Fungus is probably there to stay, minimize damages
raay wrote:
From now on i will be keeping it in a airtight box with silica gel , wish i only knew sooner ,i keep my lenses in airtight boxes!!!
First, the pattern on the image looks like fungus, but remove the lens, take a magnifier, and check that it looks like fungus on the sensor. There's still a slim chance it's "hairy" dust... check that first.
There is no way fungus is Sony's fault and I would worry that repair cost could approach price of a new A3000. Incidentally, if I had to bet, I'd guess the fungus got established by being blown onto it with your blower... unfiltered intakes on blowers can suck in badness, and it can grow inside your blower. It could be almost as bad as you blowing on it. I'd also check the lens -- really likely it's infected too, although the impact of lens fungus on image quality is fairly subtle, so you check by looking into the unmounted lens with a penlight.
Closing the barn door now doesn't help much... by the way, light and ventilation are good -- an airtight box tends to trap moisture & friends (ok, not so friendly life forms) inside, and silica gel can only absorb so much moisture. Silica gel also needs to be baked regularly (e.g., every few months under good conditions) to get the stored moisture out so it can collect more. Anyway, minimize moisture and darkness in storage.
Once fungus has gotten established inside your camera, I don't think you'll ever totally eliminate it. Too many happy little dark corners in there. Also, if it hasn't yet started to etch whatever surface its on, it soon will -- I wouldn't wait.
If this happened to me, I'd do a wet clean of the sensor ASAP. Remember that "wet" cleaning really means ever so slightly moist. If you can quickly get a wet clean kit, do that. If not, I'd consider your camera to be an emergency case, and I'd even resort to Q-tips and alcohol rather than waiting: take a Q-tip, dip it in alcohol, momentarily touch a dry Q-tip to the moistened one's tip, and use the second Q-tip to clean. Under good lighting and using some kind of magnifier to help you see, gently move the Q-tip on the sensor (it's really glass over the sensor) in a circular motion. Don't let any loose threads come off the Q-tip in the body and don't get the moist tip over the edges of the sensor, but with reasonable care you should be ok. Repeat as needed. Hopefully, the fungus will come off easily. Ideally, do a final pass with a sensorklear pen to remove any streaks when you can... but a minor streak is better than giving fungus more time to do its thing.
Anyway, good luck with whatever you decide to do about this.... I wrote a little page on cleaning: http://aggregate.org/DIT/CLEAN/ and there's a much more comprehensive one from LensRentals: http://www.lensrentals.com/blog/2011/05/the-lensrentals-lens-cleaning-methods
