K-3 Birding with a sparkle (10 images)
Started Nov 4, 2013 | Discussions
MightyMike Forum Pro • Posts: 37,987
More K-3 bird photos n this gallery
http://www.michaelfastphotography.com/galleries/k-3/birds/firstbirds/
Don't be afraid to shoot against the sun
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
Pentax K-3
Dale108
Dale108 Veteran Member • Posts: 7,198
Re: K-3 Birding with a sparkle (10 images)
 Dale108's gear list:Dale108's gear list
Pentax K-1
Donald B
Donald B Veteran Member • Posts: 9,054
cant complain about them Mike, are you shooting continuous caf and picking the best shot ? or shooting single shot with button half pressed while tracking ?
cheers don
Pentax K7, Panasonic fz150, Olympus XZ1, my main toys.
jm_mac Senior Member • Posts: 2,044
In your experience, would the K5/K5iis have gotten the shots against the sun, or is the K3 much better in this respect? I have found this to be one of my K5's Achilles heels, and that's just shooting static subjects.
Good shooting!
Jm_mac
 jm_mac's gear list:jm_mac's gear list
Ricoh WG-M1 Pentax K-3 Sony a6000 Nikon D7200 Canon EOS 80D +12 more
OP MightyMike Forum Pro • Posts: 37,987
AF-C, short burst unless there is a decent sequence, half press while tracking. and picking the best shots to post as always.
cheers don
Mike from Canada
Interesting... 50/50 i actually thing the K-3 did admirably when the sun sparkle it the frame... However i did have 2 very odd photos where the WB went haywire, it could have been caused by internal flare or just a hick-up, i didn't want to post about it because unless i see it happen again i doubt the vast majority of people would come across it.
I edited the shots but i like the way the camera dealt with the situation making it possibly easier to edit to perfection if you can call it that. in straight auto metering I'll bet the K-3 is better then the K-5 against bright subjects
Good shooting!
Jm_mac
Mike from Canada
Ian Stuart Forsyth
Ian Stuart Forsyth Veteran Member • Posts: 3,229
Nice captures Mike
When shooting AF-C what is your hit rate, do you notice if the k3 better at the beginning of the tacking sequence or better at some other point of the sequence?
It seems like from what you have described in you other post that the initial lag has been reduced which is a good thing.
The Camera is only a tool, photography is deciding how to use it.
The hardest part about capturing wildlife is not the photographing portion; it’s getting them to sign a model release
http://www.flickr.com/photos/isfphotography/
http://isfphotography.smugmug.com/
http://isfphotography.com/
 Ian Stuart Forsyth's gear list:Ian Stuart Forsyth's gear list
Nikon PC-E Nikkor 45mm f/2.8D ED Pentax K-5 Pentax *ist DS Pentax K10D Pentax K20D +24 more
Ian Stuart Forsyth wrote:
Nice captures Mike
Hit rate was adequate, subject choice would be hard for even a canikon camera. Once i had a decent lock it was pretty good, getting the lock is user and lens dependent more than the camera. (more playing is necessary)
Unless i misunderstand... in the other post i was saying that the refocus delay is great, where as how quick it snaps into focus isn't anything to get excited over even if it actually is faster
Mike from Canada
Ian Stuart Forsyth
Nice captures Mike
Thank you for clarifying Mike
Mike from Canada
Nice captures Mike
Don't be sad or upset, IMO it was fast to begin with... Its also very lens dependent, take for instance the 77Ltd, wonderful lens, can't AF-C a child walking though! (last time i tried was with the K-5) The focus is dampened for better manual focus control but this makes continuous AF its weak point. My Pentax F 70-210mm F4-5.6 and F 35-70mm F3.5-4.5 can zip into focus faster than it takes you to realize you pressed the AF button (ok an exaggeration, but you get the point)... So until you try it out with your lenses you might not actually know if it really is faster but i will guarantee a slow focusing lens will still be a slow focusing lens.
Mike from Canada
Mike from Canada
M R Padmaraju Veteran Member • Posts: 3,417
Quite inspiring . #6 is the winner for me .
mrp.
 M R Padmaraju's gear list:M R Padmaraju's gear list
Fujifilm FinePix F40fd Pentax K-01 Pentax K-x Pentax K-500 Pentax K-S1 +8 more
ASR45
ASR45 Forum Pro • Posts: 36,726
Impressive mike, they do look great on my monitor, i see you set to -1EV is that the norm for most of your shots.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon EF 100-400mm F4.5-5.6L IS II Nikon D750 Pentax KP Canon 6D Mark II Sigma 300-800mm F5.6 EX DG HSM +10 more
Arijit Banerjee
Arijit Banerjee Senior Member • Posts: 2,555
Some awesome BIFs Mike, but then you always, always shoot so well.
So far so good. How about the higher ISOs? Any testing ?
Arijit
 Arijit Banerjee's gear list:Arijit Banerjee's gear list
Pentax K-5 Pentax K-3 Pentax K-3 II Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +3 more
fakuryu
fakuryu Senior Member • Posts: 1,329
Mike from Canada
Nice sharp shots! How do you find the AF tracking of the K3? And how do you find the performance of the K3 in general? Glad to know that you first copy was just a lemon, looks like you are having fun with the new one.
There is no such thing a "Pro" level gear, just Pro level work.
 fakuryu's gear list:fakuryu's gear list
Panasonic Lumix DMC-LX7 Pentax K-r Pentax K-5 II Pentax Q Olympus PEN E-PL1
robbo d Senior Member • Posts: 2,670
whats your take on IQ?
They are all nice shots i've seen taken with K3, but are they a....'noticable'.......improvement on K5 series? or perhaps just incremental ?
Certainly another way to improve results is by improving AF and metering, nailing the shots more of the time.....perhaps also where K3 is better?
Is it an all round slightly better performer.
Bob Corson Senior Member • Posts: 2,316
Awesome shots Mike. I went to the link too and those swan and cormorant shots were spectacular! Where were you shootiing? Love to find some spots around here. Got to check out some places and get out to do some birding next year.
Great pictures and thank you for sharing them as they were a pleasure to see.
Bob Corson
To truly see one must open their mind as well as their eyes
 Bob Corson's gear list:Bob Corson's gear list
Pentax K-30 Pentax smc DA 35mm F2.4 AL Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +5 more
Benoz
Benoz Veteran Member • Posts: 6,135
Very nice series Mike! I like the way you framed the last one!
BTW, thanks for your opinion in the other thread...much appreciated!
Ben
 Benoz's gear list:Benoz's gear list
Pentax MX-1 Pentax K-70 Pentax KP Pentax smc DA 35mm F2.8 Macro Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +4 more
Thanks mrp, that #6 sure has some nicely lit detail
Mike from Canada
Thanks the norm for certain styles of shooting, other styles might be totally different, choosing what works for each situation takes experience
Mike from Canada
Thanks Dale
Mike from Canada
