Battery charger flashing orange?
Started Aug 23, 2013 | Discussions
northlondon43
northlondon43 Senior Member • Posts: 1,941
I've just bought an extra battery off ebay for my NX20. When I've tried to charge it the charger light flashes orange (had it on for 12hrs).  As most of you know the normal sequence is red (not fully charged) to green (fully charged).  So has anyone any idea as to why this is happening?  When I put the battery into the camera everything seemed fine, i.e. showing as fully charged.  I've not had the time to use the camera for more than a few minutes to see if the battery drained in an unusual way...and it hasn't.
Cheers
Adrian
 northlondon43's gear list:northlondon43's gear list
Fujifilm X100V Panasonic Lumix DC-G9 Panasonic Lumix G 25mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +4 more
Coldamus Senior Member • Posts: 2,281
Re: Battery charger flashing orange?
Page 162 of the (English language) manual:  If the indicator light blinks orange or does not illuminate, reconnect the cable or remove the battery and insert it again.
Bryan M
Bryan M Contributing Member • Posts: 956
Cheers
Adrian
You may have a bad battery, just keep an eye on it and make sure its holding a decent charge. I have had an after market go bad like this in the past.
Bryan
www.bcmcue.com
 Bryan M's gear list:Bryan M's gear list
Nikon D750 Nikon Z6 Tamron SP 70-300mm F4-5.6 Di VC USD Tamron SP 70-200 F2.8 G2 Nikon Z 14-30mm F4 +2 more
northlondon43
OP northlondon43 Senior Member • Posts: 1,941
Thank you. I've already tried that and it makes no difference. I also put a Samsung branded battery in and it reverts to the normal red light then green.
Adrian
The instruction in the manual implies that sometimes the battery may be in an abnormal state, perhaps just a temporary glitch.  If it didn't clear when you reset it, there's a good chance it didn't charge properly.  You'll only find out by how long it lasts when you use it.  Perhaps it will accept charge once it has been used.  Perhaps not.  The aftermarket batteries can be a bit of a lottery.
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
I would not use that battery if I were you. It could somehow damage the camera.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
arbuz Senior Member • Posts: 2,247
I had the same issue. I bought 2 aftermarket batteries for NX20 from HAMA. One was causing charger blinking orange => dead on arrival. Fortunately no issues with the replacement in my case.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
Annie Lane New Member • Posts: 1
Help. I have this exact problem and I tried out your answers but it didn't help at all. When I took out the battery and put it back in and did the same with the charge it flashed red once but then went back to orange.
Zeluis New Member • Posts: 1
This problem is usually with the power source. If you are using an after market charger it might be lower power output. With most electronics it still works just takes longer, but the charger is recognizing that there isn't as much power going to the battery as there should be. This is also why they say to take the battery out then back in, because of its not flush against the metal contacts then same problem, not as much power goes there as should.
leidya New Member • Posts: 1
When i charging my camera, the battery have orange flash and i continued it. When i wanted to use it, its not fully the battery 😭
Please someone help me
Victoria Hazel
Victoria Hazel New Member • Posts: 6
That could mean anything. Mostly when I had that problem my phone would usually ask me to reset or my battery has expired or I need to buy a new phone
victoria
