NEW 24-70mm f2.8ii Zoom Ring "Ticking" While Zooming
Started Oct 21, 2013 | Discussions
dsc888 Forum Member • Posts: 97
Hi Guys,
I just received my new 24-70 f2.8ii lens and it's everything that people have said it was. It's super sharp wide open and focus speed and accuracy is to die for!
But I also noticed one particular thing funny about the zoom ring. It seems to produce a very faint "tick tick tick" as I zoom from 24-70 and back at regular intervals. I read over at Canonrumors Forum that some folks have noticed it as well with the "NEWER" batch of lens made this year with thew new CENTER PINCH lens caps, which I also got. I ordered mine her from DPR's GearShop which ships from Amazon's stock. It's been reported that it may be due to a "brush" sensor or sorts that reports focal length to the camera as you zoom. It's not been verified of course.
Other than that, the lens is fantastic. I just wanted to see if folks here have experienced the same issue. I've only had the lens for about 5 days now and it's not gotten better or worse.
Thanks,
dsc888
 dsc888's gear list:dsc888's gear list
Panasonic Lumix DMC-LX7 Canon EOS 5D Mark III Fujifilm X-E1 Canon EOS Rebel SL1 Fujifilm X-T1 +17 more
billythek Veteran Member • Posts: 5,260
Re: NEW 24-70mm f2.8ii Zoom Ring "Ticking" While Zooming
It's probably ticking because "it's da bomb", as the young folks used to say ;-).
Are you focusing when this happens? Or no?
If I remember, I'll check if my copy does the same thing later today.
- Bill
 billythek's gear list:billythek's gear list
DxO One Canon EOS 5D Mark III Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM
Ryan Ruel Forum Member • Posts: 70
dsc888 wrote:
Hi Guys,
Thanks,
dsc888
I noticed this with mine as well, and it appears to be normal.
I don't notice it at all anymore after using the lens for a while, either it went away or I don't obsess over it.  The images from the lens are so good I don't care, and everything I read said it's just the design of the lens.
- Bill
It may be just my hearing, but I sure don't hear any ticking when I zoom the lens.
- Bill
OP dsc888 Forum Member • Posts: 97
Ryan Ruel wrote:
dsc888 wrote:
Hi Guys,
Thanks,
dsc888
Yeah, I found a few members over at CanonRumors that had the exact same issue and it seems like all the new March 2013 units, which I have, are ticking to some degree. Some have had success by getting older 2012 units with the folder side squeeze lens caps. But yeah, I only hear it in a quiet room. Click here  to check out the post over on the CR forum. It affects nothing in terms of function or the resulting image. The zoom ring is stiff even for an L lens though. Neither my 17-40 nor my 24-105 were as stiff when new.
- Bill
Thanks Bill. It seems to affect only recent 2013 units. If yours came with Canon's newer "center pinch" lens cap, then yours is new and may have the ticking.
- Bill
I got mine in 2012. So, you are implying there was a design change to the lens itself on the units that came with the center pinch caps? Interesting. It would be nice to know what they changed.
- Bill
qianp2k Forum Pro • Posts: 10,350
My copy seems doesn't have this issue, but I can double check tonight.
It's something you really have to look for....
In a completely quiet room, slowly turn the zoom ring, it FAINTLY will "tick tick tick".  It's very faint... this isn't like "CLICK CLICK CLICK".
rebel99 Veteran Member • Posts: 4,025
agree, mine has a faint noise from the mechanical gear movement but it is not noticeable unless you are looking for it i think all canon AF lenses have that noise as far as i can tell, nothing to get concerned about.
cheerz.
- Bill
- Bill
Yes Bill. It seems that only people with 2013 units are having the issue. Quite a few more folks posted to my other thread on CanonRumors and no one with the 2012 lens have the issue. I have no idea what might have been changed but it obviously resulted in undesirable noise. Again, it was reported that Canon states it is related to the brush connector rubbing as you zoom.
Thanks qianp2k. This is EXACTLY what the noise sounds like. Some folks may not even know their's is affected if they don't test out the zoom ring in a quiet environment. I'm still not sure if I want to swap mine out as it seems many owners have the same issue. What if I get one with worse optics and it still ticks?
Please post when you have checked yours. And is yours the 2013 unit with the center pinch lens cap?
I just checked in a very quiet room. I tried many times in different speed either very slowly, moderate slow, moderate fast and very fast zooming in and out. I didn't hear tick tick tick but just normal friction sound in barrel movement like any other lenses.
I bought this lens in last Dec (so it's 2012 version) still with the old traditional Canon lens cap not pinch one. If possible can you record the noise and post sound file somewhere?  It seems that this sound only from 2013 version as you said above.
I heard recently that some owners of this lens had rubber peeling off on the zooming band. So far I don't have this issue yet that worries me. This lens covered lots of dusts during my recent Africa trip that I cleaned carefully on outside surface after return.
Occams Razor Senior Member • Posts: 1,252
I checked my copy very carefully and it does not make that sound.  I purchased it in December 2012 with the older style lens cap.  Since you have seen it reported elsewhere, I would not worry about it if everything else is performing to your satisfaction.
Good luck.
Randy
 Occams Razor's gear list:Occams Razor's gear list
Canon EOS Rebel SL2 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM +4 more
qian and randy,
Thanks for the both your replies. It seems both of you got the older 2012 units that are noise free with the older style edge squeeze caps. Again, I have still 20 plus days to make up my mind. And being that it was purchased from GearShop (i.e. Amazon), it's really not an issue. Whatever happens, I will post back here once a decision is made. Thanks all for all your feedback.
Wayne
Wayne Regular Member • Posts: 210
Just received mine today from Adorama and yes it has the very faint tick tick, tick!!
Not sure what that means if anything!!
 Wayne's gear list:Wayne's gear list
Canon EOS 40D Canon EOS 7D Canon EOS 5D Mark III Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +22 more
AOKH
AOKH Senior Member • Posts: 2,675
It's because it's "Da Bomb"!
Regards. Anders
 AOKH's gear list:AOKH's gear list
Canon EOS 5D Mark II Canon EF 35mm F1.4L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +14 more
anand71 New Member • Posts: 10
Hi,
I got the lens during the $1699 price from B&H last week. I have the same ticking sound and having owned so many L lenses this sounded strange to me and have RMA'ed for replacement. But it looks like its common on these new 24-70 II lens and might very well be in the new one that I am going to get as well
But looking at the date code (by serial number) it starts wtih 03.... which indicates its March 2013 production and I am surprised the lenses that most of seem to have purchased in past week or so is having March production dates and not anything more recent!
Has anyone gotten the lens recently that is later to March of 2013? If so what does your serial # starts with (first 2 or 4 numbers) and do you also experience the same ticking sound? Trying to see if it has something to so with March batches - 03.... serials.
Anand
 anand71's gear list:anand71's gear list
Canon EOS 5D Canon EOS-1D Mark IV Canon EOS 5D Mark III Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM +5 more
Wayne
Called Canon CPS and talked to their techies, they have not heard of this at all. The guy did
 say to me that "it can't be good" !!
