GX7 EVF great or not so great
Started Sep 27, 2013 | Polls
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
I was very unimpressed with the GX7s EVF and several others have commented similarly.  Others have said how brilliant it is.  If you've seen a GX7 perhaps you'd like to vote.  It is hard to believe that views can be so different on a simple assessment.
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
POLL
Great
76% 38  votes
Not so great
24% 12  votes
  Show results
Panasonic Lumix DMC-GX7
Manip16 Contributing Member • Posts: 515
Re: GX7 EVF great or not so great
Could you explain what you didn't like about the GX7's EVF (e.g. colours, refresh, size, etc)?
larsbc Forum Pro • Posts: 18,282
I like it simply for its high resolution.  It's a big step up from the GH2.
I can see the rainbow effect if I watch for it...so I've stopped watching for it.
IMO it's not great, but I don't think "not so great" is a good description, either.  I'd say it's "quite good."
Trevor Carpenter
OP Trevor Carpenter Forum Pro • Posts: 19,435
It seemed very small and like looking into a tunnel like some of the OVFs on low end DSLRs that I've looked at in the past.  It may well be bright and clear but any benefit was more than negated by the size.  My G5 is a much more pleasurable experience to use
George Paulides Senior Member • Posts: 1,358
Looking through it how does it compare size-wise to the GH-1/GH-2/LVF-2 viewfinders?
sea_dragon Contributing Member • Posts: 836
This is how I find the EVF on my GH3. Narrow tunnel is a good description. If the GX7 is the same then its no good. Will have to check one out in person when I have a chance.
imashination Regular Member • Posts: 415
Probably caused by the fact that youre looking into a very small tunnel.
I dont think anyone should expect any wonders from it, its extremely small and compact for convenience, to expect an imax viewing experience from it is just unrealistic
rcjim Regular Member • Posts: 318
I'm wondering the same thing about the GX7 EVF.  I own the FZ200, which IMO has a fantastic EVF.  Anyone own both the GX7 and FZ200 that can comment on how the EVFs compare?
 rcjim's gear list:rcjim's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-GX7 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS
I disagree.  We should absolutely expect a good viewable image in a viewfinder free from tunnel effect. Viewfinders should get BETTER with each new model, not worse..  The NEX cameras have nice "large" images in their EVFs.  I can't comment on the GX7 as I haven't actually seen one yet.  But the GH3 finder image is small (and it's not a small camera).  Part of the issue I believe is they crammed a widescreen panel into a small EVF housing.  This requires an overly convex magnifier in front of the panel.  They should have kept the EVF panel at 4:3 to match that of the sensor IMO.
The G6 has a good image in the EVF.
Trevor Carpenter
All a bit odd to me because for years, contributors for these forums have been saying viewfinder quality is of paramount importance and a big reason why they wouldn't give up their DSLRS and now that doesn't seem to be the case. So much so that a large percentage of people who have seen the GX7 think it is very good.  If it is very good I would say the G6s EVF is fantastic.
Olymore
Olymore Senior Member • Posts: 1,939
It seems that the glass in front of the veiwfinder is as important as the EVF itself in determining how the view is perceived.
All the comments about the Oly equivalent viewfinders (VF-4 and E-M1) suggest that they used high quality optics which seem to have been more successful despite having fewer pixels.
There are 10 types of people.
Those that understand binary and those that don't.
 Olymore's gear list:Olymore's gear list
Olympus E-M1
ssww Regular Member • Posts: 324
I wonder if the questionnaire should also include asking whether wear glasses or not because it may or may not make a difference.
morepix
morepix Veteran Member • Posts: 9,753
Unreliable opinions
Fantastic? Yes, nice and clear, but talk about tunnels ... ! I alternate between my FZ200 and LX7 with LVF2, and the difference is huge: Smaller camera, much bigger view.
How can anyone base anything on the totally subjective opinions people post here? The only way to find out anything is to try it yourself.
David
www.pbase.com/morepix
 morepix's gear list:morepix's gear list
Sony RX100 VA Ricoh GR III
RickPick
RickPick Senior Member • Posts: 1,332
Well, I only just got my GX7 a few hours ago, but I must say I am very impressed with the EVF so far. I could see instantly that is a huge improvement over the GH3's. I wear glasses, and the only problem is that in 16:9 mode I cannot see the extreme edges of the view, due to the distance of my eye from the VF. I don't think that will bother me, but if there is a larger eye cup available I may get one.
There is no distortion or curvature of the view like you get with the GH3 if your eye position is not exactly right, and I had no problem adjusting the diopter to get a clear view.
The complaints about size - well all I can say it is much better than I feared when I originally read those comments. The display is also very sharp and has more accurate colours than the others I have used. My "beloved" GH2 has a nice large display but it does suffer from the "rainbow" effect to some degree.
I have played back some video files recorded on the GH2 via the GX7 and they look great through the EVF.
Definitely the best Pana EVF to date I would say (having used G1, GH2 and GH3 before). I have not used a NEX but did look through a friend's NEX 7 EVF earlier this year. Of course it is hard to compare now, but the GX7 view looks larger and clearer to me than I remember that of the NEX.
BTW, the camera is beautifully made and a bit smaller than I was expecting. If you have large hands you may find it fiddly to use in some respects. Try before you buy if you possibly can.
My first impression of the camera though is very very good. The battery is small and spares will be needed but of course no time yet to work out how the battery life is. One interesting thing - there's a rubber flap in the battery/SD card slot cover which reveals a small hole, e.g. for a cable of some sort. Does this mean some kind of accessory battery pack or mains adapter could be (or become) available?
Rick
 RickPick's gear list:RickPick's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
KTClown
KTClown Senior Member • Posts: 1,461
I haven't seen the GX-7 at my camera shop, still waiting???
Anyway, each person is different and their expeditions are different. I have a XZ-1 as a back up, and use the VF-2 view finder, it's small and works good for me. I also wear glasses and no problem there.
But will wait and see about the EVF on the GX-7? No matter the equipment you buy nothing will be perfect.
Gary
I'm as confused as a baby in a topless bar.
 KTClown's gear list:KTClown's gear list
Olympus XZ-1 Olympus PEN E-PL5 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +2 more
captura Forum Pro • Posts: 27,478
The G1's EVF is great. So is the NEX-7/6/5R's EVF.
 captura's gear list:captura's gear list
Sony Alpha NEX-7 Canon EOS Rebel SL1 Sony a7 Olympus OM-D E-M10 Canon EF 85mm F1.8 USM +3 more
pbn New Member • Posts: 23
I have had my GX7 for about a week now. I upgraded from a G3.
I've just had a play alternating between the two cameras. The G3 vf is bigger mainly because it is squarer. Its also much lower resolution and you can definitely see that especially in the annotation around the display. The GX7 annotation is a much smaller font but actually clearer and easy to read.
I wouldn't say there more of a tunnel effect on the GX7.
I havn't used the G5, G6 or GH3.
I am happy with the GX7 vf and it doesn't feel small to me. I don't wear glasses.
somersetlad Regular Member • Posts: 270
I have had GX7 2 days, most of which has been grey outside, and I have spared the cats, so little use yet. I can only compare with EM 5 which I still have. Bigger eye piece on Oly, but in actual use I find little practical difference, perhaps slight edge to Oly - But when set on pinpoint focus the briefly magnified focus area on the GX7 is excellent so for me overall it is a winner - everything is a compromise, but they have packed a lot in.
John
 somersetlad's gear list:somersetlad's gear list
Sony RX1R II Sony a6500 Sony a7R III Sony E 16-50mm F3.5-5.6 PZ OSS Sony FE 12-24mm F4 +4 more
Re: Unreliable opinions
David
Wow, now I know I'm going to love the EVF in the GX7!!!!
(unknown member) Contributing Member • Posts: 614
John
How are you finding it generally between the OMD and GX7? I also have an OMD and am very tempted, but worried about losing IBIS (for video) even though you gain so much more bitrate and fps.
