17-40 f4L on 550d upgrade from the kit lens
Started Oct 20, 2013 | User reviews
Andrew9 New Member • Posts: 1
Had mine for about 3 months now, and I believe I found a usable sweetspot for it that finally put a smile on my face.
The 550d is 18 megapixel and jpeg's just don't do justice for neither the camera sensor or lens; so raw is the way to go. I like the quick and silent autofocus with the smooth zoom and focusing rings that focus accurately on subjects; The metal construction gives reassurance, although I think it may be vulnerable in between the metal mount and zoom ring if you keep holding the camera by the lens (anyone heard about this?). Internal focusing let's you use graduated filters and the zoom range is versatile on a crop sensor and does not cross into the 50mm 1.4 prime range or the 70-200 zoom range territory.
My biggest concern with the lens was image sharpness and I did look at pics made by the lens too see it was no issue, but mine just kept getting blurred-ish pics even when i had it on tripod, focused and shot with remote and setting apeture at f7.1 or f9, hoping more will be in focus.But ironically, the sharpest pics (even of vast landscapes) are on f4.5 - to f5.6, i noticed a drop in sharpness at f4 and f6.3+, so as long as it's kept at 4.5-5.6, and iso100-iso400 raw, IQ is good enough for all situations and justifies the cost spent in my head.
Also worth mentioning colors and contrast are superb (per the super-spectra coating). I am using the lens for landscape/ night-time/ wedding/ and occasional portrait photography. A flash helps in keeping iso low. All this is enough for me to settle in and not think about Nikon for now.
Canon EF 17-40mm f/4.0L USM
Wideangle zoom lens • Canon EF • 8806A002
Announced: Feb 27, 2003
Andrew9's score
4.0
Average community score
3.8
muscateer New Member • Posts: 1
Re: 17-40 f4L on 550d upgrade from the kit lens
Have you considered calibrating the lens to your camera? Or at least checking if their is any issue in this regard.
Michael Thomas Mitchell Forum Pro • Posts: 12,158
I was never terribly fond of the 17-40 with APS-C bodies, but it's a workhorse on both our full-frame and APS-H (1D series) bodies. It's been replaced by Canon with newer versions, but this one still works fabulously for us, and we have no intention of replacing it ourselves. Super wide doesn't really benefit from stabilization that way longer lenses do, and the 17-40 delivers excellent quality across the frame when stopped down slightly. I couldn't do my wedding group shots without it!
 Michael Thomas Mitchell's gear list:Michael Thomas Mitchell's gear list
Canon EOS-1D Mark II Canon EOS 7D Mark II Canon EOS 80D Canon EOS 5D Mark IV GoPro Hero7 Black +6 more
arty H Senior Member • Posts: 1,546
I use the 17-40 on crop and full frame. Mine is sharp across the frame on crop, and sharp across the frame on full frame, especially when stopped down. I am surprised at the comment that the lens isn't sharp stopped down. I have used mine at a variety of apertures and it is sharp.
Of course, I avoid very small apertures, when I can. I try to keep F stops at F8 or wider on crop, and F11 or so on full frame. This helps to avoid the effects of diffraction. However, I have never noticed problems with sharpness in good light on crop. Contrast is much better than the 18-55IS.
The lens has different uses on crop and full frame, but it is moderate in size and weight for a full frame zoom lens.
