Flash Kit Brand Advice For Portraits
Started Aug 25, 2013 | Questions
xobione Forum Member • Posts: 61
Good evening everyone,
I will like to please ask your advice on the brand of a Monolights kit for portraiture and fashion photography?
I´m trying to choose between these ones:
1)Bowens Gemini 500Pro 2 light Kit with Pulsar TX:
http://www.bhphotovideo.com/c/product/875143-REG/Bowens_BW_8610TXUS_Gemini_500Pro_2_Light.html
2)Elinchrom BRX 500 2 Light to Go Kit:
http://www.bhphotovideo.com/c/product/906698-REG/elinchrom_el_20758kit_brx_500_500_to_go.html
3)Hensel Integra 500 PLus Freemask 2 Light Kit:
http://www.bhphotovideo.com/c/product/841594-REG/Hensel_7048815FM_INTEGRA_PRO_FM_500ws.html
I need you please share your knowledge and experience to me to help me choose; in terms of light quality,reliability, time resistance.
I´m not considering Einsteins because I live in Madrid and here in Europe are expensive than USA.
Again thanks for your help and quick answer.
Kind Regards,
Xoán.
DecibelPhoto Contributing Member • Posts: 791
Re: Flash Kit Brand Advice For Portraits
Personally, not a big fan of the Bowens, although I know many who like them.  I just don't like the control dial, and they feel cheap.  The Elinchrom's seem pretty nice, I know many who like them, although I have no personal experience.
I did own the Hensel's for about 8 years, and I never had a single problem.  They were great lights.  I sold them for some Einsteins, but I wish I hadn't.  That would be my personal recommendation, although I would also take a close look at the Elinchroms.
Kind Regards,
Xoán.
Fargonz
Fargonz Regular Member • Posts: 152
I had the older model Bowens prolights & found the very good.
I noticed the new Geminis have the dials on the side now- might be usefull in some situations, but I don't think it makes much diff.
One advantage with the bowens S fitting is you can get a wide range of acc without having to pay for ther brand version.
 Fargonz's gear list:Fargonz's gear list
Nikon D700 Nikon 1 AW1 Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF Fisheye-Nikkor 16mm f/2.8D +14 more
OP xobione Forum Member • Posts: 61
Thanks to both Fargonz and Decibel for your quick answer, still thinking.
Kind Regards,
Xoán.
Paul Jones
Paul Jones Senior Member • Posts: 2,421
Hi Xoán.
Personally, I think any of those brands should suit your needs.  Personal preference has much to do with your final decision.
This blog post explains how I chose my lighting kit (Elinchrom).
http://www.pauljones.org/?p=578
Best regards
Paul
Paul Jones
Klaus dk
Klaus dk Veteran Member • Posts: 5,054
Paul Jones wrote:
Hi Xoán.
Best regards
Paul
Paul Jones
Hi Paul
Although I agree with most of what you have written, I think that a 400 Ws strobe is between 1/3 and 1/4 of a stop below 500 Ws. A full stop down would be 250 Ws.
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm F2.0 Canon EF 50mm f/1.8 II +12 more
Klaus dk
I don't own or know any of the sets you have proposed, so I will share some general advice on using strobes for portraits.
Range of strobes is really important, especially for portrait photography. If you wish to use shallow DOF, you will have to be able to go very low in output. My strobes go down 8 stops from 300 Ws, and I rarely go over 75 Ws and often below 19.
As for continuous lighting, I think we are not even close yet. CRI is not nearly high enough and output is too low for most portrait use.
Paul Jones
Re: Thanks Klaus (NT)
Klaus dk wrote:
Hi Paul
Thanks Klaus.
Hi Klaus,
I had proposed this:
Thanks to all of you for sharing your knowledge and experiences.
Kind Regards,
Xoan.
Klaus dk
Took a look at the three. You'll be surprised at how much light you get at 15 Ws. For portrait use it's quite a lot. I shot some portraits recently at ISO 100, f/8 because I wanted depth of field. My main light in a 12"x48" strip box was at 75 Ws, the fill in a 6' octabox were around 50 Ws, it is situated behind me. The white background I lit with two 40" brolly-boxes at 60 Ws each to get a +1/3 stop above clipping.
Imagine how low I would have had to go if I wanted to use f/2.8?
Here is one of the pictures from that session:
Sailor Blue
Sailor Blue Forum Pro • Posts: 12,947
I really agree with Klaus that you want to make sure your lights have plenty of power variability.
I can shoot at about f/11 using a 300Ws light in a 40" softbox at 6' from the subject.  If I want to open my lens up for a shallow depth of field I can only go to about f/2.8 because I only have 5 stops of power control, 300Ws to about 19Ws.
I would never recommend studio strobes with less than 5 stops of power control.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Thanks Sailor, any Brand and model you may recommend/endorse?
Kind Regards,
Xoán.
Sailor Blue
Kind Regards,
Xoán.
I have no personal experience with Elinchrome but I see lots of reports of problems with their RF trigger system and too many reports of poor service from them.
Both the Bowens and Hensel lights have 6 stops of power variability vs 5 stops for Elinchrom, and with 500Ws I would definitely want 6 stops of power variability so I could shoot shallow depth of field portraits.
Personally I would go with either the Bowens or Hensel lights. To decide which look at the price, quality, and availability of accessories that you might want - girds ranging from 10° to 40°, softboxes from 24"x24" to 4'x6' with grids, medium and large octoboxes with grids, strip softboxes with grids, and beauty dishes with a grid and a sock.
