DP3 Merrill + Strobes
Started Aug 11, 2013 | Discussions
linux99 Senior Member • Posts: 2,151
I do a lot of portraits. Mostly I use a m4/3 camera with a 45mm lens to give me a 90mm 35m Film lens equivalent focal length - works just right for head and shoulders in a typical room.
I recently bought a second hand DP2x - have been shooting with it on the street for a couple of weeks and love it. Reallt happy with the results I have been getting.
I'm thinking of getting a DP3M (which would give me the same 90mm equivalent focal length I am used to) but have one outstanding issue.
Indoors I prsume I will have to shoot with strobes, I am used to this and do it all the time. However I have heard some comments that you really dont get the best results with a combination of the Foveon sensor and single frequency (color temp) strobe lighting. Clealy this is a worry for me.
Is anyone using the DP3M with artificial lighting for portrait work? Would you like to share your thoughts / experiences? Are the stories I've heard true or groundless?
Any thoughts / help much appreciated.
 linux99's gear list:linux99's gear list
Sigma DP2x Canon PowerShot S100 Sigma DP3 Merrill Nikon Coolpix A Fujifilm X100T +19 more
Sigma DP2x Sigma DP3 Merrill
Bill Hollinger Senior Member • Posts: 1,301
Re: DP3 Merrill + Strobes
It’s actually a 75mm equivalent, not 90mm - I don’t know it that makes any difference to you. I used the DP2M and fortunately also a D800E to take photos at a birthday party recently. Like with other subjects, the Sigma picks up detail not readily apparent until you see it on the RAW files. You’ll spend a lot of time using one of the portrait plugins to make the images acceptable to your clients.
A French photographer (Hulyss Bowmas) has posted some excellent SP3M portraits on the Luminous Landscape site, but as I recall, they are predominately attractive younger women. You might want to take a look at the DP3M forum there, or Google his name and DP3M.
dmaclau Veteran Member • Posts: 3,053
As I don't do studio work I'm not really answering your question but I've experienced no noticeable image problems using foveon (DP1 & DP3M) and Nikon flashes.  It strikes me that you might test this with your DP2X.
 dmaclau's gear list:dmaclau's gear list
Fujifilm FinePix X100 Fujifilm X70 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
Johan Borg Veteran Member • Posts: 3,433
As mentioned above, DP3M is a 75mm equivalent, the new Foveon sensor is a 1.5 crop, not 1.7 as previous generation.
While Sigma cameras tend to have challenges with some artificial light and incandescent light in particular, I can't remember complaints when used with a flash. In fact, my own limited experience with a DP3M and a cheap Metz flash has been quite positive.
 Johan Borg's gear list:Johan Borg's gear list
Sigma dp2 Quattro Sigma fp Sigma 45mm F2.8 DG DN
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,587
I would try the DP-2x you have with strobes, as the result should not be too dissimilar...
I have done some model shots in studio off and on and think the camera works great with flash. Here are some SD-1 examples shooting at the studio Sigma had set up at their CES booth:
http://www.flickr.com/photos/kigiphoto/sets/72157632515761898/
The DP-3M should look quite similar to those, just a bit sharper at the edges.
One example image:
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
Hornbrille
Hornbrille Regular Member • Posts: 371
DP3 Merrill + Strobes is the best combination
The Merrill sensor works very good with flashlight. Have a look at some of my basic studio shots. I'm using several studio flash heads, a Metz 45CT strobe (potato masher) and several Sigma strobes with my DP3M or DP2M. Here is another album of shots with the EM-140 DG Macro Flash.
Edit: The DP3M is usable for portrait but you need to be careful with mixed lighting as with other cameras as well.
Uwe 8-)
 Hornbrille's gear list:Hornbrille's gear list
Sony a7 II Sigma sd Quattro H Sony a7 III Panasonic Lumix DC-S1R Sony FE 35mm F2.8 +6 more
PrebenR Veteran Member • Posts: 4,164
I have never had a problem, but could it be that those issues are related to if you only shoot JPGs?
Lightwriting with Sigma
OP linux99 Senior Member • Posts: 2,151
Thanks!
Thanks Guys for all the answers. Lots of useful feedback - really helpful.
Did it. Thanks for the help.
So I just ordered a DP3M - should be here in about a week.
Thanks for the help guys.
SigmaChrome Forum Pro • Posts: 15,728
Absolutely not. In my experience, you are far more likely to weird white balance results from JPEGs than than RAWs. Skin tones will be harder to control as well.
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
Huh? That is what I said. Shooting RAW you simply correct for it afterwards, doesn't matter what WB you used. For JPGs it is not easy.
PrebenR wrote:
SigmaChrome wrote:
PrebenR wrote:
While Sigma cameras tend to have challenges with some artificial light and incandescent light in particular, I can't remember complaints when used with a flash. In fact, my own limited experience with a DP3M and a ch eap Metz flash has been quite positive.
My bad. I misread your post.
