Better than the twin lens kit
Started Aug 16, 2013 | User reviews
Pacstar
Pacstar New Member • Posts: 4
I purchased this as the standard lens with my 7D. Although quite a heavy combination, it provides a very usable walk around combination. I only swap it out for the 10-22mm occasionally. After several year however and having seen the results of some of the prime lens I think the results from the  18-200mm are a little soft but post processing can boost that without too much trouble. It does however fully extend whenever facing down so you either have to remember to lock the lens in using the conveniently place lock or just be careful. This will inhibit its use in a tripod as gravity will soon take over as the lens tips down.
 Pacstar's gear list:Pacstar's gear list
Canon EOS 7D Canon EOS 60D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 18-200mm f/3.5-5.6 IS Canon EF-S 18-135mm F3.5-5.6 IS +7 more
Lens • Canon EF-S • 2752B002
Announced: Aug 26, 2008
Pacstar's score
4.0
Average community score
3.3
Philip Kendall
Philip Kendall Contributing Member • Posts: 789
Re: Better than the twin lens kit
The thing you haven't mentioned in this review is what makes it better than the twin lens kit - anything more than the fact you don't have to change lenses?
 Philip Kendall's gear list:Philip Kendall's gear list
Canon PowerShot SD1000 Canon EOS 550D Canon EF 50mm F1.8 II Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 IS II
