Majestic Mt. Robson of the Canadian Rockies
Started Aug 14, 2013 | Photos
jtimar84 Regular Member • Posts: 200
This was one of those shots that was really disappointing when I first looked at the results at home. The extreme contrast of the scene required my to dial down my exposure more than I would have liked, which left my shadows muddied. A blended exposure would have been ideal here, but it was starting to rain so hauling out the tripod was not an option at that point.
Still, I am happy with the final result, mostly.
What do you think?
http://inthelimelight.net/the-majestic-mount-robson/
Comment & critique:
vander
vander Senior Member • Posts: 2,671
Re: Majestic Mt. Robson of the Canadian Rockies
It's a nice shot, I like it.
I might try cropping a little of the black negative space off at the bottom making it a more landscape oriented shot.
I'd also like to see the shot not on your brown background of your website too. I'm wondering if that makes it pop as much as it does because it picks up the browns in the mountains.
All in all a very nice shot.
Check out my photo galleries !!
http://www.vandervalk.ca
stickpointed Forum Member • Posts: 50
You really need to crop a lot of the bottom out of this image.  With the great contrast in the clouds try going B&W.
OP jtimar84 Regular Member • Posts: 200
Thank you Jason.
If you click the photo when you are on the website, it will load a larger size in a with the background darkened to nearly black. Oddly enough, I have considered changing the background of my site to a more grey shade at times, but after trying it it just looked cold to me.
I debated a lot about cropping out the bottom more, but my fiancee said she liked the tress and convinced me to keep them. I'm still not so sure, my initial though was to play with the levels are keep just the tops in as a silhouette.
I agree, thank you for confirming my suspicions! Done.
David Nall
David Nall Forum Pro • Posts: 16,046
What do you think?
First of all, get rid of the water mark in the center of the image. After that, I would lighten up the foreground so more than just black is there. If you don't like that option, than cropping would be my second choice.
Visit my gallery at http://davesphotography9173.zenfolio.com/
View of Yosemite Valley, Bridalveil fall 4 frame vertical pano taken from the tunnel parking lot.
http://davesphotography9173.zenfolio.com/img/s2/v58/p1109307522-2.jpg
 David Nall's gear list:David Nall's gear list
Sony Alpha NEX-7 Nikon D4 Nikon D800E Nikon 1 V2 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +11 more
What do you think?
Ah, I was wondering when the anti-watermark crowd would show up. Sorry, but I don't like to make it easy for thieves. http://stopstealingphotos.tumblr.com/
I had the background lighter previously, but the consensus was that there was not enough detail there and it would be better off cropping it out or darkening it completely, which I have done. There actually is plenty of detail there, but it's noisy and flat and doesn't look good to my eye...
I have already cropped it a fair bit as well, from 4:3 ratio down to 3:2, are you suggesting to go further?
