new 35-100
Started Oct 17, 2013 | Discussions
jeff23r Regular Member • Posts: 273
new 35-100
I saw that there was a new 35-100 added to the road map - i understand it most likely will be a slower lens, which is ok with me.  Once added to the road map, is there a typical time period to actually get to market?  was thinking about a 45-150, which i know is clearly longer, but this length definitely appeals to me
thanks much
 jeff23r's gear list:jeff23r's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR
George Paulides Senior Member • Posts: 1,184
Re: new 35-100
thanks much
Who's roadmap? - Panasonic or Olympus. Panasonic already have a 35-100mm F2.8.
khaledgawdat Regular Member • Posts: 368
Re: new 35-100
I beleive this is supposed to be ultra compact to fit the gm1 camera
K.Gawdat
 khaledgawdat's gear list:khaledgawdat's gear list
Sony RX1 Sigma DP1 Merrill Sigma DP2 Merrill Sigma dp0 Quattro Olympus Tough TG-4 +111 more
dv312
dv312 Veteran Member • Posts: 8,184
perhaps a f3.5-5.6 lens (images)
 dv312's gear list:dv312's gear list
Fujifilm X-T2 Fujifilm X-T3 Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 35mm F2 R WR Fujifilm XF 10-24mm F4 R OIS +1 more
Sosua
Sosua Senior Member • Posts: 2,342
Hmmmmm
Wonder what the length and weight are like - I only use tele every now and then and my oly 40-150 does a good job.
If its a little smaller and higher quality, even as 3.5-5.6, could be worth a look.
www.samwaldron.co.nz
 Sosua's gear list:Sosua's gear list
Olympus E-M5 II Olympus 12-40mm F2.8 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 75mm F1.8
Acrill
Acrill Veteran Member • Posts: 3,057
Re: Hmmmmm
Its designed for the GM1 two-lens kits.
 Acrill's gear list:Acrill's gear list
Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS
DLBlack Forum Pro • Posts: 13,550
Re: new 35-100
Anyones guess when or if the upcoming compact Panasonic 35-100 will reach the market.  Last year Panasonic had a 150/f2.8 on the previous lens road map with an expect release time of late 2013.  On the just release lens road map the 150/f2.8 has been removed.  So I will guess the release of the compact 35-100 will depend on how well the new GM1 sells.
 DLBlack's gear list:DLBlack's gear list
Pentax K-5 Pentax K-7 Olympus OM-D E-M5 Olympus E-M1 Olympus E-M5 II +38 more
Optical1
Optical1 Senior Member • Posts: 1,096
Sometime in 2014. Japanese translation may provide more info...
thanks much
According to the lens roadmap Panny released, this lens will be released in 2014.  I'm not sure what the Japanese next to the lenses mean.  Anyone who can read Japanese want to help?
 Optical1's gear list:Optical1's gear list
Canon PowerShot S95 Sony RX100 Ricoh GR Olympus OM-D E-M5 Olympus PEN E-PM1 +18 more
CharlesTokyo Contributing Member • Posts: 721
Japanese text
The Japanese text is expected release dates:
12-35 vario - end of november
15mm f1.7 - planned release sometime in 2014
35-100 vario - planned release sometime in 2014
42.5 - planned release sometime in 2013-2014
Not all the useful.  In the case of the 12-35 that's probably the Japanese release date. May vary by country.
 CharlesTokyo's gear list:CharlesTokyo's gear list
Ricoh GR Olympus OM-D E-M5 Panasonic Lumix DMC-GF1 Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 +22 more
LeeS Contributing Member • Posts: 792
Re: new 35-100
Unlike the 12-32 the 35-100 does appear to have a manual focus ring.  I wonder if the 12-32 will have manual focusing capability with any older bodies via a firmware update or will only work with the new GM1.
Lee
 LeeS's gear list:LeeS's gear list
Olympus E-M1 II Panasonic Lumix DMC-GM5 Olympus PEN-F
Fredrik Glckner Veteran Member • Posts: 3,679
Re: new 35-100
Based on the picture I have seen, it does not appear that much smaller than the 45-150mm zoom lens.
http://m43photo.blogspot.com
