope. Try again.
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 15,807
Get off of it
"Usual run about"?
I am quite sure that the Great Bustard is aware that exposure, as categorized by f/stop, exposure time and ISO, is totally independent of sensor dimensions. So there's no need to respond to a tautology.
You can foam at the mouth about equivalance but that doesn't affect its validity.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony RX100 III Nikon D300 Nikon D750 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED +12 more
EinsteinsGhost
Re: Get off of it
"Usual run about"?
You think he is, that tells me you are just as clueless. Prove me wrong by answering the question I posed that your buddy is going to be running around, rest of the way. Whining and crying about my response for the non-sense is not going to cut it.
Hint: Question has to do with exposure values.
Speaking of running about...
The answer I gave before was:
Now let me flesh it out by quoting more from the link:
Mathematically, we can express these four quantities rather simply:
  • Exposure (photons / mm²) = Sensor Illuminance (photons / mm² / s) · Time (s)
  • Brightness (photons / mm²) = Exposure (photons / mm²) · Amplification (unitless)
  • Total Light (photons) = Exposure (photons / mm²) · Effective Sensor Area (mm²)
  • Total Light Collected (electrons) = Total Light (photons) · QE (electrons / photon)
So, we can now answer the questions posed at the beginning of the section:
The exposure (light per area on the sensor) at f/2.8 1/100 ISO 100 is 4x as great as f/5.6 1/100 ISO 400 for a given scene luminance, regardless of the focal length or the sensor size. However, the brightness for the two photos will be the same since the 4x lower exposure is brightened 4x as much by the higher ISO setting. If the sensor that the f/5.6 photo was recorded on has 4x the area as the sensor as the f/2.8 photo (e.g. FF vs mFT), then the same total amount of light will fall on both sensors, which will result in the same noise for equally efficient sensors (discussed in the next section).
If you are still confused, please let us know.
EinsteinsGhost
Re: Speaking of running about...
The answer I gave before was...
Useless, and nothing to do with the question. Have you see these kind of numbers before?
ISO 125, f/4, 1/800s (and yes, I picked these from one of the images in your gallery).
So, what are these numbers? Looking for your awareness.
GodSpeaks
GodSpeaks Forum Pro • Posts: 13,306
These 2 Zuiko lenses are Four Thirds, NOT micro four thirds.  They are a telecentric design which IS larger.
Micro four thirds lenses do not use the same telecentric design, so you should use MFT lenses in your comparison.  The closest of which would be the Panasonic 12-35mm f2.8 at 305g, and the 35-100mm f2.8 at 360g.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
- Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic FZ1000 Nikon D800E Sony Alpha DSLR-A850 Panasonic Lumix DMC-GX7 +47 more
rhlpetrus Forum Pro • Posts: 24,916
Flnge distance and FF
  1. Smaller format
Smaller flange distance for FF would also mean smaller designs for FF, but the cost is there and it may require soft corrections. I'm not sure Nikon and Canon will reduce the flange distance for FF as they move into ML. The mirror box may be gone, but will venerable lens designers adopt that? I think APS-C will ove to a different mount for both companies as Canon has already done, but FF is bit more complicated, as backward compatibility may be seen, especially by Nikon, as essential. They kept its mount even when it looked like a changevwas needed.
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon 1 V1 Nikon D7000 Nikon 1 Nikkor 10mm f/2.8 Nikon AF Nikkor 35mm f/2D +4 more
TrapperJohn Forum Pro • Posts: 16,488
Understand why the earlier 4/3 lenses were so large, and the current ones aren't
The ZD 4/3 lenses have a telecentric light path, which is to say the light coming out of the back of the sensor is perpendicular to the sensor, at a 90 degree angle. That was done specifically to address the vignetting and soft edges caused by the early deep light well sensors. Light at extreme angles wasn't a problem for film, which has no real depth, but it was a problem for the digital sensors of the day, that had fairly deep light wells, which meant light at angles was lost on the way down the well to the actual sensor.
It's why the first DSLR's were APS and not 24x36 - the film lenses available at that time were not telecentric (didn't need to be) but when used on early digital sensors, the image lost definition and intensity the further from the center of the sensor. Easy solution was to make a smaller sensor to crop out the troublesome edges. Hence, the 'crop sensor', that cropped a 35mm image circle to get an acceptable photograph.
Some companies, particularly Canon and Leica, addressed this with microlenses on the sensor to straighten the light out, Oly addressed it by making a lens that straightened out the light. Oly got what they wanted, excellent rendering and razor sharp wide open, but the lenses were larger and heavier, from the thicker barrel and larger internal elements that were required to straighten out the light path.
This isn't needed any more. The latest sensors have shallow light wells that can take light at more extreme angles, which makes the short focal length mirrorless systems possible at all.
For a more accurate size comparison, use the µ43 size optimized lenses like the 45 1.8, 75 1.8, 12-40 constant F2.8, 12-35 constant F2.8, 20 1.7, 17 1.8, etc... they are very small for what they can do.
GossCTP Veteran Member • Posts: 4,751
For a given f stop, the 4/3 lenses are smaller. The issue as I see it, is that people bought into a smaller format, and then wanted to get the same shallow DOF and lower noise that the larger formats did. So then Olympus created beasts like the 35-100 f/2. Over 3.5 lbs and $2500. Certainly a masterpiece of a lens, but in terms of DOF and noise, a 70-200 f/4 on FF would be equivalent and weigh in at just over a lb. Price for a Canon L 70-200 f/4 is running around a grand right now.
I think that f/4 is a sweet spot for lenses right now, regardless of format. Few lenses don't improve in some fashion until being stopped down at least that far. That's my main gripe with micro 4/3. They have super compact slow zooms and top dollar f/2.8 zooms. Higher quality, moderately sized and priced f/4 zooms just aren't there. And if you need a faster lens than f/4 most of the time, you are probably better off with a larger format - up to FF anyway.
Through the window in the wall
Come streaming in on sunlight wings
A million bright ambassadors of morning
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K-5 II Pentax K20D Pentax 16-85mm F3.5-5.6 WR Pentax smc DA 16-45mm F4 ED AL +7 more
EinsteinsGhost
Re: Understand why the earlier 4/3 lenses were so large, and the current ones aren't
The m43 size benefits comes from its crop factor, just as a camera with 1/2.3" sensor can deliver a 35-600mm (equiv) f/2.8 zoom range, again due to crop factor. But, we could also compare lens sizes and weight by focal length (not equiv.).
Minolta 35-105 f/3.5-4.5 N, a full frame lens for example, was 60mm long, with 55mm filter size and weighed 290g.  Whereas, Panasonic 35-105 f/2.8, a m43 lens, is 100mm long with 58mm filter size and weighs 360g. The Panasonic, of course, offers constant f/2.8 zoom which would account for the size gains but the point is ultimately with focal length itself, rather than equivalent FL.
Just another Canon shooter
Just another Canon shooter Veteran Member • Posts: 4,691
NexOffender wrote:
[...]  but an APS-C 35mm lens is usually smaller than the equivalent 50mm FF lens.
The Sigma 30/1.4 (for APS-C) is 430 g. The (faster) Canon 50/1.8 for FF is 130g.
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 70-200mm f/4L IS USM Canon EF 135mm F2L USM Canon EF 100mm f/2.8L Macro IS USM Canon EF 50mm f/1.2L USM +4 more
Oh dear.
Useless...
...to people who lack the ability and/or are unwilling, to understand.
...and nothing to do with the question.
If that were so, then we'd be left with one of two situations:
  • The question is meaningless in terms of the visual properties of the photo.
  • The question ignores the context of what role the exposure plays in the visual properties of the photo.
I must have been using Auto ISO or used ISO 125 by mistake, as I never intentionally shoot intermediate ISO settings.
Well, ISO 125 means that the brightness of the captured photo is amplified by 1/3 of a stop.  f/4 means that the diameter of the lens aperture was 1/4 the focal length of the lens.  1/800 means the sensor was exposed to the light for 1/800 of a second.
What do you think the numbers mean?
(unknown member) Senior Member • Posts: 2,216
Nope. Try again.
Well, they do say that Albert Einstein wasn't very good at arithmetic; but both of you seem to be struggling with basic multiplication and division here. A 200mm f/2.8 lens on an APS-C camera will have very similar performance to a 300mm f/4 lens on a FF camera...
Joe
