fairground with E620
Started Aug 27, 2013 | Discussions
108 Contributing Member • Posts: 804
Hello
I took this shot below at the local fair. Oly E620 with a PanaLeica 1.4.
This is the first time in my short digital photography experience that I used my equipment for this kind of shooting : night, bright electric lights of all different colours, fast moving fairground "rides". Most of what I had done is late evening stills, and this was quite a challenge for me. I must say the metering was OK most of the time, except a few cases where I had to put EV correction ( thank you back lcd ). The lens is a very good lens and did well in my view. I am still amazed that this equipment could render all these different bright colours rather faithfully. Magic of digital photography ;-). Focus was a headache , and I finally settled for speed priority with cdaf , cdaf I had never used. For this shot it was 1/500 with 1250 iso at f1.4. Of 110 shots I threw 90 away back home. This shot I consider barely acceptable. Background noise was terrible and I had to run it through Neat Image ( fine software imo ). I am not very experienced and certainly did a few things wrong, but I think the E620 is not up to the task, sensor and focus wise. I wonder if the last m4/3 would do much better and more comfortably, like the OMD or the EP5, or the latest Pana G's or GH3 ? Or should one consider top APSC's or FF's for this kind of shooting ?
Thanks for your experiences.
 108's gear list:108's gear list
Olympus E-30 Olympus OM-D E-M5 Olympus E-M1 Olympus OM-D E-M10
ac921ol Forum Member • Posts: 74
Re: fairground with E620
full size image looks better, for a first time I think you did fine, obviously a bigger sensor, different AF would make a difference, but the next person with a better camera, could also say the same thing, just keep shooting.
OP 108 Contributing Member • Posts: 804
That's just what I did.
Thanks for the encouragement
toyak Regular Member • Posts: 166
I think you took some decent shots in a challenging lighting situation. I have an E-620 and that is not the worlds best sensor for low light work with 1/500th shutter speed.
sirharold
sirharold Contributing Member • Posts: 537
I'm not going to beat up on your picture. I had plenty of these in the past. Your missing one tool and that is a hand held light meter. You can grab one off ebay for around 50-75 bucks. This gives you a cheating advantage instead of cranking up your shutter. This is the best tool in my gear bag.
 sirharold's gear list:sirharold's gear list
Olympus E-1 Olympus E-3 Olympus E-330 Olympus E-5 Olympus E-M1 +27 more
Thanks for the tip.
I'll do some reading on this and I'll get back to you with some questions.
