PowerPoint slideshow
Started Nov 8, 2013 | Questions
GCOTTERL Regular Member • Posts: 129
I have created a PowerPoint slideshow containing about 150 digitial images (photos).
When I play the slideshow on my PC, the photos look great.  But, when I play the slideshow on a  projector screen, the photos are off-color or dark.
Do I need to set up or configure my PC and/or PowerPoint so the photos look great on the projector screen?
ARShutterbug
ARShutterbug Veteran Member • Posts: 8,978
Get a better projector
The problem is likely to be the fault of the projector, some of which are really bad at displaying accurate colours and gradients.  Did you run a calibration test on your projector from the output device?
WryCuda Veteran Member • Posts: 8,466
Re: PowerPoint slideshow
Digital projectors can fade with time, and have always had quality issues.
HDTVs are very common these days, and connecting your computer to the HDTV might be a better alternative to a projector. Many notebook computers have better resoltion than projectors.
If you don't require the features available with PowerPoint, consider showing you photos directly from a USB stick to the screen; crop 16:9 so they fill the screen. Resolution is 1920 x 1080, and photos look terrific. The new Ultra-HDTVs are 3840 x 2160 which approaches the original resolution of digital photos.
 WryCuda's gear list:WryCuda's gear list
Nikon D7100 Sony a6000 Sony a7
OP GCOTTERL Regular Member • Posts: 129
I want to show the slideshow to 20 people so using an HDTV would not be practicable and my department doesn't have an HDTV)
You can hire projectors.
Mark Scott Abeln
Mark Scott Abeln Forum Pro • Posts: 12,787
I’d try to do a basic calibration of the projector.
Take at look at this manual calibration procedure:
http://www.projectorpeople.com/resources/video-calibration.asp
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +2 more
