Canon 100-400L jumps on image-stabilization
Started Aug 13, 2013 | Questions
Apparition1234 New Member • Posts: 3
Hi,
I just purchased a 100-400L. When I half press, the image jumps in the viewfinder, then 2-3 seconds after releasing the button, the image jumps again. I was told this is normal for long focal length lenses with image stabilization. It is more obvious out at 400mm.  It does not happen when IS is turned off.
Is this normal?
P.
OhioBob Regular Member • Posts: 429
Re: Canon 100-400L jumps on image-stabilization
Just mounted mine to my 7D and it does not jump when engaged is dissengaged. Hand holding at 100mm and 400mm.
 OhioBob's gear list:OhioBob's gear list
Olympus C-750 UZ Canon EOS 7D Canon EOS 7D Mark II Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +8 more
Memory Leak Junior Member • Posts: 41
Apparition1234 wrote:
Hi,
Is this normal?
P.
Yes.
bronxbombers4 Veteran Member • Posts: 3,387
Hi,
Is this normal?
P.
yeah
Digital Shutterbug Veteran Member • Posts: 5,487
Hi,
Is this normal?
P.
yeah
Completely normal.
Steve
mailman88
mailman88 Veteran Member • Posts: 6,291
+1 also
 mailman88's gear list:mailman88's gear list
Canon EOS 30D Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 200mm f/2.8L II USM Canon EF-S 10-22mm F3.5-4.5 USM +4 more
RS_RS Senior Member • Posts: 1,788
Hi,
Is this normal?
P.
Up to a point. The image will jump a bit as IS starts and finishes, but if it jumps repeatedly you have a problem. I have just had to send mine to Canon to fix this.
happysnapper64 Veteran Member • Posts: 5,421
I have a Sigma 120-400 OS & there is no "jump" with the stabilization. My 70-200f/4 IS is a bit noisy, but again, no jump. The Tamron 70-300VC jumps when stabilization is activated & freezes the image in the viewfinder, but this is a feature of this lens. Methinks you should get it looked at.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
"I'm so fast, when I turn off the light, i'm in bed before the room gets dark" The great Mohamed Ali.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +6 more
robbert100 Contributing Member • Posts: 714
1+ had to send in mine also, it was repaired under warranty.
Best regards,
Rob
 robbert100's gear list:robbert100's gear list
Canon EOS M Canon EOS 7D Mark II Canon EOS M10 Canon EOS 5D Mark IV Canon EF 100mm F2.8L Macro IS USM +2 more
Just Having Fun Veteran Member • Posts: 3,869
Common on Canon IS Binoculars
I own a couple different Canon IS Binoculars and this is common.  Not sure why.
OP Apparition1234 New Member • Posts: 3
It ONLY jumps at the 1/2 press (or full press) and 2-3 seconds later (when I assume it stops ISing).  It does not jitter in-between.
My Canon 18-135 IS does not do this. Any ideas why the L needs to?
R2D2 Forum Pro • Posts: 26,550
It was just born that way.
R2
Daniel L Contributing Member • Posts: 939
When IS engaged on long focal lens, it jerk a little then you can hear whine on the coil but not jump.
You are describing the issue i used to have with my 1-4. I was having sharpness problem and thought so the jump may be normal until i tried on friend's unit that just brought new and was much sharper than mine. It jerks a little but not to level that my unit was exhibited. Sent it in and Canon fixed it with IS coil issue.
Same thing with my 500mm, it doesn't jump.
Hi,
Is this normal?
P.
Macro and Bird Photography
http://www.danielslim.com
gavin
gavin Veteran Member • Posts: 8,242
+1 slight jump
What camera do I have? I rather you look at my photos www.flickr.com/photos/gavinz
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
Jay A Senior Member • Posts: 2,576
This is quite normal even though some lenses do this and some don't. It is of concern if it KEEPS jumping after it has stabilized, but what you describe is fine.
