SLR Magic 25mm -light gathering capabilities
Started Aug 14, 2013 | Discussions
frnkoch New Member • Posts: 14
Hi Folks
A few days ago I received an SLR Magic 25mm T0.95 lens. I immediately began doing some initial tests, especially of the light gathering abilities when shooting wide open. To be honest, I was shocked.
At apertures above T1.4 the lens behaves perfectly normal, with each aperture stop corresponding to one EV more light gathered. This is how a lens should behave. But beyond T1.4 and up to T0.95, the lens does not gather much more light. In fact, when turning the aperture from T1.4 to T0.95, it only gathers about 0.3 light units more light, when it should be 1EV in theory.
I did some research and it turns out that this seems to be a problem of modern sensors, not of the lens itself. At very small apertures (F/1.2 and smaller) the sensors fail to use the additionally available light. Here is an article explaining the effect:
http://www.dxomark.com/index.php/Publications/DxOMark-Insights/F-stop-blues
It turns out that for low light shooting, a very large aperture is almost useless. You gain very little by going from F/1.2 to F/0.95, except a thinner depth of field.
What do you guys think? Should I just send the lens back??
secretworld Senior Member • Posts: 1,734
Re: SLR Magic 25mm -light gathering capabilities
I don´t think you will get a much thinner DOF either. Since the light from the widest part of the aperture is hardly seen by the sensor. But if you like the lens at 1.2 or how it renders at 0.95 keep it!
 secretworld's gear list:secretworld's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GM5 Panasonic Lumix G 20mm F1.7 ASPH +7 more
Pedagydusz Veteran Member • Posts: 5,638
It also depends on the camera (sensor) itself, apparently (according to that article and others) some cameras are more sensitive to that issue than others.
Which camera were you using?
 Pedagydusz's gear list:Pedagydusz's gear list
Sony Cyber-shot DSC-F707 Panasonic Lumix DMC-GX7 Canon EOS 7D Olympus E-M1 Panasonic Lumix DMC-GX8 +3 more
OP frnkoch New Member • Posts: 14
Indeed, the depth of field doesn't change much past T/1.4 either, just tested it. Although it is hard to quantify this aspect, I might be wrong here.
But it is quite a disappointment, considering that the lens is VERY expensive and relatively hard to use.
I tested it on an Olympus OMD.
Best way to test DOF is to photograph a ruler.
I just did a ruler test, the lens behaves like T/1.2 when set to T/0.95, regarding depth of field.
I do have some good news to report, though. Stopped down to T/2.0 the lens becomes extremely sharp! It easily beats my oly 17mm f/1.8 in centre sharpness. I will test the corners next.
tjuster1 Senior Member • Posts: 2,222
frnkoch wrote:
Hi Folks
Wow, really interesting. Even more concerning is the inverse correlation between pixel pitch and light-loss--modern m43 cameras, with their tiny pixel pitch (lower than anything in that diagram), would be expected to experience the most light loss.
Also makes me wonder if this is an argument against the trend toward more and more megapixels, which we're once again seeing. The new Sony NEX is rumored to have 32 MPix for example!
 tjuster1's gear list:tjuster1's gear list
Olympus E-M5 III Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 35-100mm F4.0-5.6 ASPH Mega OIS +6 more
coffeebean Regular Member • Posts: 102
If you are using average metering, whatever light you gain the central portion gets offset by the lightloss in the border region from vignetting. Spot metering will give you a better idea.
I did use spot metering. Sorry, but after T1.2 the sensor just isn't able to use the additional light.
honeyiscool
honeyiscool Senior Member • Posts: 1,376
How about when it's completely dark outside? I'm curious to see how it works then.
 honeyiscool's gear list:honeyiscool's gear list
Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus 12-40mm F2.8 Pro +2 more
Same thing, really. I did some shooting last night. Going from T/1.4 to T/0.95 gives about 0.3 EV.
My conclusion: Don't bother with super fast apertures.
Chez Wimpy
Chez Wimpy Veteran Member • Posts: 9,055
Something to keep in mind regarding the upcoming (f0.95 and f1.2) 42.5's...
FF suffers from this problem as well, but in that case, there aren't many (faster than f1.4) lenses to worry about.  Ironic that f0.95 on m43 emerged as a way to match fast primes on FF for DOF control, yet...
-CW
 Chez Wimpy's gear list:Chez Wimpy's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 5D Mark II Canon EOS 20D Canon EOS 550D Panasonic Lumix DMC-G1 +32 more
SeeRoy Senior Member • Posts: 1,666
But, but, but... what's the "unboxing experience" like?
Roy
robonrome
robonrome Senior Member • Posts: 2,334
If this is generally the case I'll have to rethink my plan to buy the 17.5 nokton
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +10 more
Abrak Veteran Member • Posts: 4,186
frnkoch wrote:
Hi Folks
Arent you confusing F stops and T stops here. Your post doesnt really make sense to me?
Abrak wrote:
frnkoch wrote:
Hi Folks
Here is what confused you: The article by dxomark uses F stops, my lens has T stops. Thus I spoke of T stops when describing my measurements and of F stops when summarizing the article.
Well, I'm having a bout of buyers remorse now. Don't get me wrong, you still get something like a T1.2 or T1.1, which is already pretty amazing. But it doesn't seem to be worth the high price.
No you are the one I think is confused. Your lens is measured in T stops - it is a T0.95. A lens like the the PL 25 1.4 is measured in F stops. By definition T1.4 will gather more light than F1.4. By definition an F0.95 lens will have less than 1 stop difference in light to an F1.4 stop.
A T stop is a measurement of light gathered by the lens - an F stop is not. If you are claiming that at T0.95 lens only gather 0.3EV additional light compared to T1.4, you are simply claiming that SLR Magic are fraudulent which I highly doubt and I dont think you meant to imply.
Not quite. The lens does gather an additional 1.0EV when going from T1.4 to T0.95. I trust SLR Magic. But, as stated in the dxomark article I have linked, the imaging sensor fails to use this additional light. This is due to the fact that a part of the light from very large aperture settings hits the sensor from an unfavourable angle, reducing the ability of the micro lenses to focus this light on the photo diode.
In fact, I am in contact with SLR Magic and they have given a partial confirmation that this problem does exist.
Conclusion: The SLR Magic 25mm is still the fastest M43 lens on the market. It is just not as fast in practice as in theory.
