NX300 + wireless flash trigger + Yongnuo YN560 II Flash Speedlite
Started Aug 11, 2013 | Questions
NewForce Senior Member • Posts: 1,263
Re: NX300 + wireless flash trigger + Yongnuo YN560 II Flash Speedlite
Raw Jaw wrote:
emirphoto wrote:
My camera is the Samsung nx300 and doesn't have optical viewer finder..all has to be set on the screen.., I couldn't find the framing mode that you mentioned.
Any advise??
You can not be in Auto mode to see Framing Mode on the menu
as I described above.
Try P,A.S,M.
Your other issues can wait until you turn on Framing Mode.
emirphoto, Raw Jaw was right. You'll need to set your NX300 in P, A,S, or M modes by then only you can see the "Framing mode". Click "Menu" button > Camera icon > Framing mode > On. In the user manual it explained,
Framing mode
When you adjust the aperture value or shutter speed, the exposure changes according to the settings, so the display may darken. With this function on, the brightness of the display is constant regardless of the settings, so you can better frame your shot.
Kenny
Locowood New Member • Posts: 1
I couldn't get my NX300 to fire a Yongnuo either in the hot shoe or with a CBS trigger.  After a time with tech support, figured out that it won't fire when the shutter speed is faster than 1/160. Once I slowed the shutter speed it worked fine.
Sami Kontto
Sami Kontto Contributing Member • Posts: 505
I have same proplem nx300 and nx30, i test elinchrom, jinbei, yongnuo.. sometimes it works and normally not (hotshoe was proplem) ; ( nx1 is great
 Sami Kontto's gear list:Sami Kontto's gear list
Sony a7C Sony a7 IV Sony E 35mm F1.8 OSS Sony FE 85mm F1.8 Sony FE 24-105mm F4 +2 more
PTurbo Forum Member • Posts: 87
http://flashhavoc.com/yongnuo-yn560-tx-now-available/
this one works with my nx300  GNX, NX30 and NX1 . I got the canon model
 PTurbo's gear list:PTurbo's gear list
Fujifilm X10 Fujifilm X30 Canon EOS 5D Samsung GX-10 Samsung NX300 +11 more
phans2k Regular Member • Posts: 141
You got any samples pictures of some results or some set ups photos?
 phans2k's gear list:phans2k's gear list
Samsung NX1 Fujifilm X-T3 Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung NX 45mm F1.8 +5 more
r0brwy Junior Member • Posts: 29
Thank you locowood. This problem has been driving me crazy. Your post solved the problem ..and saved my sanity.
Ahnaf Lubab
Ahnaf Lubab New Member • Posts: 2
I'm able to fire YongNuo 560II flash from my Samsung NX30's hot shoe and using 3Light NE FM-radio Trigger to use the flash off the camera wirelessly.
3Light NE series to use the flash off-the-camera
emirphoto New Member • Posts: 15
Hi did you or any one had resolve or get working the 2nd curtain or rear curtain using a wireless transmitter flash on any Samsung nx camera????
shafk New Member • Posts: 5
Do you have a link to the trigger - As i'm interested in getting a set for my NX300.
Thanks!
 shafk's gear list:shafk's gear list
Sony RX100 VII Canon EOS 5D Mark III Canon EOS M6 II GoPro Hero9 Black Canon EF 100mm f/2.8 Macro USM +6 more
