Panasonic 45-150 and Olympus EM-5
Started Oct 7, 2013 | Discussions
Nivedita Contributing Member • Posts: 659
I just ordered a Panasonic 45-150mm from B&H. After my rewards points, I paid $126.00. I think for that price, it is good. Though I heard that Olympus 40-150 is better, I chose Panasonic for because of build quality.
One question - Does EM-5 automatically turn-off the OIS in the lens (or does not turn it on) because there is not OIS switch in this lens?
-Nivedita
 Nivedita's gear list:Nivedita's gear list
Sony a7R III Sony FE 70-200mm F2.8 GM OSS Phase One Capture One Pro
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Panasonic 45-150 and Olympus EM-5
The Panasonic lens appears to test as a better lens than the Olympus 40-250mm especially is better at 150mm. Go to http://www.photozone.de/m43 and compare the two lenses resolution results, both tested at 16MP so should be a good comparison. Nice lens, I like it a lot.
-Nivedita
With E-M5 and all the earlier Pens the unswitched OIS is disabled so never works, no fear of interaction.
With E-PL5/E-PL6/E-PM2/E-M1 the unswitched OIS can be used (gives a nice stabilised preview on my E-PL5 without needing to half press) and the camera logic prevents the IBIS and OIS interacting, no matter what you do only one (or none) will work at the same time.
Regards...... Guy
bgalb
bgalb Senior Member • Posts: 2,179
The OIS does not activate on the E-M5.  The E-M5 IBIS is arguably better anyway. (On this forum, definitely arguably  .
 bgalb's gear list:bgalb's gear list
Panasonic Lumix DMC-GM5 Olympus E-M1 II Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Panasonic 20mm F1.7 II Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +4 more
OP Nivedita Contributing Member • Posts: 659
-Nivedita
Regards...... Guy
Thank you very much. I will post some of my pictures with it once I receive the lens (next week is fall festival here and hope to get some nice shots !)
-Novedita
Hopefully that is the case
I have used both lens based and sensor based image stabilizations in the past (Canon and Pentax). Based on my limited testing, for longer ranges I found the lens based stabilizations performs better. EM-5 is my first Olympus camera and now I am learning the 'different' menu system.
-Nivedita
EarthQuake Veteran Member • Posts: 3,240
-Nivedita
In my experience (with EM5 and 100-300), the IBIS in the EM5 is even better than the in lens IS. I assume this is because the IBIS corrects for types of motion that the lens IS can't (like rotational). The IBIS in the EM5 is noticeably better than the IBIS in my Sony Alpha DSLRs too.
You can set the EM5 up so that it stabilizes on half press, which isn't as nice as always on lens IS, but better than nothing.
Michael Geary Regular Member • Posts: 322
The E-P5 works this way too (no surprise here, just mentioning it for anyone wondering since you didn't list it).
 Michael Geary's gear list:Michael Geary's gear list
Canon PowerShot S95 Sony RX100 II Olympus PEN E-P5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +6 more
Guy Parsons
Ooops, I knew that but somehow missed typing it, sorry.
So the "modern" group in regard to firmware are indeed E-PL5/E-PM2/E-P5/E-PL6/E-M1.
The "early" group are the E-P1/E-P2/E-P3/E-PL1/E-PL2/E-PL3/E-PM1/E-M5 and they don't have unswitched OIS ability. The E-M5 being the odd one out in the "early" group with the more modern sensor and the better IBIS.
Regards...... Guy
