Samsung NX20 vs Sony A58
Started Aug 5, 2013 | Questions
michael85 New Member • Posts: 13
These camera kits (18-55mm) cost exactly the same (399euros=530$) in my country.
A58 over NX20:
-Phase detection AF (+ while recording video)
-Better focus peaking for MF
-Better battery life (+330 shots)
-Cheaper lenses
-In-built image stabilization and focus motor
NX20 over A58:
-Larger (+0.3") and crispier screen (+150K pixels)
-Faster burst rate (+3fps)
-Slow motion video (720p at 60fps, 480p at 120fps)
-Metallic lens mount
-Wi-fi (+remote viewfinder via smartphone)
-1/8000 max shutter speed
As you can see, it is very difficult to pick between the two cameras. Videography and photography are of the same importance for me.
If I buy two more Samsung lenses (45mm f/1.8 + 50-200mm f/4-5.6), the NX20 is about 100euros (=130$) more expensive than the A58 (+2 equivalent Sony lenses), so they re essentially equally priced.
Samsung NX20 Sony SLT-A58
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Re: Samsung NX20 vs Sony A58
they are both very good cameras.
the nx20 is much lighter (almost one half) body only. The sony is also much thicker, as you can see here:
http://camerasize.com/compare/#318,443
so if size/weight advantage is important to you, nx20 is much better.
besides nx has a lot of nice prime pancakes (16,20,30 and soon 10mm).
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
ChuckTa Senior Member • Posts: 1,492
It really depends on how you will use it. If you take a lot of action shots, then A58. If you take a lot of stills and prefer to take it everywhere ( you can easy put you NX20 in your backpack), then NX20. But if you can do without the EVF, then definitely NX300.
 ChuckTa's gear list:ChuckTa's gear list
Sony a7 Samsung NX500 Fujifilm X-T20 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GF10 (GF90) +8 more
OP michael85 New Member • Posts: 13
Both the answers above, mention the size of NX20 as its only advantage.
Since I am going to carry a bag for either of the two cameras (+at least 3 lenses and a small tripod), I really don't care if one of them is a few grams lighter or a few cm slimmer. If size was my concern I would pick Sony NEX-3N.
tecnoworld
I also mentioned the pancakes primes, actually
Anyway the main advantage of a mirrorless camera over a dslr shaped one is size and weight. The a58 has great iq and dr, about on par with nx20. So these cameras are basically equicpvalent, but nx20 is much smaller and lighter.
Base your choice on the lens lineup, if weight/size aren't important for you.
NewForce Senior Member • Posts: 1,263
What a about you give Samsung NX300 a try?
Yes, it may come without an up to be desire EVF, but you'll have a large 3.31" AM-OLED screen to compensate the changed.
Pixels count may not as high as a tiny OLED-EVF, but again the 3.31" AM-OLED screen was a huge screen to watch comfortably with both eyes  than a tiny EVF with squeezing single eyeball to watch that left to be desire, plus it's an suffocating experience, every single time you have to sticked the camera up close with your nose compressed and twisted side way.
Kenny
Samsung NX300 kit (18-55mm) costs 690euros (=910$). Quite a long way from the 530$ of the NX20 don't you think? The price difference is so huge that defines the NX300 as "off-topic".
P.S.: The prices mentioned above, as well as in the original post, apply to my country's retail stores (Greece). I am not interested in internet deals or discounts that may put the NX300 at the same price range of ~500$ (although I doubt there is such a big price difference between retail stores and internet).
So in your photography philosophy was all about "Value for money" instead of "Performance"?
So you are suggesting that every photographer should buy every brand camera with 1 generation behind for the better value for money philosophy of yours?
I'm fine with that, but good luck to you.
Kenny
If u look at it side ways, the NX20 is almost half the size of A58. So it's not just a few mm difference. I carry my NX200/NX300 almost every time I go out, I don't think you can do that with the A58.
I had an Nex 5 and I used the Sony DT 50/f1.8 and DT 55-210 with adapter on the Nex. I sold it quickly, quality is not that high. I have the Samsung NX 50-200 and it is a much better tele zoom. I don't have the NX 45/f1.8 but I have the NX 30/f2 and to me that lens is better than the Sony DT 50/f1.8. I have not use the top Sony lens, but if you are just getting the bread and butter line up, than my opinion Samsung lens quality is better. Oh I forget to say that the NX kit is also better than my Nex kit. I have 4 Samsung NX lens and 1 Nex kit lens. But Sony has more lens to chose, and Samsung may not have the range you want.
Chris62 Contributing Member • Posts: 693
A58 over NX20:
-Cheaper lenses
NX20 over A58:
Do not think about camera only.
You are going to enter into the system so yo should thing about system as on epart.
Define your needs - lenses you will nedd accesories and budget.
NX is for pepole who need good quality in small and light package.
It is obvious that if the size doesn't matter comparable DSLR is better camera.
But personally I like the newest Panasonic GX7 - small with everything what can be placed in the body.
Sony SLT I do not like becuase of mirror between lens and sensor.
You also forgot abou sensor NX20 has 20 MP very nice sensor when used in RAW mode.
I use NX10 that I bought only I got 30/F2 in the set and there was not competition in that price.
After 3 years of usung I can say it is very good camera also very good quality service was not becesseray but it is made in Korea.
I am not sure if cameras made in China will be also good quality.
Zoom 50-200 is nice lens- maybe not the top resolution but AF is Ok and bokeh is very nice.
I can not comment Sony zoom because I did not use it.
In genera NX system is very nice but underrated and not rich in accesories - still no decent flash and still no body we can say it is profi.
Still no fast zoom lenses.
I treat ma NX as a compact camera - if you use panacake 30/2 (or other) it is compact - isn't it?
But sometimes I use it as a DSLR ->50-200 is a little heavy and middle size - normal if we consider taht is equipped in OIS and quiet and fast USM AF.
18-55 is similar nice consruction.
 Chris62's gear list:Chris62's gear list
Panasonic Lumix DMC-LX7 Samsung NX30 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +2 more
RPywell Regular Member • Posts: 148
Until just over a year ago my system was based around a Sony SLT-A35, then I bought my first Samsung and within a few weeks sold the Sony system - no regrets!
However, I never shoot video so that may or may not make a difference.....
tecnoworld
As for the flash remark, actually the metz 44 is very decent...or, better, very good
jennyrae Senior Member • Posts: 2,690
fast zoom do not make sense in small body, also do not give much benefit as was many moons ago.
system can use good dedicated flash but not much problem because of 3rd party support and wireless trigger.
built-in evf is ok. do not like it as accessory.
HendeHoq Junior Member • Posts: 33
I wanted to buy a Sony A58, but instead bought the NX300 and have not regretted it. However, focusing in the video mode is a NX300 weak point. And if a video was something important for me, I would definitely buy A58.
 HendeHoq's gear list:HendeHoq's gear list
Fujifilm FinePix Real 3D W3 Samsung NX300 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED +3 more
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
In my limited use of the video on the NX300 I believe some lenses focus much more efficiently than others. Of my lenses the 45mm is pretty fast and also the 18-55mm is good for my video usage.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
Ralf Bauer Regular Member • Posts: 183
Get the best of two worlds
I have NX11, far more sweet is my NX200, one year ago I bougt SLT-A37
Wheras I swore never to buy a camera with a sluggish 2.7 inch screen, I do not want to it miss it, since I got excellent lenses Samsung does not offer or are far more expensive.
Minolta 50mm f1.7 (can be had very cheap)
Sigma 90mm f2.8 Macro (excellent macro and portrait lens)
Sigma 70-200 F2.8 APO (excellent lens for concert shots - but really heavy)
Nowadays it doesn't make sens to believe, you buy into ONE camera system. Reason: bodies are so cheap, throwing NX200 + 30mm lens into the bag will release you from lens swapping. Two cameras around your neck will give you the best of two worlds.
I also keep sweetly in mind, all this old glass mentioned above is FF capable .... and will work on future Sony FF cameras (one that is in my funds).
 Ralf Bauer's gear list:Ralf Bauer's gear list
Sony Cyber-shot DSC-R1 Sony a7R Samsung NX500
tecnoworld
Re: Get the best of two worlds
The only lens you mentioned that nx is really missing is a fast zoom, since the 45mm f1.8 is much sharper than the minolta 50mm and the 60mm macro is also very nice and comparable to the 90mm you quoted.
(unknown member) Veteran Member • Posts: 6,192
Do not forget the Sony branded lenses such as the 50mm f1.8 and 30mm f2.8 are cheap at only £150 in the UK. I just bought the latter 30mm for £99 refurbished from Sony and I think it is just stock clearance as it is like new. This lens can focus from 5" to infinity. Probably not sharp if you want to see the molecules in the corners but not a bad lens. You can get the Tamron 70-300 for £99 in the UK with a 5 year warranty.
I think the A58 seems outstanding value for money and if size is not the driver the best choice. The Sony SLT's are pretty large beasts though and the A37/A58 are the only ones that I think are nice to handle weight and sizewise but are still lumpier than the NX20 and the NX 18-55 does rather negate the size difference, much preferred the 20-50 myself. Difficult choice.
Hi tecnoworld,
Samsung 45mm f1.8 must be a beast of a lens. I have no scientific proove that Minolta 50mm f1.7 behaves as good .... wide open it will certainly not, finally its a twenty year old lens design. Just take a look at these DXO charts to get an idea how good these old minolta lenses are.
http://www.dxomark.com/index.php/Lenses/Compare-Camera-Lenses/Compare-lenses/(lens1)/188/(brand)/Konica%20Minolta/(camera1)/562/(lens2)/1036/(brand2)/Samsung/(camera2)/0/(lens3)/217/(brand3)/Sony/(camera3)/0
As far as I know how to read these DXO charts, my modest conclusion about the new 45mm Samsung lens .... Up from F2.8 these two lenses will behave as good as the other. You can hardly tell one lens from the other. Samsung lens will perform better wide open. On the downside Samsung 45mm will offer you no OIS like the Sony/Minolta.
Pls obey: the comparison above includes only Minolta 50mm f1.4. This lens  performs quite alike (I have both lenses). DXO has not tested the Minolta F1.7 version.
fotophool Veteran Member • Posts: 4,340
Current A58 Review
