85mm lens focus noise anyone?
Started Nov 5, 2013 | Questions
kimmonoj Regular Member • Posts: 169
Hi I have 85mm lens and it makes high pitch hiss like noise when it focuses.
do any of you experience same thing?
thanks
viking79
viking79 Forum Pro • Posts: 14,157
Re: 85mm lens focus noise anyone?
thanks
When mine gets cold it does that (say around 45F or so, but I noticed it was doing it the other day closer to 50F). If it does it too much it could be the motor failing. It is an ultrasonic motor so you shouldn't hear it when operating correctly. If you hear it there is something scraping or slipping and it is probably not ideal.
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
targut Regular Member • Posts: 456
My 85mm one makes the like noises sometimes, but this does not influence its operation.
 targut's gear list:targut's gear list
Samsung NX200 Samsung NX2000 Panasonic Lumix DMC-GM1 Samsung NX 30mm F2 Pancake Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +4 more
Zdman Regular Member • Posts: 236
Never heard a high pitched noise comming from my 85 but I live where its pretty warm.
northlondon43
northlondon43 Senior Member • Posts: 1,941
I've only recently bought the 85mm so only used it 3-4 times. On one occasion I heard a high pitched noise whilst focusing but not the other times. No idea about the relationship to temperature though.
Adrian
 northlondon43's gear list:northlondon43's gear list
Fujifilm X100V Panasonic Lumix DC-G9 Panasonic Lumix G 25mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +4 more
Fuzzfuzz
Fuzzfuzz Forum Member • Posts: 89
I hear it all the time if i have my ear near the lense and when its really quite. If you are young with good hearing you can probably hear it while some older folks(my mum and dad cant hear it) only hear it when its get cold.
I dont think it's something to worry about, i can hear it on all my pentax sdm lenses and some canon usm lenses.
my and my girldriend's photography blogg http://svartvitt.webblogg.se/
 Fuzzfuzz's gear list:Fuzzfuzz's gear list
Pentax K-5 Samsung NX1000 Pentax smc DA 16-45mm F4 ED AL Samsung NX 30mm F2 Pancake Sigma 10-20mm F4-5.6 EX DC HSM +7 more
viking79
This is a point I should have clarified: I hear my lens all the time as a soft chattering/whirring. When it gets cold it actually starts to make a slightly different squealing noise. More like a slipping noise. I would hope it is not the motor slipping, but could just be a rubbing noise of some internal component as well.
Eric
OP kimmonoj Regular Member • Posts: 169
thank you all for answers!
BrendanSeabrook Regular Member • Posts: 101
http://www.dpreview.com/forums/post/42269770
M
y 85 had the squeaks.
Sent it back to Samsung. Took forever. They ended up not fixing it and letting my dealer give me a new copy.
Hasn't come back in the new copy but I haven't used it as much.
arbuz Senior Member • Posts: 2,247
Mine developed this condition few weeks ago. I researched this topic and apparently it is a sign of failing af motor.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
jennyrae Senior Member • Posts: 2,690
any report confirmation of 85mm AF failing or fail?
Mike Mu
Mike Mu Regular Member • Posts: 224
Mine has it every once in a while.  Its kind of disconcerting, and I'm afraid of imminent auto focus failure (or worse).
I'm curious to know if anybody else who has the same problem has had their lens fail.  I'm in Southern California, the temperature I've used the lens in has been fairly moderate.
 Mike Mu's gear list:Mike Mu's gear list
Sony RX100 II Sigma dp2 Quattro Lytro Illum Sigma dp0 Quattro Ricoh Theta S +35 more
warriorpluto New Member • Posts: 7
So my motor is failing? I got mine from ebay.I'm going to return it
I had mine since launch. not sure what focus noise some people are referring to, other than the normal resistance when the optics inside move around during focus. other than that, lens is alive and kicking. I do not believe this is something similar to Pentax SDM.
