Re: Consensus on 24-70/2.8 II field curvature at infinity focus?
Benedict Slotte wrote:
My lens has field curvature, with soft edges as a result focused at infinity.
And the “cure” is to focus beyond the infinity mark. For a start, focus using live view, aperture set at 8, place the focus point in one of the far edges, stop down and manual focus until the edge is sharp. You will by trial and error find the “magic focus point” that will bring both the center and edge/corners pin sharp.
This is what I tried to achieve too - using somewhat offset microadjustment. However, I was unsuccessful at getting a sharp center at the same time. Tweaking focus using live view across the frame is of course possible, but kind of annoying.
Another copy I tried was sharp as a knife both in the center and at the right edge, but mushy on the entire left side... There is just a lot of variation going on between copies. The excellent AF of the 1D X just makes any such inconsistencies even more obvious.
It seems to me that the 24-70 L II is not really such a good landscape lens after all.
Sounds like you are dealing with much worse issues than I see. Perhaps if you post example pictures it would be easier to tell what is going on. Some people have reported decentering problems with their copy of the lens that got much better with a replacement.
When I say I noticed "some" field curvature, it was slight. Not what I would call "mushy" at all. Let me go into more detail on the test I did. I went to a location across the river from a row of buildings which are more or less parallel (but not exactly). It was probably about a half mile from the closest building directly in front of me. I tried to aim my camera perpendicular to the plane of the buildings, but had no way to measure how accurately that was done. I tested at 24mm & f/2.8, since I take most of my landscapes at 24mm or wider, and f/2.8 would be the toughest test.
Of course, I was using a tripod, live view, and remote release. I initially focused using CDAF using the center point on the building directly in front of me. Then I checked in the center using 10X mag if I could improve on the focus by tweaking the focus ring manually (slightly, either direction). I could not. So I concluded that CDAF does a decent job in live view.
Then I again focused using CDAF using the center point and checked the buildings towards the edges. They appeared, at first glance, to be sharp. The question was, could I improve their sharpness AT ALL by tweaking the focus ring slightly. Turns out, yes, I could. But only a very slight tweak was required to optimize focus. So I concluded that the focal plane has some slight curvature at 24mm f/2.8. When I checked with more depth of field, I did not notice the effect at all.
Now what does this matter to the landscape photographer? In my opinion, not a lot. How often are you trying to photograph something that is in a perfect plane. I suppose a mountain range on the horizon is one example. But only if you're pointing the camera at exact right angles to the mountains. If you are not, the focal plane is tilted anyway. Once you stop down to give yourself more DOF the problem goes away, anyway (at least for me it does). Typically, the objects in my landscape photos are not all in a single plane. There are objects at various distances. So I have to provide DOF if I want them to all be in acceptable focus.
But it sounds like you are seeing much worse problems than this, which makes me suspect you might have an alignment or decentering issue. Perhaps Canon can adjust the lens so it is better?
It is true that I only checked at 24mm, because that is what I was most concerned about. I've never noticed a problem at other focal lengths, but I can't say I did a scientific test, either. Maybe I will, if I get motivated, but it won't be anytime in the near future, since life is hectic at the moment.
Here are some landscape pictures taken with the 24-70II. It is quite possible that the TSE17 or the Zeiss 21 could do a better job, but I don't own those lenses (yet). But I think the 24-70II does a reasonable job at landscape. Better than my old 24-105, anyway. Click on the pictures to view at 100%. Some of these are panos, but I threw in a few handheld single shots as well.
