Are images from the E-m1 actually better than from the E-m5?
Started Oct 1, 2013 | Discussions
DocDerm Regular Member • Posts: 376
I have become confused whether the:
a) New sensor
b) Lack of anti-aliasing / low pass filter
actually result in better images.
Lots of sites point out these seemingly meaningful advances......but I do not seem to be finding images from one versus the other camera....using the same lens micro 4/3 lens....that tell us whether the camera bodies result in different quality images.
Can anyone shine light on this question?
DonSantos Senior Member • Posts: 1,145
Re: Are images from the E-m1 actually better than from the E-m5?
a) New sensor
According to the dpreview raw test low iso em-5 looks sharper but super high iso em-1 take a small lead
 DonSantos's gear list:DonSantos's gear list
Fujifilm X100S Nikon D600 Sony a7 Voigtlander 40mm F1.4 Nokton Classic Nikon AF-S Nikkor 50mm f/1.8G +3 more
OP DocDerm Regular Member • Posts: 376
Is it puzzling that the E-M5 at low iso would be sharper when the E-M1 does not have an anti-aliasing filter?
pdelux Contributing Member • Posts: 834
I think they were shot with different lenses, em5 with the 50mm F2 and the EM1 with the 45mm.
 pdelux's gear list:pdelux's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +6 more
broody Contributing Member • Posts: 674
Some bloggers like Ming Thein reported the EM-1 could perform at 1 stop ISO advantage over the EM-5. What they forgot to mention is that this is for JPEG files ONLY.
Indeed, the EM-1 has a visibly improved JPEG engine over the last generation and the competition, and it does yield nicer images in high ISO settings. However this does not apply to RAW at all. The EM-1 is tied with the OM-D EM-5 and the GX7 for RAW captures. Just look at DPreview's own test charts. The EPL-5 even seems to beat it in high ISO detail.
Let's keep it honest, guys. the EM1 was massively hyped by review after review comparing it to Full Frame cameras. But at the end of the day, it's the same Sony sensor we know and are used to, same DR, same ISO sensitivity, sure it also has PDAF, no AA filter and better JPEGs but that's it.
I recommend you guys take a look at this comparison. It will either make you feel great you don't pack an APS-C body, or bad you don't have a D600. http://kimletkeman.blogspot.com/2013/09/battle-of-aps-c-and-m43-latest.html
 broody's gear list:broody's gear list
Canon EOS 5D Mark II Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Canon EF 50mm f/1.8 II Canon EF 24-105mm f/4L IS USM +5 more
Ulric Veteran Member • Posts: 4,547
a) New sensor
Considering the reports that the Dpreview test shots may have been plagued by shutter-shock, I don't think it is meaningful to use them to compare sharpness.
My impression is that the E-M1 performs on par with the E-M5 and other recent Olympus cameras. The improvements are in other areas.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Acrill
Acrill Veteran Member • Posts: 3,055
7
It has a new jpeg engine but I think overall image quality is very similar between the two cameras.
An upgrade in IQ is not the point of the E-M1. it is all about the focusing system, ergonomics and customizability.
 Acrill's gear list:Acrill's gear list
Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
Donald Chin
Donald Chin Veteran Member • Posts: 5,757
Ming Thein had up-dated his review regarding raw. (n/t)
ASR45
ASR45 Forum Pro • Posts: 36,810
Agree, but what i have seen thus far, has been impressive.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon EF 100-400mm F4.5-5.6L IS II Nikon D750 Pentax KP Canon 6D Mark II Nikon AF Nikkor 80-400mm f/4.5-5.6D ED VR +10 more
Abrak Veteran Member • Posts: 4,131
Actually Ming Thein does claim that the E-M1 has noticeably better IQ even for RAW.
Now that ACR 8.2 has support for the E-M1′s raw files, I’ve gone back through the archive, reprocessed a few and had another look at the overall file quality. Fundamentally, the good news is that none of the observations really change: underlying sensor quality remains excellent, and a small but distinct step up on the E-M5′s sensor. There is a definite gain in edge acuity and ability to resolve fine detail; the high ISO noise improvement is not as pronounced as with the JPEGs, but the red channel especially shows clear signs of improvement in luminance noise, color accuracy and tonal separation. I would estimate the advantage of the newer sensor to be about half a stop up to ISO 1600
I am somewhat skeptical myself but we shall see. Early reviews tend to be pretty enthusiastic with a lot of cameras.
Nemo0815 Contributing Member • Posts: 823
It's the same sensor design, just with lots of pixels sacrified for PDAF. Not even Olympus claims and there are any improvements in image quality. That is alone coming from some fanboyish review blogs which already die the same for the E-P5 despite exactly the same sensor as E-M5.
 Nemo0815's gear list:Nemo0815's gear list
Panasonic LX10 Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +2 more
Donald Chin
I don't have E-M5 raw file in hand to compare, you can download my E-M1 sample raw to review yourself.
http://www.sendspace.com/file/pfathz--
Powerdoc Veteran Member • Posts: 3,471
I did not see any improvement. The lack of AA filter does not seem to increase sharpness : with great primes, it's still very good.
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm FinePix X100 Fujifilm X-Pro1 Canon EOS 6D Panasonic Lumix DMC-GX7 Fujifilm X-T1 +35 more
hinting Contributing Member • Posts: 750
 hinting's gear list:hinting's gear list
Panasonic Lumix DMC-GX1 Olympus OM-D E-M5 Leica M-Monochrom Panasonic Lumix DMC-GX7 Olympus E-M1 +52 more
Tony Rogers Senior Member • Posts: 1,361
Anybody else concerned about how red the E-M1 images are? I'm finding this in the raw files too and so far, haven't found a way to compensate for it.
 Tony Rogers's gear list:Tony Rogers's gear list
Olympus E-M1 Olympus E-M1 II Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro
http://cameralabs.com/reviews/Olympus_OMD_EM1/RAW_quality.shtml
See the test above.
THX.
Even though his conclusion is not very accurate, one can easily See that the GX7 has a color noise advantage starting from 6400 and becoming stronger and stronger the higher the ISO goes, while M1 and M5 looking almost identical with maybe a very slight andvantage for the M1. Just look at the darker areas in the comparison shots.
That's in line with most other reviews til now.
Out of interest what are you using as the RAW converter - Olympus viewer? or LR? I believe that as ACR only has preliminary support for the E-M1, the colors may not be quite right yet.
I'm using CS5. But it seems to me that the colours are similar in the jpegs too and that the E-M1 is very different in colour cast from the E-M5.
Olymore
Olymore Senior Member • Posts: 1,763
If there is so much uncertainty and confusion over whether there are any improvements when shooting test charts then it is probably safe to assume that for practical , real life use you won't see any difference.
There are obviously many other reasons to consider the camera.
There are 10 types of people.
Those that understand binary and those that don't.
 Olymore's gear list:Olymore's gear list
Olympus E-M1
LTZ470
LTZ470 Forum Pro • Posts: 11,926
Should do just fine, but D600's have been plagued?
http://www.dpreview.com/forums/thread/3553383
--Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
