NX300 Mode Dial Issue
Started Nov 1, 2013 | Questions
jpcutler85 New Member • Posts: 21
Re: NX300 Mode Dial Issue
Just thought I would share an update. After applying switch contact cleaner under the mode dial it appears to have solved the issue. At least for now anyway  Thanks for the suggestion.
 jpcutler85's gear list:jpcutler85's gear list
Samsung NX300 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung 16-50mm F3.5-5.6 power zoom Samsung Galaxy S7
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
did you disassemble the camera to do that?
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
No just squirted it a couple of times in the gap between the dial and the main body as best as I could using the supplied straw. Then as someone else suggested, kept rapidly switching between modes for a few seconds whilst the camera was off.
Jiri Barta New Member • Posts: 3
Same here with Nx1. Top plate replaced under warranty
 Jiri Barta's gear list:Jiri Barta's gear list
NiSi 15mm F4
markyboy81 Veteran Member • Posts: 4,778
markyboy81 wrote:
jpcutler85 wrote:
OK great, I will give it a go. Thanks.
Just had the same issue with my NX1 - the dial on the left kept thinking it was in 15fps mode when it was in continuous normal. Squirt of Servisol seems to have fixed it.
I wonder if the problem is more prevalent when you don't move the dials much? I pretty much only ever use continuous normal shooting mode.
Although the Servisol does definitely help, it seems it doesn't provide a permanent fix, and the problem comes back quite quickly after.
So far it's not a big enough problem for me to be that bothered, unless it gets worse..
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
OneShot3006
OneShot3006 New Member • Posts: 7
I have some WD40 around the house, I think.
Can I safely use that or do I need to get special contact cleaner?Does that fix last longer?
I'm not sure I would use wd40, the Servisol is supposed to be safe to use on electrical contacts.
tecnoworld
This is the most common problem in nx cameras and it'd be great if a permanent solution were found.
It would be great. It's the only issue I've ever had (so far) with any of my cameras. I'm loathed to start taking them apart as undoubtedly I'd cause more damage.
yurtesen New Member • Posts: 4
I have had this problem for a while and I removed the top assembly board and sprayed drops of Electrolube EML200F Contact Cleaner Lubricant only on the SMD switch and rotated it using a tiny screwdriver many times to let the oil in through the gaps.
Now the switch seems to work perfectly. But I don't know how long. So we shall see...
wwwsnngr
wwwsnngr New Member • Posts: 16
this is the board of the dial
I have the same problem with NX20 & NX1100
The nx20 don't want to go to M manual mode then I press the Dial on top and it's OK until the next time
When I touch the nx 1100 dial sometimes go to another setting ...
I try to not touch it and all OK.
