HENRY'S CANCELLING ORDERS on 45mm f/1.8 (purchased at $199 sale price)
Started Aug 1, 2013 | Discussions
timedrun Contributing Member • Posts: 683
Re: lens hood
I have a rubber lens hood for my 85. I do like them, ive not been able to find a 43 version yet, I would be hapy to be guided to one.
A little green rosetta......a tiny green rosetta........
 timedrun's gear list:timedrun's gear list
Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake Samsung NX 45mm F1.8
Timmbits
OP Timmbits Contributing Member • Posts: 617
Re: lens hood
You are correct, I found none either when I wanted one. However, I did a search just now, to see what comes closest, and I found 2 on ebay that are for a 43mm thread. The least expensive is only $4 shipping included, from Hong Kong. Search for eBay item number 251181195615
For me, it's a good thing I didn't find a 43mm lens hood at the time, because with the 30mm lens it was destined for, it would have cut out the edges of my photos as the 46mm is just the perfect size for it.  I use the same one with my new 45mm lens, however, I might just get this 43mm one for the new lens.
 Timmbits's gear list:Timmbits's gear list
Panasonic Lumix DMC-TS3 Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 45mm F1.8 +2 more
Timmbits
first quickie shots
tecnoworld wrote:
Good th hear that everything went fine. Now, how do you like your new lens???? I personally love the 45mm. At present it's my most used lens.
I've posted a few quickie pics in my NX20 Gallery. http://www.dpreview.com/galleries/1310839954/albums/samsung-nx20
No works of art here - just first shots. Although this is off-topic for this thread; all is well that ends well.
atarget Regular Member • Posts: 171
Re: lens hood
Timmbits wrote:
timedrun wrote:
The good news is you have your 45! It's a very good lens. The hood works with the 30mm as well without vignetting.
I hate the hood - it screws onto the filter thread, instead of a quick twist-snap-on. I find it impractical because it makes the whole camera assembly large for when putting away into a bag. Removing it will quickly wear the plastic thread, and I don't want to leave it on, because I don't know how strong the thread mount on the lens is in case of impact, with the leverage given the hood's length.
I use a rubber lens hood that I got for a few bucks on ebay. it is for a 46mm thread, with a 46mm-43mm ring adapter. On the 30mm lens it is precisely the right size for no vignetting (narrow it at the corners with your fingers and it'll vignet, that's how I checked), and it works quite nicely on the 45mm as well. The rubber hood collapses, and makes for easy storage into a camera bag without unscrewing the lens hood.
I only use metal screw - on  hoods. On all of my glass. I don't believe in plastic or rubber.
Just get yourself UV filter. Even the cheapest ones come with metal ring. Or if you don't routinely
protect your glass with them ( I do and always will) just get yourself a metal step-up ring, keep it on permanently  and buy metal hood with tread size  to match step - up ring.
I always recommend Fotga modular metal screw - on lens hood system.  By the way, their ND vario filters are  of great quality, too.
Timmbits
Re: lens hood
Maybe you don't believe in Samsung lenses then?  I'm not a fan of plastic either, and wished more lenses were still made of all metal parts.
Just get yourself UV filter. Even the cheapest ones come with metal ring. Or if you don't routinely protect your glass with them ( I do and always will) just get yourself a metal step-up ring, keep it on permanently and buy metal hood with tread size to match step - up ring.
I always recommend Fotga modular metal screw-on lens hood system. By the way, their ND vario filters are of great quality, too.
I own a nice metal hood, but I choose not to use it on Samsung lenses, because I don't want something stronger and more rigid than the lens, on the end of it where an accidental impact could happen.  Putting a metal UV filter on there only makes an impact's leverage that will act on the lens a bit longer, and will only (slightly) worsen the problem.
I find that the rubber hoods are nice for a couple of reasons: first, they have 3 positions: completely retracted for stowing in your camera bag (protruding less than my metal hood), half out for the wide-angle end of a zoom (which is about equivalent to the metal hoods), and full out (which provides better sun protection than most other hoods).  second, they cushion the impact energy that metal parts would send straight through to the lens.  In fact, I have gained so much confidence with my rubber lens hoods, that I've found myself hardly ever using the UV filters anymore (which have their own set of advantages AND disadvantages, but I don't think it's productive to get into a debate about that).
I am curious to learn more about this modular lens hood system that you mention.
