Nice but flawed
Started Aug 16, 2013 | User reviews
Pacstar
Pacstar New Member • Posts: 4
Nice but flawed
This was a really nice general walk about lens. I had several years faithful service with some very crisp results. However it failed. Just like so many other people with this lens, "error 99". Turn the camera off an on would reset it for a while until finally even that stopped working. Searching the net and I found it to be a very common fault of this lens. Apparently an internal wiring harness breaks. I wasn't prepared to spend the money to get it fix so I sold it as is (with full disclosure as to its problem) and still made AU$150 so I was happy. I see it has been replaced with the 15-85mm so I hope Canon also fixed the fault.
 Pacstar's gear list:Pacstar's gear list
Canon EOS 7D Canon EOS 60D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 18-200mm f/3.5-5.6 IS Canon EF-S 18-135mm F3.5-5.6 IS +7 more
Canon EF-S 17-85mm f/4-5.6 IS USM
Zoom lens • Canon EF-S • 9517A002
Announced: Aug 19, 2004
Pacstar's score
3.0
Average community score
3.6
scrup Contributing Member • Posts: 595
Re: Nice but flawed
I had the same problem, got it repaired from canon us for 110 dollars total. optically it is not as good as the 18-55 kit lens but I like the range on it.
after the repair, it shoots wider so I guess canon recalibrated.
 scrup's gear list:scrup's gear list
Canon EOS M Canon EOS M3 Canon EOS M6 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM +2 more
tonyjr
tonyjr Veteran Member • Posts: 5,295
Re: Nice but flawed
I looked at it , the 15-85 and the 17-55 . Ended up with the 17-55 .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
aus_pic_hunter Contributing Member • Posts: 506
Re: Nice but flawed
I had the same issue after 5 years use. Cost only a few dollars and an hour work to replace the flex cable. The lens is as new again.
 aus_pic_hunter's gear list:aus_pic_hunter's gear list
Nikon Coolpix AW120 Canon EOS 20D Canon EOS 6D Canon EF 28mm f/1.8 USM Canon EF 85mm F1.8 USM +3 more
Re: Nice but flawed
And here are some pictures to show the inside of the 17-85  lens and the replaced flexcable.
http://www.dpreview.com/galleries/9492148352/photos/1316125/power_diaphragm_with_faulty_cable
http://www.dpreview.com/galleries/9492148352/photos/1316124/new_flex_cable-ef-s-17-85
I did the repair outside on my patio table on a clear Sydney day. The parts are not on the lawn, that the table cloth. I took the opportunity to clean the dust out of the lens and it is like new again.
The EFS17-85 is basically the only lens I use on my 20D now the 6D is my main camera. It is the oldest lens I have with the most shots of all lenses.
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: DIY cable replacement
You don't happen to have step-by-step instructions for that do you?  Looks pretty daunting to dive into that w/o some guidance.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Sir Canon
Sir Canon Senior Member • Posts: 1,572
ive done it. canon creases the wire in some spots, and it should be curled instead so i did that and it works fine
 Sir Canon's gear list:Sir Canon's gear list
Panasonic Lumix DMC-TS1 Canon EOS 350D Canon EOS 550D Canon EOS 700D Canon EF 50mm F1.8 II +6 more
ZX11
ZX11 Veteran Member • Posts: 6,156
Youtube is your friend if you need video instructions on how to do something.
"Very funny, Scotty! Now beam me down my clothes."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
