moon shot with ef600 f4II
Started Oct 12, 2013 | User reviews
rebel99 Veteran Member • Posts: 4,025
5
for those who are curious about adding tc on ef 600mm f4II, here are 2 moon shots with and without 1.4xIII TC. the lens IQ takes a big hit when TC is added. i haven't taken my lens on field tour yet i do have the 2.0xIII TC as well and i didn't bother with it because i knew it'll look awful. i have PPed the shots on my uncalibrated laptop so i don't know how it'd look like on your monitor. please let me know if the posted photos look weird on your monitor. the RAW pictures look very nice and sharp with excellent contrast on my monitor. any comment is welcomed.
cheerz.
EF 600mm f4II /1D4 no TC
EF 600mm f4II+1.4x TC
Canon EF 600mm f/4.0L IS II USM
Telephoto prime lens • Canon EF • 5125B002
Announced: Feb 7, 2011
rebel99's score
5.0
Average community score
4.7
joger
joger Veteran Member • Posts: 7,513
Re: moon shot with ef600 f4II
cheerz.
the bare 600 shot looks fantastic.
I am puzzled by the bad quality of the 1.4x image ???
Are you sure everything was done properly?
My 300 II sees almost no degradation with the 1.4x III on it - could it be that you had not focussed perfectly or any other user flaw? If the degradation is that big I would not like to use it - my 300 looks better with the 2x III on it (if I recall my images right)
__________________________________
isn’t it funny, a ship that leaks from the top
ISO 9000 definition of quality: 'Degree to which a set of inherent characteristic fulfills requirements'
I am the classic “Windows by Day, Mac by Night user'
“The horizon of many people is a circle with zero radius which they call their point of view.” Albert Einstein
don't feed trolls - ignore them
 joger's gear list:joger's gear list
Sony a7R IV Sony FE 135mm F1.8 GM Sony FE 35mm F1.4 GM Sony FE 50mm F1.2 GM Sony FE 14mm F1.8 GM +12 more
paulbysea Contributing Member • Posts: 530
which body did you use?
 paulbysea's gear list:paulbysea's gear list
Pentax Optio W80 Nikon Coolpix A Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 20mm f/2.8 USM +6 more
Digital Shutterbug Veteran Member • Posts: 5,487
Hover your cursor over the image to see the EXIF. It was a 1D Mk IV.
Steve
Searching Veteran Member • Posts: 3,964
Bare the 600 looks excellent on my monitor.  Great shot.  I too am a bit puzzled by the performance with the TC, didn't think it would be that bad.
 Searching's gear list:Searching's gear list
Olympus E-M1 II Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +4 more
Iron Mike
Iron Mike Contributing Member • Posts: 540
Looking at the exif, there seems to be a few differences, for example the bare 600 was stopped down to f/8 while the 600+1.4X was wide open at f/5.6 ; but the most obvious difference, is that the moon looks different, and was not photographed at the same time. Again, looking at the exif it seems likely that the atmospheric seeing conditions on the 20th (600+1.4X shot) were not as good as the day of the first shot.
Tele-converters, like all other lenses, can be out of spec as well, or be a poor match with this particular combination. Have you tested your 1.4XIII on some of your other lenses to check its performance? You might also need a separate AFMA input for the 600+TC combination.
It seems that there is likely something else at play, because all the other image samples I have seen of this combination show far less image degradation than what we see here.
Mike
P.S. I don't personally own a 600mm, so take my opinions for what they are worth...(i.e. not much)
OP rebel99 Veteran Member • Posts: 4,025
joger wrote:
cheerz.
yes indeed, i am puzzled as well to the degree of iq degradation when tc is added. but i think there must be a different reason and i need to investigate the reason. thanks for replying.
cheerz.
Mike
i did try the shots on different nights but that shouldn't make that much of drastic difference. i have tried the 1.4x III (including 2.0x III) tcs on my 300mm f2.8II and you hardly notice any iq difference! i agree with your excellent points and need to investigate further and find out the real culprit. i think i have some methodologies in mind to go about and hopefully those will resolve this mystery. thanks for your helpful reply and good points
cheerz.
R2D2 Forum Pro • Posts: 26,551
+1  Atmospherics play a huge role in IQ.  That is unless your TC is in fact bad.
R2
Tapeman Contributing Member • Posts: 672
I have excellent results with a 1.4X MK III on my 500 f/4L IS II.
I've heard good things about it on the 600 as well. Seems to me there is something wrong with yours.
AOKH
AOKH Senior Member • Posts: 2,675
cheerz.
To me the one with the TC looks backfocused. Maybe MA will fix it!
Regards. Anders
 AOKH's gear list:AOKH's gear list
Canon EOS 5D Mark II Canon EF 35mm F1.4L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +14 more
numnuts
numnuts Forum Member • Posts: 99
I think Iron Mike might be on track with a lot of the image degradation. While I don't own the 600, but have the 400 2.8 I've found that absolute image quality is attained one or two stops from wide open with these lenses, so f4-5.6 for me, f5.6-8 for you, but throw on the 1.4 tele converter and you'll need to go another stop again to maintain the lenses native aperture, so reporting f8-11. Also maintaining aperture is a given for comparing image quality. I noticed also that the shutter speed was pretty high. Unless you're shooting hand held you'd be better off reducing shutter speed for lowest iso. I've shot the moon on my 7D surprisingly clean at 1/50th (I found this to be about as slow as I could go before getting motion blur) while using both a 2xII and a 1.4xIII behind my 400 at a true f11, one stop from wide open. A day or two later I tried the same setup and settings on my 5DII, but the quality wasn't as good, so apparently clear nights do vary a lot as others have said.
The shot below is the one from my 7D, straight from raw conversion so it'll clean up a bit better than this. Also you can see the exif doesn't report double stacking of tele's, hence the info saying 800mm f8.
 numnuts's gear list:numnuts's gear list
Canon EOS 7D Mark II Canon EOS 5DS Canon EF-S 10-22mm F3.5-4.5 USM Canon TS-E 17mm f/4L Canon EF 70-200mm F2.8L IS II USM +7 more
Press Correspondent
Press Correspondent Veteran Member • Posts: 3,362
Right, backfocused... because the edes seem more in focus and they are obviously further away than the center. Never mind the moon is two hundred million miles away - the shallow DOF of the 600mm can clearly separate the edges from the center!
Here in America we are proud of the public school education. And although our kids rank the last in in science, they rank #1 in self confidence.
 Press Correspondent's gear list:Press Correspondent's gear list
SeaLife DC2000 Panasonic LX100 II Canon EOS 5D Mark III Canon EF 50mm F1.4 USM Canon EF 70-200mm F4L USM +12 more
BigBen08 Veteran Member • Posts: 7,473
How does you 600 + 1.4x combo work with shots other than the moon?
like i said, i haven't used my lens and TCs on the field yet but i'll do that shortly
cheerz.
clarnibass Senior Member • Posts: 2,480
I would try two things.
First, try the combination on different targets, not just the moon.
Second, since your first photo is f/8, 1/160, ISO 100, I would try the 600mm + 1.4TC at f/11, 1/160, ISO 200 and taking the photos one after the other.
Schwany
Schwany Forum Pro • Posts: 10,169
Could this be true about ef600 f4II?
Heard this yesterday.
The 600f4 II plus 1.4x extender don't work optimally on a 1DMkIV or any older body. By this I mean focus speed, accuracy, and resulting image quality. Apparently that combo works much better on a 5DMkIII or 1DX with almost zero degradation when using a 1.4x III extender.
Yes that is the stuff interweb BS and mythology comes from, but I did hear it while talking to someone about longer than 500mm lenses. Can't confirm it. Don't you have a 1DX now. If so, you could check to see if that is true.
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 5D Mark IV +14 more
ed rader Veteran Member • Posts: 9,068
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
garyknrd
garyknrd Contributing Member • Posts: 810
That is horrible. I have also noticed a drop in IQ with the 1.4 on the 500 II, But it is still very good. But verrry little with the 300 II. Strange.
Personally if my results were that bad I would send the T.C. back to canon with the lens.
Presently living in Asia
 garyknrd's gear list:garyknrd's gear list
Canon EOS 7D Canon EOS 7D Mark II Canon EF 500mm f/4.0L IS II USM Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF 400mm F4 DO IS II USM
Exactly my experience also. 300 II/1.4xIII provides razor sharp images. 500 II/1.4xIII results in a noticeable IQ drop. Not real bad, but noticeable.
